virtual int | GetOutlineFlag () |
| This flag is set during the execute method. More...
virtual void | SetUseOutline (int) |
| Set/get whether to produce outline (vs. More...
virtual int | GetUseOutline () |
void | SetGenerateFeatureEdges (bool) |
| Set/get whether to produce feature edges (vs. More...
virtual bool | GetGenerateFeatureEdges () |
virtual void | SetBlockColorsDistinctValues (int) |
| Determines the number of distinct values in vtkBlockColors. More...
virtual int | GetBlockColorsDistinctValues () |
void | SetGenerateCellNormals (int) |
| Whether to generate cell normals. More...
virtual int | GetGenerateCellNormals () |
virtual void | GenerateCellNormalsOn () |
virtual void | GenerateCellNormalsOff () |
void | SetGeneratePointNormals (bool) |
| Whether to generate point normals. More...
virtual bool | GetGeneratePointNormals () |
virtual void | GeneratePointNormalsOn () |
virtual void | GeneratePointNormalsOff () |
void | SetFeatureAngle (double) |
| Specify the angle that defines a sharp edge. More...
virtual double | GetFeatureAngle () |
void | SetSplitting (bool) |
| Turn on/off the splitting of sharp edges. More...
virtual void | SplittingOn () |
virtual void | SplittingOff () |
virtual void | SetTriangulate (int) |
| Whether to triangulate mesh for rendering. More...
virtual int | GetTriangulate () |
virtual void | TriangulateOn () |
virtual void | TriangulateOff () |
virtual void | SetNonlinearSubdivisionLevel (int) |
| Nonlinear faces are approximated with flat polygons. More...
virtual int | GetNonlinearSubdivisionLevel () |
virtual void | SetMatchBoundariesIgnoringCellOrder (int) |
| When two volumetric cells of different order are connected by their corners (for instance, a quadratic hexahedron next to a linear hexahedron ), the internal face is rendered and is not considered as a ghost cell. More...
virtual int | GetMatchBoundariesIgnoringCellOrder () |
virtual void | SetController (vtkMultiProcessController *) |
| Set and get the controller. More...
virtual vtkMultiProcessController * | GetController () |
void | SetPassThroughCellIds (int) |
| If on, the output polygonal dataset will have a celldata array that holds the cell index of the original 3D cell that produced each output cell. More...
virtual int | GetPassThroughCellIds () |
virtual void | PassThroughCellIdsOn () |
virtual void | PassThroughCellIdsOff () |
void | SetPassThroughPointIds (int) |
| If on, the output polygonal dataset will have a pointdata array that holds the point index of the original vertex that produced each output vertex. More...
virtual int | GetPassThroughPointIds () |
virtual void | PassThroughPointIdsOn () |
virtual void | PassThroughPointIdsOff () |
virtual void | SetGenerateProcessIds (bool) |
| If on, point arrays named vtkProcessId is added. More...
virtual bool | GetGenerateProcessIds () |
virtual void | GenerateProcessIdsOn () |
virtual void | GenerateProcessIdsOff () |
virtual void | SetHideInternalAMRFaces (bool) |
| This property affects the way AMR outlines and faces are generated. More...
virtual bool | GetHideInternalAMRFaces () |
virtual void | HideInternalAMRFacesOn () |
virtual void | HideInternalAMRFacesOff () |
virtual void | SetUseNonOverlappingAMRMetaDataForOutlines (bool) |
| For overlapping AMR, this property controls affects the way AMR outlines are generated. More...
virtual bool | GetUseNonOverlappingAMRMetaDataForOutlines () |
virtual void | UseNonOverlappingAMRMetaDataForOutlinesOn () |
virtual void | UseNonOverlappingAMRMetaDataForOutlinesOff () |
vtkDataObjectAlgorithm * | NewInstance () const |
virtual void | SetOutput (vtkDataObject *d) |
virtual int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
