Shape that represents an individual control node in a 2D transfer function. More...
#include <vtkPVTransferFunction2DBox.h>
virtual const vtkRectd & | GetBox () |
Returns the current box as [x0, y0, width, height]. More... | |
virtual vtkImageData * | GetTexture () |
Get the texture for this box item. More... | |
virtual void | SetBox (double x, double y, double width, double height) |
Set position and width with respect to origin i.e. More... | |
virtual void | SetBox (const vtkRectd &b) |
virtual void | SetColor (double, double, double, double) |
Set/Get the color (r,g,b,a) to be used for this box. More... | |
virtual void | SetColor (double [4]) |
virtual double * | GetColor () |
virtual void | GetColor (double &, double &, double &, double &) |
virtual void | GetColor (double [4]) |
virtual void | SetTextureSize (int, int) |
Set/Get the texture size of the box. More... | |
void | SetTextureSize (int [2]) |
virtual int * | GetTextureSize () |
virtual void | GetTextureSize (int &, int &) |
virtual void | GetTextureSize (int [2]) |
virtual void | SetGaussianSigmaFactor (double) |
Set/Get the standard deviation for the gaussian function. More... | |
virtual double | GetGaussianSigmaFactor () |
virtual void | Modified () |
static vtkPVTransferFunction2DBox * | New () |
Instantiate the class. More... | |
static vtkObject * | New () |
vtkPVTransferFunction2DBox () | |
~vtkPVTransferFunction2DBox () override | |
virtual void | ComputeTexture () |
Internal method to compute texture. More... | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
vtkRectd | Box |
double | Color [4] = { 1, 1, 1, 1 } |
int | TextureSize [2] = { 128, 128 } |
double | GaussianSigmaFactor = 30.0 |
vtkImageData * | Texture = nullptr |
bool | Debug |
vtkTimeStamp | MTime |
Standard methods for the VTK class. More... | |
static vtkPVTransferFunction2DBox * | SafeDownCast (vtkObject *o) |
Definition at line 22 of file vtkPVTransferFunction2DBox.h.
Definition at line 34 of file vtkPVTransferFunction2DBox.h.
bottom left corner.
bottom left corner.
Defaults to opaque white (1, 1, 1, 1).
The texture will be computed, if needed.
Defaults to (128, 128).
void vtkPVTransferFunction2DBox::SetTextureSize | ( | int | [2] | ) |
Defaults to 30.
Defaults to 30.
protectedvirtual |
Definition at line 89 of file vtkPVTransferFunction2DBox.h.
Definition at line 90 of file vtkPVTransferFunction2DBox.h.
Definition at line 91 of file vtkPVTransferFunction2DBox.h.
Definition at line 92 of file vtkPVTransferFunction2DBox.h.
Definition at line 94 of file vtkPVTransferFunction2DBox.h.
