virtual void | SetVectorScaleMode (int) |
| Get/set the vector scaling mode. More...
virtual int | GetVectorScaleMode () |
vtkMTimeType | GetMTime () override |
| Overridden to include SourceTransform's MTime. More...
virtual void | SetScaleFactor (double) |
| Set/get scale factor used to change the size of glyphs. More...
virtual double | GetScaleFactor () |
int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
| Overridden to create output data of appropriate type. More...
void | SetSourceConnection (int id, vtkAlgorithmOutput *algOutput) |
| Specify a source object at a specified table location. More...
void | SetSourceConnection (vtkAlgorithmOutput *algOutput) |
void | SetController (vtkMultiProcessController *) |
| Get/Set the vtkMultiProcessController to use for parallel processing. More...
virtual vtkMultiProcessController * | GetController () |
void | SetSourceTransform (vtkTransform *) |
| When set, this is use to transform the source polydata before using it to generate the glyph. More...
virtual vtkTransform * | GetSourceTransform () |
virtual void | SetOutputPointsPrecision (int) |
| Set/get the desired precision for the output types. More...
virtual int | GetOutputPointsPrecision () |
virtual void | SetGlyphMode (int) |
| Set/Get the mode at which glyphs will be generated. More...
virtual int | GetGlyphMode () |
virtual void | SetStride (int) |
| Set/Get the stride at which to glyph the dataset. More...
virtual int | GetStride () |
virtual void | SetSeed (int) |
| Set/Get Seed used for generating a spatially uniform distribution. More...
virtual int | GetSeed () |
virtual void | SetMaximumNumberOfSamplePoints (int) |
| Set/Get maximum number of sample points to use to sample the space when GlyphMode is set to SPATIALLY_UNIFORM_*. More...
virtual int | GetMaximumNumberOfSamplePoints () |
vtkPolyDataAlgorithm * | NewInstance () const |
vtkPolyData * | GetPolyDataInput (int port) |
vtkPolyData * | GetOutput () |
vtkPolyData * | GetOutput (int) |
virtual void | SetOutput (vtkDataObject *d) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
