a window associated with current process, if any. More...
#include <vtkPVProcessWindow.h>
virtual void | Modified () |
static vtkPVProcessWindow * | SafeDownCast (vtkObject *o) |
static vtkRenderWindow * | GetRenderWindow () |
Returns the render window for this process. More... | |
static void | PrepareForRendering () |
This may be called to ensured that the shared window is created/initialized at least once. More... | |
static vtkObject * | New () |
vtkPVProcessWindow () | |
~vtkPVProcessWindow () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Static Protected Member Functions | |
static vtkRenderWindow * | NewWindow () |
static vtkRenderWindow * | NewTileDisplayWindow () |
static vtkRenderWindow * | NewCAVEWindow () |
bool | Debug |
vtkTimeStamp | MTime |
In certain configurations, a ParaView process may have a single vtkRenderWindow per process that is used to show the rendering results. For example, in CAVE or tile-display mode, each render-server (or pvserver) process may show its results on a user-viewable window. This class provides access to that window.
It is a singleton, since each process can have at most one such window.
Definition at line 24 of file vtkPVProcessWindow.h.
Definition at line 27 of file vtkPVProcessWindow.h.
May return nullptr on processes where ParaView rules dictate no such process specific window is necessary. The first time this method is called the window may get created and initialized based on the configuration.
staticprotected |
staticprotected |
staticprotected |
