bool | MakeDirectory () |
| Create a directory named Path. More...
bool | DeleteDirectory () |
| Delete a directory named Path. More...
bool | OpenDirectory () |
| Open a directory named Path. More...
bool | RenameDirectory () |
| Rename a directory named Path to SecondaryPath. More...
bool | IsDirectory () |
| Check is directory named Path exists. More...
bool | GetActiveFileIsReadable () |
| Returns if this->Path is a readable file. More...
virtual void | SetPath (const char *) |
| Get/Set the path that will be used by the helper. More...
virtual char * | GetPath () |
virtual void | SetSecondaryPath (const char *) |
| Get/Set the secondary path that will potentially be used by the helper. More...
virtual char * | GetSecondaryPath () |
virtual int | GetActiveGlobalId () |
| Get/Set the globalId of the vtkDirectory present of the server that we will use to manipulate directories. More...
virtual void | SetActiveGlobalId (int) |
virtual void | Modified () |
