void | Reset () |
| To restart the incremental resample process, call this method. More...
void | UpdateResampledVolume (vtkOverlappingAMR *) |
| Updates the volume. More...
bool | NeedsInitialization () const |
| Returns true if the resampler will reinitialize the volume in the next call to UpdateResampledVolume(). More...
virtual void | SetMaxDimensions (int, int, int) |
| Get/Set the maximum number of samples along each axis. More...
virtual void | SetMaxDimensions (int [3]) |
virtual int * | GetMaxDimensions () |
virtual void | GetMaxDimensions (int &, int &, int &) |
virtual void | GetMaxDimensions (int [3]) |
virtual void | SetSpatialBounds (double, double, double, double, double, double) |
| When provided, the resampled image is set up to cover these bounds. More...
virtual void | SetSpatialBounds (double [6]) |
virtual double * | GetSpatialBounds () |
virtual void | GetSpatialBounds (double &, double &, double &, double &, double &, double &) |
virtual void | GetSpatialBounds (double [6]) |
vtkTrivialProducer * | NewInstance () const |
virtual void | SetOutput (vtkDataObject *output) |
virtual int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
virtual void | SetWholeExtent (int, int, int, int, int, int) |
virtual void | SetWholeExtent (int[6]) |
virtual int * | GetWholeExtent () |
virtual void | GetWholeExtent (int &, int &, int &, int &, int &, int &) |
virtual void | GetWholeExtent (int[6]) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
