Used to load ParaView plugins. More...
#include <vtkPVPluginLoader.h>
bool | LoadPluginByName (const char *name, bool acceptDelayed=true) |
Tries to the load the plugin by name using tracked plugins. More... | |
bool | LoadPlugin (const char *filename) |
Tries to the load the plugin given the path to the plugin file. More... | |
bool | LoadPluginSilently (const char *filename) |
bool | LoadDelayedLoadPlugin (const std::string &name, const std::vector< std::string > &xmls, const std::string &filename) |
Load a delayed load plugin with provided name, XMLs and an actual plugin filename The actual loading will take place the first time a VTK object for a XML proxy needs to be created. More... | |
void | LoadPluginsFromPluginSearchPath () |
Loads all plugins under the directories mentioned in the SearchPaths. More... | |
void | LoadPluginsFromPluginConfigFile () |
Use PV_PLUGIN_CONFILE_FILE xml file to load specified plugins It can contain path to multiples xml pluginc config files sperated by env separator. More... | |
void | LoadPluginsFromPath (const char *path) |
Loads all plugin libraries at a path. More... | |
void | LoadPluginConfigurationXMLFromString (const char *xmlcontents) |
Simply forwards the call to vtkPVPluginTracker to load configuration xml. More... | |
void | LoadPluginConfigurationXML (const char *configurationFile) |
virtual char * | GetFileName () |
Returns the full filename for the plugin attempted to load most recently using LoadPlugin(). More... | |
virtual char * | GetPluginName () |
Get the plugin name. More... | |
virtual char * | GetPluginVersion () |
Get the plugin version string. More... | |
virtual char * | GetErrorString () |
Get the error string if the plugin failed to load. More... | |
virtual char * | GetSearchPaths () |
Get a string of standard search paths (path1;path2;path3) search paths are based on PV_PLUGIN_PATH, plugin dir relative to executable. More... | |
virtual bool | GetLoaded () |
Returns the status of most recent LoadPlugin call. More... | |
virtual void | Modified () |
static vtkPVPluginLoader * | New () |
static vtkPVPluginLoader * | SafeDownCast (vtkObject *o) |
static void | PluginLibraryUnloaded (const char *pluginname) |
Internal method used in pqParaViewPlugin.cxx.in to tell the vtkPVPluginLoader that a library was unloaded so it doesn't try to unload it again. More... | |
static vtkObject * | New () |
vtkPVPluginLoader () | |
~vtkPVPluginLoader () override | |
bool | LoadPluginInternal (const char *filename, bool no_errors) |
bool | LoadPluginInternal (vtkPVPlugin *plugin) |
Called by LoadPluginInternal() to do the final steps in loading of a plugin. More... | |
bool | IsLoaded (const char *filename, bool acceptDelayed=false) |
Return true if a plugin pointing provided filename is already loaded, return false otherwise. More... | |
virtual void | SetErrorString (const char *) |
virtual void | SetPluginName (const char *) |
virtual void | SetPluginVersion (const char *) |
virtual void | SetFileName (const char *) |
virtual void | SetSearchPaths (const char *) |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
char * | ErrorString |
char * | PluginName |
char * | PluginVersion |
char * | FileName |
char * | SearchPaths |
bool | Loaded |
bool | Debug |
vtkTimeStamp | MTime |
using | PluginLoaderCallback = std::function< bool(const char *)> |
static int | RegisterLoadPluginCallback (PluginLoaderCallback callback) |
static void | UnregisterLoadPluginCallback (int id) |
vtkPVPluginLoader can be used to load plugins for ParaView. vtkPVPluginLoader loads the plugin on the local process.
vtkPVPluginLoader logs plugin related messages using at PARAVIEW_LOG_PLUGIN_VERBOSITY
level. See vtkPVLogger::SetPluginVerbosity
for information on using environment variables to override or elevate the verbosity level.
This class only needed when loading plugins from shared libraries dynamically. For statically importing plugins, one directly uses PV_PLUGIN_IMPORT() macro defined in vtkPVPlugin.h.
Definition at line 30 of file vtkPVPluginLoader.h.
Definition at line 34 of file vtkPVPluginLoader.h.
using vtkPVPluginLoader::PluginLoaderCallback = std::function<bool(const char*)> |
Definition at line 143 of file vtkPVPluginLoader.h.
bool vtkPVPluginLoader::LoadPluginByName | ( | const char * | name, |
bool | acceptDelayed = true |
Definition at line 45 of file vtkPVPluginLoader.h.
Definition at line 46 of file vtkPVPluginLoader.h.
bool vtkPVPluginLoader::LoadDelayedLoadPlugin | ( | const std::string & | name, |
const std::vector< std::string > & | xmls, | ||
const std::string & | filename | ||
void vtkPVPluginLoader::LoadPluginConfigurationXMLFromString | ( | const char * | xmlcontents | ) |
void vtkPVPluginLoader::LoadPluginConfigurationXML | ( | const char * | configurationFile | ) |
void vtkPVPluginLoader::LoadPluginsFromPluginSearchPath | ( | ) |
void vtkPVPluginLoader::LoadPluginsFromPluginConfigFile | ( | ) |
It allow user to fine pick which plugins to load, instead of using PV_PLUGIN_PATH the format a xml plugin file should be the following :
void vtkPVPluginLoader::LoadPluginsFromPath | ( | const char * | path | ) |
This returns a valid name only after the plugin has been loaded.
This returns a valid version string only after the plugin has been loaded.
Returns nullptr if the plugin was loaded successfully.
Delayed load plugin are considered not loaded until they actually are as standard plugins.
protectedvirtual |
protectedvirtual |
protectedvirtual |
protectedvirtual |
protectedvirtual |
Definition at line 177 of file vtkPVPluginLoader.h.
Definition at line 180 of file vtkPVPluginLoader.h.
Definition at line 181 of file vtkPVPluginLoader.h.
Definition at line 182 of file vtkPVPluginLoader.h.
Definition at line 183 of file vtkPVPluginLoader.h.
Definition at line 184 of file vtkPVPluginLoader.h.
