helper class that used selection and ray casting to find the intersection point between the user picking point and the concreate cell underneath. More...
#include <vtkPVRayCastPickingHelper.h>
void | SetInput (vtkAlgorithm *) |
Set input on which the selection apply. More... | |
void | SetSelection (vtkAlgorithm *) |
Set the selection that extract the cell that intersect the ray. More... | |
void | ComputeIntersection () |
Compute the intersection. More... | |
virtual double * | GetIntersection () |
virtual void | GetIntersection (double &, double &, double &) |
virtual void | GetIntersection (double [3]) |
virtual double * | GetIntersectionNormal () |
virtual void | GetIntersectionNormal (double &, double &, double &) |
virtual void | GetIntersectionNormal (double [3]) |
virtual void | SetPointA (double, double, double) |
Set the point 1 that compose the ray. More... | |
virtual void | SetPointA (double [3]) |
virtual double * | GetPointA () |
virtual void | GetPointA (double &, double &, double &) |
virtual void | GetPointA (double [3]) |
virtual void | SetPointB (double, double, double) |
Set the point 2 that compose the ray. More... | |
virtual void | SetPointB (double [3]) |
virtual double * | GetPointB () |
virtual void | GetPointB (double &, double &, double &) |
virtual void | GetPointB (double [3]) |
virtual void | SetSnapOnMeshPoint (bool) |
Set the flag to use directly selected points on mesh as intersection. More... | |
virtual bool | GetSnapOnMeshPoint () |
virtual void | Modified () |
static vtkPVRayCastPickingHelper * | New () |
static vtkPVRayCastPickingHelper * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkPVRayCastPickingHelper () | |
~vtkPVRayCastPickingHelper () override | |
void | ComputeIntersectionFromDataSet (vtkDataSet *ds) |
Compute the intersection using provided dataset. More... | |
int | ComputeSurfaceNormal (vtkDataSet *data, vtkCell *cell, int subId, double *weights) |
Compute the intersection normal either by interpolating the point normals at the intersected point, or by computing the plane normal for the 2D intersected face/cell. More... | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
double | Intersection [3] |
double | IntersectionNormal [3] |
double | PointA [3] |
double | PointB [3] |
bool | SnapOnMeshPoint |
vtkAlgorithm * | Input |
vtkAlgorithm * | Selection |
bool | Debug |
vtkTimeStamp | MTime |
Definition at line 21 of file vtkPVRayCastPickingHelper.h.
Definition at line 25 of file vtkPVRayCastPickingHelper.h.
void vtkPVRayCastPickingHelper::SetInput | ( | vtkAlgorithm * | ) |
void vtkPVRayCastPickingHelper::SetSelection | ( | vtkAlgorithm * | ) |
void vtkPVRayCastPickingHelper::ComputeIntersection | ( | ) |
Definition at line 88 of file vtkPVRayCastPickingHelper.h.
Definition at line 89 of file vtkPVRayCastPickingHelper.h.
Definition at line 90 of file vtkPVRayCastPickingHelper.h.
Definition at line 91 of file vtkPVRayCastPickingHelper.h.
Definition at line 92 of file vtkPVRayCastPickingHelper.h.
Definition at line 93 of file vtkPVRayCastPickingHelper.h.
Definition at line 94 of file vtkPVRayCastPickingHelper.h.
