virtual void | SetPassCellArrays (bool) |
| Shallow copy the input cell data arrays to the output. More...
virtual void | PassCellArraysOn () |
virtual void | PassCellArraysOff () |
virtual bool | GetPassCellArrays () |
virtual void | SetPassPointArrays (bool) |
| Shallow copy the input point data arrays to the output Off by default. More...
virtual void | PassPointArraysOn () |
virtual void | PassPointArraysOff () |
virtual bool | GetPassPointArrays () |
virtual void | SetPassFieldArrays (bool) |
| Set whether to pass the field-data arrays from the Input i.e. More...
virtual void | PassFieldArraysOn () |
virtual void | PassFieldArraysOff () |
virtual bool | GetPassFieldArrays () |
virtual void | SetTolerance (double) |
| Set the tolerance used to compute whether a point in the source is in a cell of the input. More...
virtual double | GetTolerance () |
virtual void | SetComputeTolerance (bool) |
| Set whether to use the Tolerance field or precompute the tolerance. More...
virtual void | ComputeToleranceOn () |
virtual void | ComputeToleranceOff () |
virtual bool | GetComputeTolerance () |
virtual void | SetPassPartialArrays (bool) |
| When dealing with composite datasets, partial arrays are common i.e. More...
virtual bool | GetPassPartialArrays () |
virtual void | PassPartialArraysOn () |
virtual void | PassPartialArraysOff () |
virtual int | GetSamplingPattern () |
| Setter and getter for SamplingPattern (values to be taken from the enumeration vtkProbeLineFilter::SamplingPattern). More...
virtual void | SetSamplingPattern (int) |
virtual int | GetLineResolution () |
| Setter and getter for LineResolution . More...
virtual void | SetLineResolution (int) |
virtual double * | GetPoint1 () |
| Get/Set the begin and end points for the line to probe against. More...
virtual void | GetPoint1 (double &, double &, double &) |
virtual void | GetPoint1 (double [3]) |
virtual void | SetPoint1 (double, double, double) |
virtual void | SetPoint1 (double [3]) |
virtual double * | GetPoint2 () |
virtual void | GetPoint2 (double &, double &, double &) |
virtual void | GetPoint2 (double [3]) |
virtual void | SetPoint2 (double, double, double) |
virtual void | SetPoint2 (double [3]) |
vtkPolyDataAlgorithm * | NewInstance () const |
vtkPolyData * | GetPolyDataInput (int port) |
vtkPolyData * | GetOutput () |
vtkPolyData * | GetOutput (int) |
virtual void | SetOutput (vtkDataObject *d) |
virtual int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
