Holds timer log for all processes. More...
#include <vtkPVTimerInformation.h>
typedef vtkPVInformation | Superclass |
void | AddInformation (vtkPVInformation *info) override |
Merge another information object. More... | |
virtual void | SetLogThreshold (double) |
Get/Set the threshold to use to gather the timer log information. More... | |
virtual double | GetLogThreshold () |
int | GetNumberOfLogs () |
Access to the logs. More... | |
char * | GetLog (int proc) |
void | CopyFromObject (vtkObject *data) override |
Transfer information about a single object into this object. More... | |
virtual void | CopyFromMessage (unsigned char *msg) |
void | CopyToStream (vtkClientServerStream *) override |
Serialize objects to/from a stream object. More... | |
void | CopyFromStream (const vtkClientServerStream *css) override |
virtual int | GetRootOnly () |
Set/get whether to gather information only from the root. More... | |
virtual void | Modified () |
static vtkPVTimerInformation * | New () |
static vtkPVTimerInformation * | SafeDownCast (vtkObject *o) |
static vtkPVInformation * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
Protected Attributes | |
double | LogThreshold |
int | NumberOfLogs |
char ** | Logs |
int | RootOnly |
bool | Debug |
vtkTimeStamp | MTime |
void | CopyParametersToStream (vtkMultiProcessStream &) override |
Serialize/Deserialize the parameters that control how/what information is gathered. More... | |
void | CopyParametersFromStream (vtkMultiProcessStream &) override |
vtkPVTimerInformation () | |
~vtkPVTimerInformation () override | |
I am using this information object to gather timer logs from all processes.
Definition at line 16 of file vtkPVTimerInformation.h.
Definition at line 20 of file vtkPVTimerInformation.h.
This are different from the ivars that constitute the gathered information itself.
protecteddelete |
Reimplemented from vtkPVInformation.
This must be set before calling GatherInformation().
int vtkPVTimerInformation::GetNumberOfLogs | ( | ) |
Access to the logs.
char* vtkPVTimerInformation::GetLog | ( | int | proc | ) |
Access to the logs.
Implements vtkPVInformation.
protecteddelete |
Definition at line 79 of file vtkPVTimerInformation.h.
Definition at line 80 of file vtkPVTimerInformation.h.
Definition at line 81 of file vtkPVTimerInformation.h.
