void | SetController (vtkMultiProcessController *) |
| Get/Set the MPI controller used for gathering. More...
virtual void | SetReductionMode (int) |
| Get/Set the Reduction Mode. More...
virtual int | GetReductionMode () |
virtual void | SetReductionProcessId (int) |
| Get/Set the node to reduce to, default is 0. More...
virtual int | GetReductionProcessId () |
void | SetPreGatherHelper (vtkAlgorithm *) |
| Get/Set the pre-reduction helper. More...
void | SetPreGatherHelperName (const char *) |
virtual vtkAlgorithm * | GetPreGatherHelper () |
void | SetPostGatherHelper (vtkAlgorithm *) |
| Get/Set the reduction helper. More...
void | SetPostGatherHelperName (const char *) |
virtual vtkAlgorithm * | GetPostGatherHelper () |
virtual void | SetPassThrough (int) |
| Get/Set the PassThrough flag which (when set to a nonnegative number N) tells the filter to produce results that come from node N only. More...
virtual int | GetPassThrough () |
virtual void | SetGenerateProcessIds (int) |
| When set, a new array vtkOriginalProcessIds will be added to the output of the the pre-gather helper (or input, if no pre-gather helper is set). More...
virtual int | GetGenerateProcessIds () |
vtkDataObjectAlgorithm * | NewInstance () const |
virtual void | SetOutput (vtkDataObject *d) |
virtual int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
