virtual void | SetArrayAssociation (int) |
| Which field data to get the arrays from. More...
virtual int | GetArrayAssociation () |
virtual void | SetExpression (std::string) |
| Set the text of the python expression to execute. More...
virtual std::string | GetExpression () |
virtual void | SetMultilineExpression (std::string) |
| Set the text of the python multiline expression. More...
virtual std::string | GetMultilineExpression () |
virtual void | SetArrayName (const char *) |
| Set the name of the output array. More...
virtual char * | GetArrayName () |
virtual int | GetResultArrayType () |
| Type of the result array. More...
virtual void | SetResultArrayType (int) |
virtual bool | GetUseMultilineExpression () |
| If true, executes MultilineExpression , which is a multiline string representing a Python script, ending by a return statement. More...
virtual void | SetUseMultilineExpression (bool) |
vtkProgrammableFilter * | NewInstance () const |
void | SetExecuteMethod (void(*f)(void *), void *arg) |
void | SetExecuteMethodArgDelete (void(*f)(void *)) |
vtkPolyData * | GetPolyDataInput () |
vtkStructuredPoints * | GetStructuredPointsInput () |
vtkStructuredGrid * | GetStructuredGridInput () |
vtkUnstructuredGrid * | GetUnstructuredGridInput () |
vtkRectilinearGrid * | GetRectilinearGridInput () |
vtkGraph * | GetGraphInput () |
vtkTable * | GetTableInput () |
virtual void | SetCopyArrays (bool) |
virtual bool | GetCopyArrays () |
virtual void | CopyArraysOn () |
virtual void | CopyArraysOff () |
vtkPassInputTypeAlgorithm * | NewInstance () const |
vtkPolyData * | GetPolyDataOutput () |
vtkStructuredPoints * | GetStructuredPointsOutput () |
vtkImageData * | GetImageDataOutput () |
vtkStructuredGrid * | GetStructuredGridOutput () |
vtkUnstructuredGrid * | GetUnstructuredGridOutput () |
vtkRectilinearGrid * | GetRectilinearGridOutput () |
vtkTable * | GetTableOutput () |
vtkGraph * | GetGraphOutput () |
virtual int | ProcessRequest (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
