virtual void | AddValueLabelIfUnoccluded (double value, double pos, double diff) |
| Add value as annotation label on scalar bar at the given position. More...
void | ReleaseGraphicsResources (vtkWindow *) override |
| Release any graphics resources that are being consumed by this actor. More...
int | RenderOpaqueGeometry (vtkViewport *viewport) override |
| Overridden to sync internal variables with renderer state. More...
int | RenderOverlay (vtkViewport *viewport) override |
| Draw the scalar bar and annotation text to the screen. More...
virtual double | GetAspectRatio () |
| The bar aspect ratio (length/width). More...
virtual void | SetAspectRatio (double) |
virtual int | GetAutomaticLabelFormat () |
| If true (the default), the printf format used for the labels will be automatically generated to make the numbers best fit within the widget. More...
virtual void | SetAutomaticLabelFormat (int) |
virtual void | AutomaticLabelFormatOn () |
virtual void | AutomaticLabelFormatOff () |
virtual int | GetDrawTickMarks () |
| If true (the default), tick marks will be drawn. More...
virtual void | SetDrawTickMarks (int) |
virtual void | DrawTickMarksOn () |
virtual void | DrawTickMarksOff () |
virtual int | GetDrawSubTickMarks () |
| If true (the default), sub-tick marks will be drawn. More...
virtual void | SetDrawSubTickMarks (int) |
virtual void | DrawSubTickMarksOn () |
virtual void | DrawSubTickMarksOff () |
virtual int | GetAddRangeLabels () |
| Set whether the range endpoints (minimum and maximum) are added as labels alongside other value labels. More...
virtual void | SetAddRangeLabels (int) |
virtual void | AddRangeLabelsOn () |
virtual void | AddRangeLabelsOff () |
virtual void | SetAutomaticAnnotations (int) |
| Set whether annotions are automatically created according the number of discrete colors. More...
virtual int | GetAutomaticAnnotations () |
virtual void | AutomaticAnnotationsOn () |
virtual void | AutomaticAnnotationsOff () |
virtual char * | GetRangeLabelFormat () |
| Set the C-style format string for the range labels. More...
virtual void | SetRangeLabelFormat (const char *) |
virtual int | GetTitleJustification () |
| Set the title justification. More...
virtual void | SetTitleJustification (int) |
virtual int | GetAddRangeAnnotations () |
| Set whether the scalar data range endpoints (minimum and maximum) are added as annotations. More...
virtual void | SetAddRangeAnnotations (int) |
virtual void | AddRangeAnnotationsOn () |
virtual void | AddRangeAnnotationsOff () |
vtkScalarBarActor * | NewInstance () const |
virtual int | HasTranslucentPolygonalGeometry () |
virtual void | GetScalarBarRect (int rect[4], vtkViewport *viewport) |
void | ShallowCopy (vtkProp *prop) |
virtual int | RenderTranslucentPolygonalGeometry (vtkViewport *) |
virtual void | SetLookupTable (vtkScalarsToColors *) |
virtual vtkScalarsToColors * | GetLookupTable () |
virtual void | SetUseOpacity (int) |
virtual int | GetUseOpacity () |
virtual void | UseOpacityOn () |
virtual void | UseOpacityOff () |
virtual void | SetMaximumNumberOfColors (int) |
virtual int | GetMaximumNumberOfColors () |
virtual void | SetNumberOfLabels (int) |
virtual int | GetNumberOfLabels () |
virtual void | SetOrientation (int) |
virtual int | GetOrientation () |
void | SetOrientationToHorizontal () |
void | SetOrientationToVertical () |
virtual void | SetTitleTextProperty (vtkTextProperty *p) |
virtual vtkTextProperty * | GetTitleTextProperty () |
virtual void | SetLabelTextProperty (vtkTextProperty *p) |
virtual vtkTextProperty * | GetLabelTextProperty () |
virtual void | SetAnnotationTextProperty (vtkTextProperty *p) |
virtual vtkTextProperty * | GetAnnotationTextProperty () |
virtual void | SetLabelFormat (const char *) |
virtual char * | GetLabelFormat () |
virtual void | SetTitle (const char *) |
virtual char * | GetTitle () |
virtual void | SetComponentTitle (const char *) |
virtual char * | GetComponentTitle () |
virtual void | SetTextureGridWidth (double) |
virtual double | GetTextureGridWidth () |
virtual vtkTexturedActor2D * | GetTextureActor () |
virtual void | SetTextPosition (int) |
virtual int | GetTextPosition () |
virtual void | SetTextPositionToPrecedeScalarBar () |
virtual void | SetTextPositionToSucceedScalarBar () |
virtual void | SetMaximumWidthInPixels (int) |
virtual int | GetMaximumWidthInPixels () |
virtual void | SetMaximumHeightInPixels (int) |
virtual int | GetMaximumHeightInPixels () |
virtual void | SetAnnotationLeaderPadding (double) |
virtual double | GetAnnotationLeaderPadding () |
virtual void | SetDrawAnnotations (int) |
virtual int | GetDrawAnnotations () |
virtual void | DrawAnnotationsOn () |
virtual void | DrawAnnotationsOff () |
virtual void | SetDrawNanAnnotation (int) |
virtual int | GetDrawNanAnnotation () |
virtual void | DrawNanAnnotationOn () |
virtual void | DrawNanAnnotationOff () |
virtual void | SetDrawBelowRangeSwatch (bool) |
virtual bool | GetDrawBelowRangeSwatch () |
virtual void | DrawBelowRangeSwatchOn () |
virtual void | DrawBelowRangeSwatchOff () |
virtual void | SetBelowRangeAnnotation (const char *) |
virtual char * | GetBelowRangeAnnotation () |
virtual void | SetDrawAboveRangeSwatch (bool) |
virtual bool | GetDrawAboveRangeSwatch () |
virtual void | DrawAboveRangeSwatchOn () |
virtual void | DrawAboveRangeSwatchOff () |
virtual void | SetAboveRangeAnnotation (const char *) |
virtual char * | GetAboveRangeAnnotation () |
virtual void | SetFixedAnnotationLeaderLineColor (int) |
virtual int | GetFixedAnnotationLeaderLineColor () |
virtual void | FixedAnnotationLeaderLineColorOn () |
virtual void | FixedAnnotationLeaderLineColorOff () |
virtual void | SetNanAnnotation (const char *) |
virtual char * | GetNanAnnotation () |
virtual void | SetAnnotationTextScaling (int) |
virtual int | GetAnnotationTextScaling () |
virtual void | AnnotationTextScalingOn () |
virtual void | AnnotationTextScalingOff () |
virtual void | SetDrawBackground (int) |
virtual int | GetDrawBackground () |
virtual void | DrawBackgroundOn () |
virtual void | DrawBackgroundOff () |
virtual void | SetDrawFrame (int) |
virtual int | GetDrawFrame () |
virtual void | DrawFrameOn () |
virtual void | DrawFrameOff () |
virtual void | SetDrawColorBar (int) |
virtual int | GetDrawColorBar () |
virtual void | DrawColorBarOn () |
virtual void | DrawColorBarOff () |
virtual void | SetDrawTickLabels (int) |
virtual int | GetDrawTickLabels () |
virtual void | DrawTickLabelsOn () |
virtual void | DrawTickLabelsOff () |
virtual void | SetBackgroundProperty (vtkProperty2D *p) |
virtual vtkProperty2D * | GetBackgroundProperty () |
virtual void | SetFrameProperty (vtkProperty2D *p) |
virtual vtkProperty2D * | GetFrameProperty () |
virtual int | GetTextPad () |
virtual void | SetTextPad (int) |
virtual int | GetVerticalTitleSeparation () |
virtual void | SetVerticalTitleSeparation (int) |
virtual double | GetBarRatio () |
virtual void | SetBarRatio (double) |
virtual double | GetTitleRatio () |
virtual void | SetTitleRatio (double) |
virtual void | SetUnconstrainedFontSize (bool) |
virtual bool | GetUnconstrainedFontSize () |
virtual void | UnconstrainedFontSizeOn () |
virtual void | UnconstrainedFontSizeOff () |
vtkActor2D * | NewInstance () const |
vtkProperty2D * | GetProperty () |
virtual void | SetProperty (vtkProperty2D *) |
void | SetDisplayPosition (int, int) |
virtual void | GetActors2D (vtkPropCollection *pc) |
virtual void | SetMapper (vtkMapper2D *mapper) |
virtual vtkMapper2D * | GetMapper () |
virtual void | SetLayerNumber (int) |
virtual int | GetLayerNumber () |
virtual vtkCoordinate * | GetPositionCoordinate () |
virtual void | SetPosition (float x[2]) |
virtual void | SetPosition (float x, float y) |
virtual float * | GetPosition () |
virtual vtkCoordinate * | GetPosition2Coordinate () |
virtual void | SetPosition2 (float x[2]) |
virtual void | SetPosition2 (float x, float y) |
virtual float * | GetPosition2 () |
void | SetWidth (double w) |
double | GetWidth () |
void | SetHeight (double h) |
double | GetHeight () |
virtual vtkCoordinate * | GetActualPositionCoordinate (void) |
virtual vtkCoordinate * | GetActualPosition2Coordinate (void) |
vtkProp * | NewInstance () const |
virtual void | Pick () |
virtual bool | HasKeys (vtkInformation *requiredKeys) |
virtual void | BuildPaths (vtkAssemblyPaths *paths, vtkAssemblyPath *path) |
virtual void | GetActors (vtkPropCollection *) |
virtual void | GetVolumes (vtkPropCollection *) |
virtual void | SetVisibility (int) |
virtual int | GetVisibility () |
virtual void | VisibilityOn () |
virtual void | VisibilityOff () |
virtual void | SetPickable (int) |
virtual int | GetPickable () |
virtual void | PickableOn () |
virtual void | PickableOff () |
virtual void | SetDragable (int) |
virtual int | GetDragable () |
virtual void | DragableOn () |
virtual void | DragableOff () |
virtual vtkMTimeType | GetRedrawMTime () |
virtual void | SetUseBounds (bool) |
virtual bool | GetUseBounds () |
virtual void | UseBoundsOn () |
virtual void | UseBoundsOff () |
virtual double * | GetBounds () |
virtual void | InitPathTraversal () |
virtual vtkAssemblyPath * | GetNextPath () |
virtual int | GetNumberOfPaths () |
virtual void | PokeMatrix (vtkMatrix4x4 *vtkNotUsed(matrix)) |
virtual vtkMatrix4x4 * | GetMatrix () |
virtual vtkInformation * | GetPropertyKeys () |
virtual void | SetPropertyKeys (vtkInformation *keys) |
virtual int | RenderVolumetricGeometry (vtkViewport *) |
virtual bool | RenderFilteredOpaqueGeometry (vtkViewport *v, vtkInformation *requiredKeys) |
virtual bool | RenderFilteredTranslucentPolygonalGeometry (vtkViewport *v, vtkInformation *requiredKeys) |
virtual bool | RenderFilteredVolumetricGeometry (vtkViewport *v, vtkInformation *requiredKeys) |
virtual bool | RenderFilteredOverlay (vtkViewport *v, vtkInformation *requiredKeys) |
virtual double | GetEstimatedRenderTime (vtkViewport *) |
virtual double | GetEstimatedRenderTime () |
virtual void | SetEstimatedRenderTime (double t) |
virtual void | RestoreEstimatedRenderTime () |
virtual void | AddEstimatedRenderTime (double t, vtkViewport *vtkNotUsed(vp)) |
virtual void | SetAllocatedRenderTime (double t, vtkViewport *vtkNotUsed(v)) |
virtual double | GetAllocatedRenderTime () |
void | SetRenderTimeMultiplier (double t) |
virtual double | GetRenderTimeMultiplier () |
virtual bool | GetSupportsSelection () |
virtual int | GetNumberOfConsumers () |
void | AddConsumer (vtkObject *c) |
void | RemoveConsumer (vtkObject *c) |
vtkObject * | GetConsumer (int i) |
int | IsConsumer (vtkObject *c) |
virtual void | Modified () |
