void | AddFrustum (double vertices[32]) |
| Set a frustum to choose within. More...
virtual void | SetArrayName (const char *) |
| For threshold and value selection, this controls the name of the scalar array that will be thresholded within. More...
void | AddGlobalID (vtkIdType id) |
| Add global IDs. More...
void | RemoveAllGlobalIDs () |
void | AddPedigreeID (const char *domain, vtkIdType id) |
| Add integer pedigree IDs in a particular domain. More...
void | RemoveAllPedigreeIDs () |
void | AddPedigreeStringID (const char *domain, const char *id) |
| Add string pedigree IDs in a particular domain. More...
void | RemoveAllPedigreeStringIDs () |
void | AddID (vtkIdType piece, vtkIdType id) |
| Add a (piece, id) to the selection set. More...
void | RemoveAllIDs () |
void | AddValue (vtkIdType piece, vtkIdType value) |
| Add a (piece, value) to the selection set. More...
void | RemoveAllValues () |
void | AddCompositeID (unsigned int composite_index, vtkIdType piece, vtkIdType id) |
| Add IDs that will be added to the selection produced by the selection source. More...
void | RemoveAllCompositeIDs () |
void | AddHierarhicalID (unsigned int level, unsigned int dataset, vtkIdType id) |
| The list of IDs that will be added to the selection produced by the selection source. More...
void | RemoveAllHierarchicalIDs () |
void | AddThreshold (double min, double max) |
| Add a value range to threshold within. More...
void | RemoveAllThresholds () |
void | AddBlock (vtkIdType blockno) |
| Add the flat-index/composite index for a block. More...
void | RemoveAllBlocks () |
void | AddLocation (double x, double y, double z) |
| Add a point in world space to probe at. More...
void | RemoveAllLocations () |
void | AddBlockSelector (const char *selector) |
| Add/Remove block-selectors to make selections with vtkSelectionNode::BLOCK_SELECTORS as the content-type. More...
void | RemoveAllBlockSelectors () |
virtual void | SetProcessID (int) |
| Get/Set which process to limit the selection to. More...
virtual int | GetProcessID () |
virtual void | SetFieldType (int) |
| Set the field type for the generated selection. More...
virtual int | GetFieldType () |
virtual void | SetContainingCells (int) |
| When extracting by points, extract the cells that contain the passing points. More...
virtual int | GetContainingCells () |
virtual void | SetInverse (int) |
virtual int | GetInverse () |
virtual void | SetQueryString (const char *) |
| Set/get the query expression string. More...
virtual char * | GetQueryString () |
virtual void | SetNumberOfLayers (int) |
| Specify number of layers to extract connected to the selected elements. More...
virtual int | GetNumberOfLayers () |
virtual void | SetRemoveSeed (bool) |
| Set/Get the flag the control if, when using the number of layers to extract connected elements, the initial selection seed should be removed. More...
virtual bool | GetRemoveSeed () |
virtual void | SetRemoveIntermediateLayers (bool) |
| Set/Get the flag the control if, when using the number of layers to extract connected elements, the intermediate layers should be removed. More...
virtual bool | GetRemoveIntermediateLayers () |
vtkSelectionAlgorithm * | NewInstance () const |
virtual int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
vtkSelection * | GetOutput () |
vtkSelection * | GetOutput (int index) |
void | SetInputData (vtkDataObject *obj) |
void | SetInputData (int index, vtkDataObject *obj) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
