void | WidgetInteraction (double eventPos[2]) override |
| Considering an eventPosition and current interaction state, this method will adjust internal position and shape so the widget behave correctly, ie: resizable, movable, but not going over the edges of the render window. More...
virtual void | BuildRepresentation () |
virtual void | SetImage (vtkImageData *img) |
virtual vtkImageData * | GetImage () |
virtual void | SetImageProperty (vtkProperty2D *p) |
virtual vtkProperty2D * | GetImageProperty () |
virtual void | GetActors2D (vtkPropCollection *pc) |
virtual void | ReleaseGraphicsResources (vtkWindow *) |
virtual int | RenderOverlay (vtkViewport *) |
vtkLogoRepresentation * | NewInstance () const |
virtual vtkCoordinate * | GetPositionCoordinate () |
virtual void | SetPosition (float x[2]) |
virtual void | SetPosition (float x, float y) |
virtual float * | GetPosition () |
virtual vtkCoordinate * | GetPosition2Coordinate () |
virtual void | SetPosition2 (float x[2]) |
virtual void | SetPosition2 (float x, float y) |
virtual float * | GetPosition2 () |
virtual void | SetShowBorder (int border) |
virtual int | GetShowBorderMinValue () |
virtual int | GetShowBorderMaxValue () |
virtual int | GetShowBorder () |
void | SetShowBorderToOff () |
void | SetShowBorderToOn () |
void | SetShowBorderToActive () |
virtual void | SetShowVerticalBorder (int) |
virtual int | GetShowVerticalBorder () |
virtual void | SetShowHorizontalBorder (int) |
virtual int | GetShowHorizontalBorder () |
virtual vtkProperty2D * | GetBorderProperty () |
virtual void | SetProportionalResize (int) |
virtual int | GetProportionalResize () |
virtual void | ProportionalResizeOn () |
virtual void | ProportionalResizeOff () |
virtual void | SetMinimumSize (int, int) |
void | SetMinimumSize (int[2]) |
virtual int * | GetMinimumSize () |
virtual void | GetMinimumSize (int &, int &) |
virtual void | GetMinimumSize (int[2]) |
virtual void | SetMaximumSize (int, int) |
void | SetMaximumSize (int[2]) |
virtual int * | GetMaximumSize () |
virtual void | GetMaximumSize (int &, int &) |
virtual void | GetMaximumSize (int[2]) |
virtual void | SetTolerance (int) |
virtual int | GetTolerance () |
virtual double * | GetSelectionPoint () |
virtual void | GetSelectionPoint (double data[2]) |
virtual void | SetMoving (int) |
virtual int | GetMoving () |
virtual void | MovingOn () |
virtual void | MovingOff () |
virtual void | StartWidgetInteraction (double eventPos[2]) |
virtual void | GetSize (double size[2]) |
virtual int | ComputeInteractionState (int X, int Y, int modify=0) |
virtual int | RenderOpaqueGeometry (vtkViewport *) |
virtual int | RenderTranslucentPolygonalGeometry (vtkViewport *) |
virtual int | HasTranslucentPolygonalGeometry () |
vtkBorderRepresentation * | NewInstance () const |
virtual void | PickingManagedOn () |
virtual void | PickingManagedOff () |
virtual void | SetPickingManaged (bool) |
virtual bool | GetPickingManaged () |
virtual void | SetRenderer (vtkRenderer *ren) |
virtual vtkRenderer * | GetRenderer () |
virtual void | PlaceWidget (double *vtkNotUsed(bounds[6])) |
virtual void | EndWidgetInteraction (double newEventPos[2]) |
virtual int | GetInteractionState () |
virtual void | Highlight (int vtkNotUsed(highlightOn)) |
virtual void | SetPlaceFactor (double) |
virtual double | GetPlaceFactor () |
virtual void | SetHandleSize (double) |
virtual double | GetHandleSize () |
virtual int | GetNeedToRender () |
virtual void | SetNeedToRender (int) |
virtual void | NeedToRenderOn () |
virtual void | NeedToRenderOff () |
virtual double * | GetBounds () |
virtual void | ShallowCopy (vtkProp *prop) |
virtual void | GetActors (vtkPropCollection *) |
virtual void | GetVolumes (vtkPropCollection *) |
virtual int | RenderOverlay (vtkViewport *vtkNotUsed(viewport)) |
virtual int | RenderOpaqueGeometry (vtkViewport *vtkNotUsed(viewport)) |
virtual int | RenderTranslucentPolygonalGeometry (vtkViewport *vtkNotUsed(viewport)) |
virtual int | RenderVolumetricGeometry (vtkViewport *vtkNotUsed(viewport)) |
vtkWidgetRepresentation * | NewInstance () const |
vtkProp * | NewInstance () const |
virtual void | Pick () |
virtual bool | HasKeys (vtkInformation *requiredKeys) |
virtual void | BuildPaths (vtkAssemblyPaths *paths, vtkAssemblyPath *path) |
virtual void | SetVisibility (int) |
virtual int | GetVisibility () |
virtual void | VisibilityOn () |
virtual void | VisibilityOff () |
virtual void | SetPickable (int) |
virtual int | GetPickable () |
virtual void | PickableOn () |
virtual void | PickableOff () |
virtual void | SetDragable (int) |
virtual int | GetDragable () |
virtual void | DragableOn () |
virtual void | DragableOff () |
virtual vtkMTimeType | GetRedrawMTime () |
virtual void | SetUseBounds (bool) |
virtual bool | GetUseBounds () |
virtual void | UseBoundsOn () |
virtual void | UseBoundsOff () |
virtual void | InitPathTraversal () |
virtual vtkAssemblyPath * | GetNextPath () |
virtual int | GetNumberOfPaths () |
virtual void | PokeMatrix (vtkMatrix4x4 *vtkNotUsed(matrix)) |
virtual vtkMatrix4x4 * | GetMatrix () |
virtual vtkInformation * | GetPropertyKeys () |
virtual void | SetPropertyKeys (vtkInformation *keys) |
virtual int | RenderVolumetricGeometry (vtkViewport *) |
virtual bool | RenderFilteredOpaqueGeometry (vtkViewport *v, vtkInformation *requiredKeys) |
virtual bool | RenderFilteredTranslucentPolygonalGeometry (vtkViewport *v, vtkInformation *requiredKeys) |
virtual bool | RenderFilteredVolumetricGeometry (vtkViewport *v, vtkInformation *requiredKeys) |
virtual bool | RenderFilteredOverlay (vtkViewport *v, vtkInformation *requiredKeys) |
virtual double | GetEstimatedRenderTime (vtkViewport *) |
virtual double | GetEstimatedRenderTime () |
virtual void | SetEstimatedRenderTime (double t) |
virtual void | RestoreEstimatedRenderTime () |
virtual void | AddEstimatedRenderTime (double t, vtkViewport *vtkNotUsed(vp)) |
virtual void | SetAllocatedRenderTime (double t, vtkViewport *vtkNotUsed(v)) |
virtual double | GetAllocatedRenderTime () |
void | SetRenderTimeMultiplier (double t) |
virtual double | GetRenderTimeMultiplier () |
virtual bool | GetSupportsSelection () |
virtual int | GetNumberOfConsumers () |
void | AddConsumer (vtkObject *c) |
void | RemoveConsumer (vtkObject *c) |
vtkObject * | GetConsumer (int i) |
int | IsConsumer (vtkObject *c) |
virtual void | Modified () |
