Gets features of the server. More...
#include <vtkPVServerInformation.h>
typedef vtkPVInformation | Superclass |
virtual bool | GetIsInTileDisplay () |
Returns true if server is in tile-display mode. More... | |
virtual bool | GetIsInCave () |
Returns true if server is in CAVE mode. More... | |
void | DeepCopy (vtkPVServerInformation *info) |
void | CopyFromObject (vtkObject *) override |
Transfer information about a single object into this object. More... | |
void | AddInformation (vtkPVInformation *) override |
Merge another information object. More... | |
virtual void | SetNVPipeSupport (bool) |
if the server supports compressing images via NVPipe More... | |
virtual bool | GetNVPipeSupport () |
virtual int * | GetTileDimensions () |
When in tile display mode, returns the tile dimensions. More... | |
virtual void | GetTileDimensions (int &, int &) |
virtual void | GetTileDimensions (int [2]) |
virtual bool | IsMPIInitialized () const |
Return whether MPI is initialized or not. More... | |
virtual void | SetRemoteRendering (int) |
This flag indicates whether the server can render remotely. More... | |
virtual int | GetRemoteRendering () |
void | CopyToStream (vtkClientServerStream *) override |
Manage a serialized version of the information. More... | |
void | CopyFromStream (const vtkClientServerStream *) override |
virtual void | SetUseIceT (int) |
Returns 1 if IceT is available. More... | |
virtual int | GetUseIceT () |
virtual void | SetTimeout (int) |
Get/Set the time after which the server timesout. More... | |
virtual int | GetTimeout () |
const std::string & | GetTimeoutCommand () const |
Get the timeout command used by the server to retrieve remaining time. More... | |
virtual int | GetTimeoutCommandInterval () |
Get the time interval in seconds between consecutive calls of TimeoutCommand. More... | |
virtual int | GetNumberOfProcesses () |
Get the number of processes. More... | |
virtual int | GetMultiClientsEnable () |
Return true if the server allow server client to connect to itself. More... | |
virtual int | GetClientId () |
Get the id that correspond to the current client. More... | |
virtual void | SetIdTypeSize (int) |
Set/Get vtkIdType size, which can be 32 or 64. More... | |
virtual int | GetIdTypeSize () |
virtual std::string | GetSMPBackendName () |
Get the SMP Tools backend name of the server. More... | |
virtual int | GetSMPMaxNumberOfThreads () |
Get the max number of threads of the server. More... | |
virtual int | GetAcceleratedFiltersOverrideAvailable () |
Return true if VTK-m accelerated filters override is enabled in this build. More... | |
virtual void | CopyParametersToStream (vtkMultiProcessStream &) |
Serialize/Deserialize the parameters that control how/what information is gathered. More... | |
virtual void | CopyParametersFromStream (vtkMultiProcessStream &) |
virtual int | GetRootOnly () |
Set/get whether to gather information only from the root. More... | |
virtual void | Modified () |
static vtkPVServerInformation * | New () |
static vtkPVServerInformation * | SafeDownCast (vtkObject *o) |
static vtkPVInformation * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
Protected Attributes | |
int | NumberOfProcesses |
bool | MPIInitialized |
int | OGVSupport = 1 |
int | AVISupport = 0 |
bool | NVPipeSupport = false |
int | RemoteRendering = 1 |
int | Timeout = 0 |
std::string | TimeoutCommand |
int | TimeoutCommandInterval = 60 |
int | UseIceT |
int | MultiClientsEnable = 0 |
int | ClientId = 0 |
int | IdTypeSize = 0 |
bool | IsInTileDisplay = false |
bool | IsInCave = false |
int | TileDimensions [2] = { 0, 0 } |
std::string | SMPBackendName |
int | SMPMaxNumberOfThreads |
bool | AcceleratedFiltersOverrideAvailable |
int | RootOnly |
bool | Debug |
vtkTimeStamp | MTime |
This objects is used by the client to get the features supported by the server. At the moment, server information is only on the root.
Definition at line 22 of file vtkPVServerInformation.h.
Definition at line 26 of file vtkPVServerInformation.h.
Reimplemented from vtkPVInformation.
If it is off, all rendering has to be on the client. This is only off when the user starts the server with the –disable-composite command line option.
void vtkPVServerInformation::DeepCopy | ( | vtkPVServerInformation * | info | ) |
Implements vtkPVInformation.
Definition at line 98 of file vtkPVServerInformation.h.
Defaults to 60.
Definition at line 173 of file vtkPVServerInformation.h.
Definition at line 174 of file vtkPVServerInformation.h.
Definition at line 175 of file vtkPVServerInformation.h.
Definition at line 176 of file vtkPVServerInformation.h.
Definition at line 177 of file vtkPVServerInformation.h.
Definition at line 178 of file vtkPVServerInformation.h.
Definition at line 179 of file vtkPVServerInformation.h.
Definition at line 180 of file vtkPVServerInformation.h.
Definition at line 181 of file vtkPVServerInformation.h.
Definition at line 182 of file vtkPVServerInformation.h.
Definition at line 183 of file vtkPVServerInformation.h.
Definition at line 184 of file vtkPVServerInformation.h.
Definition at line 185 of file vtkPVServerInformation.h.
Definition at line 186 of file vtkPVServerInformation.h.
Definition at line 187 of file vtkPVServerInformation.h.
Definition at line 188 of file vtkPVServerInformation.h.
Definition at line 189 of file vtkPVServerInformation.h.
Definition at line 190 of file vtkPVServerInformation.h.
Definition at line 191 of file vtkPVServerInformation.h.
