virtual char * | GetCleanCommand () |
virtual void | SetCleanCommand (const char *) |
| The name assigned by the xml parser. More...
virtual char * | GetCommand () |
| The command name used to set the value on the server object. More...
virtual bool | GetInformationOnly () |
| Is InformationOnly is set to true, this property is used to get information from server instead of setting values. More...
virtual bool | GetRepeatable () |
| If repeatable, a property can have 1 or more values of the same kind. More...
virtual void | SetIsInternal (bool) |
| This ivar is configured when the xml file is read and is mainly useful to trigger a method call. More...
virtual bool | GetIsInternal () |
virtual void | Modified () |
