vtkRulerSourceRepresentation is a representation to show a ruler. More...
#include <vtkRulerSourceRepresentation.h>
typedef vtkPVDataRepresentation | Superclass |
enum | { SkippedUpdateDataEvent = vtkCommand::UserEvent + 91, UpdateTimeChangedEvent } |
typedef vtkDataRepresentation | Superclass |
typedef vtkPassInputTypeAlgorithm | Superclass |
typedef vtkAlgorithm | Superclass |
enum | DesiredOutputPrecision |
void | SetTextProperty (vtkTextProperty *prop) |
Set the text property for the printed distance. More... | |
void | SetAxisLineWidth (float width) |
Set the line width for the displayed axis in screen units. More... | |
void | SetAxisColor (double red, double green, double blue) |
Set the color for the displayed axis. More... | |
void | SetVisibility (bool) override |
Set the visibility. More... | |
void | SetLabelFormat (char *labelFormat) |
Specify the format to use for labeling the distance. More... | |
void | SetNumberOfRulerTicks (int numberOfRulerTicks) |
Specify the number of major ruler ticks. More... | |
int | ProcessViewRequest (vtkInformationRequestKey *request_type, vtkInformation *inInfo, vtkInformation *outInfo) override |
vtkAlgorithm::ProcessRequest() equivalent for rendering passes. More... | |
void | SetDistanceRepresentation (vtkDistanceRepresentation2D *) |
Set the text widget. More... | |
virtual vtkDistanceRepresentation2D * | GetDistanceRepresentation () |
void | SetRulerMode (int choice) |
Enable or disable ruler mode. More... | |
int | GetRulerMode () |
void | SetRulerDistance (double distance) |
Specify the RulerDistance which indicates the spacing of the major ticks in the unit space obtained after the Scale is applied (see SetScale()). More... | |
double | GetRulerDistance () |
void | SetScale (double distance) |
Set scale factor to apply to the ruler graduation scale and the displayed distance. More... | |
double | GetScale () |
virtual void | MarkModified () |
This is one of the most important functions. More... | |
virtual unsigned int | Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) |
Initialize the representation with an identifier range so each internal representation can own a unique ID. More... | |
unsigned int | GetUniqueIdentifier () |
Return 0 if the Initialize() method was not called otherwise a unique ID that will be shared across the processes for that same object. More... | |
virtual bool | GetVisibility () |
virtual vtkDataObject * | GetRenderedDataObject (int vtkNotUsed(port)) |
Returns the data object that is rendered from the given input port. More... | |
double | GetCacheKey () const |
Returns the cache-key the representation is currently using. More... | |
vtkAlgorithmOutput * | GetInternalOutputPort () override |
Retrieves an output port for the input data object at the specified port and connection index. More... | |
vtkAlgorithmOutput * | GetInternalOutputPort (int port) override |
vtkAlgorithmOutput * | GetInternalOutputPort (int port, int conn) override |
vtkView * | GetView () const |
Provides access to the view. More... | |
vtkMTimeType | GetPipelineDataTime () |
Returns the timestamp when RequestData was executed on the representation. More... | |
bool | GetNeedsUpdate () |
Returns true if the representation needs an update. More... | |
virtual void | SetArrayIdNames (const char *vtkNotUsed(pointArray), const char *vtkNotUsed(cellArray)) |
Specify the array names used for the selection. More... | |
virtual void | SetUpdateTime (double time) |
Set the update time. More... | |
virtual double | GetUpdateTime () |
virtual bool | GetUpdateTimeValid () |
Get whether the UpdateTime is valid. More... | |
void | ResetUpdateTime () |
virtual void | SetForcedCacheKey (double val) |
Generally, caching is within the purview of the vtkPVView (and subclasses). More... | |
virtual void | SetForceUseCache (bool val) |
virtual double | GetForcedCacheKey () |
virtual bool | GetForceUseCache () |
bool | AddToView (vtkView *view) override |
Making these methods public. More... | |
bool | RemoveFromView (vtkView *view) override |
virtual void | SetLogName (const std::string &name) |
This is solely intended to simplify debugging and use for any other purpose is vehemently discouraged. More... | |
const std::string & | GetLogName () const |
virtual bool | GetHasTemporalPipeline () |
This flag indicates if the representation is for a temporal pipeline. More... | |
virtual void | SetHasTemporalPipeline (bool) |
void | SetInputConnection (int port, vtkAlgorithmOutput *input) override |
Overridden to ensure that MarkModified is called. More... | |
void | AddInputConnection (int port, vtkAlgorithmOutput *input) override |
vtkDataRepresentation * | NewInstance () const |
virtual void | ApplyViewTheme (vtkViewTheme *vtkNotUsed(theme)) |
virtual vtkSelection * | ConvertSelection (vtkView *view, vtkSelection *selection) |
vtkAlgorithmOutput * | GetInputConnection (int port=0, int index=0) |
vtkAnnotationLink * | GetAnnotationLink () |
void | SetAnnotationLink (vtkAnnotationLink *link) |
void | Select (vtkView *view, vtkSelection *selection) |
void | Select (vtkView *view, vtkSelection *selection, bool extend) |
void | Annotate (vtkView *view, vtkAnnotationLayers *annotations) |
void | Annotate (vtkView *view, vtkAnnotationLayers *annotations, bool extend) |
virtual void | SetSelectable (bool) |
virtual bool | GetSelectable () |
virtual void | SelectableOn () |
virtual void | SelectableOff () |
void | UpdateSelection (vtkSelection *selection) |
void | UpdateSelection (vtkSelection *selection, bool extend) |
void | UpdateAnnotations (vtkAnnotationLayers *annotations) |
void | UpdateAnnotations (vtkAnnotationLayers *annotations, bool extend) |
virtual vtkAlgorithmOutput * | GetInternalAnnotationOutputPort () |
virtual vtkAlgorithmOutput * | GetInternalAnnotationOutputPort (int port) |
virtual vtkAlgorithmOutput * | GetInternalAnnotationOutputPort (int port, int conn) |
virtual vtkAlgorithmOutput * | GetInternalSelectionOutputPort () |
virtual vtkAlgorithmOutput * | GetInternalSelectionOutputPort (int port) |
virtual vtkAlgorithmOutput * | GetInternalSelectionOutputPort (int port, int conn) |
virtual void | SetSelectionType (int) |
virtual int | GetSelectionType () |
virtual void | SetSelectionArrayNames (vtkStringArray *names) |
virtual vtkStringArray * | GetSelectionArrayNames () |
virtual void | SetSelectionArrayName (const char *name) |
virtual const char * | GetSelectionArrayName () |
vtkPassInputTypeAlgorithm * | NewInstance () const |
vtkPolyData * | GetPolyDataOutput () |
vtkStructuredPoints * | GetStructuredPointsOutput () |
vtkImageData * | GetImageDataOutput () |
vtkStructuredGrid * | GetStructuredGridOutput () |
vtkUnstructuredGrid * | GetUnstructuredGridOutput () |
vtkRectilinearGrid * | GetRectilinearGridOutput () |
vtkTable * | GetTableOutput () |
vtkGraph * | GetGraphOutput () |
virtual int | ProcessRequest (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
Protected Attributes | |
vtkDistanceRepresentation2D * | DistanceRepresentation |
vtkNew< vtkPolyData > | Clone |
double | UpdateTime |
bool | UpdateTimeValid |
unsigned int | UniqueIdentifier |
bool | Selectable |
int | SelectionType |
vtkStringArray * | SelectionArrayNames |
Command * | Observer |
vtkAnnotationLink * | AnnotationLinkInternal |
vtkInformation * | Information |
double | Progress |
char * | ProgressText |
vtkProgressObserver * | ProgressObserver |
unsigned long | ErrorCode |
bool | Debug |
vtkTimeStamp | MTime |
SINGLE_PRECISION | |
DOUBLE_PRECISION | |
DEFAULT_PRECISION | |
int | AbortExecute |
static vtkInformationIntegerKey * | PORT_REQUIREMENTS_FILLED () |
static vtkExecutive * | DefaultExecutivePrototype |
The input is expected to be vtkPolyData with two points.
Definition at line 22 of file vtkRulerSourceRepresentation.h.
Definition at line 26 of file vtkRulerSourceRepresentation.h.
void vtkRulerSourceRepresentation::SetDistanceRepresentation | ( | vtkDistanceRepresentation2D * | ) |
void vtkRulerSourceRepresentation::SetTextProperty | ( | vtkTextProperty * | prop | ) |
void vtkRulerSourceRepresentation::SetAxisLineWidth | ( | float | width | ) |
Set the visibility.
void vtkRulerSourceRepresentation::SetLabelFormat | ( | char * | labelFormat | ) |
Note that an empty string results in no label, or a format string without a "%" character will not print the distance value.
void vtkRulerSourceRepresentation::SetRulerMode | ( | int | choice | ) |
When enabled, the ticks on the distance widget are separated by the amount specified by vtkDistanceRepresentation::RulerDistance. Otherwise, the value vtkDistanceRepresentation::NumberOfRulerTicks is used to draw the tick marks.
int vtkRulerSourceRepresentation::GetRulerMode | ( | ) |
void vtkRulerSourceRepresentation::SetRulerDistance | ( | double | distance | ) |
This ivar only has effect when the RulerMode is on.
double vtkRulerSourceRepresentation::GetRulerDistance | ( | ) |
void vtkRulerSourceRepresentation::SetScale | ( | double | distance | ) |
Used to transform VTK world space units to a desired unit, e.g., inches to centimeters.
double vtkRulerSourceRepresentation::GetScale | ( | ) |
void vtkRulerSourceRepresentation::SetNumberOfRulerTicks | ( | int | numberOfRulerTicks | ) |
Note: the number of ticks is the number between the two handle endpoints. This ivar only has effect when the RulerMode is off.
overrideprotectedvirtual |
Overridden to invoke vtkCommand::UpdateDataEvent.
Fill input port information.
Definition at line 137 of file vtkRulerSourceRepresentation.h.
Definition at line 138 of file vtkRulerSourceRepresentation.h.
