manages ParaView plugins. More...
#include <vtkSMPluginManager.h>
enum | { PluginLoadedEvent = 100000, LocalPluginLoadedEvent, RemotePluginLoadedEvent } |
bool | FulfillPluginRequirements (vtkSMSession *session, bool onlyCheck=false) |
Method to load remote plugins in order to meet plugin requirement across processes. More... | |
void | RegisterSession (vtkSMSession *) |
Register/Unregister a session. More... | |
void | UnRegisterSession (vtkSMSession *) |
virtual vtkPVPluginsInformation * | GetLocalInformation () |
vtkPVPluginsInformation provides information about plugins loaded/available. More... | |
vtkPVPluginsInformation * | GetRemoteInformation (vtkSMSession *) |
const char * | GetLocalPluginSearchPaths () |
Returns the plugin search paths used either locally or remotely. More... | |
const char * | GetRemotePluginSearchPaths (vtkSMSession *) |
bool | LoadRemotePlugin (const char *plugin, vtkSMSession *) |
Loads the plugin either locally or remotely. More... | |
bool | LoadLocalPlugin (const char *plugin) |
void | LoadPluginConfigurationXMLFromString (const char *xmlcontents, vtkSMSession *session, bool remote) |
Plugin configuration XML is a simple XML that makes ParaView aware of the plugins available and may result in loading of those plugins that are marked for auto-loading. More... | |
void | LoadPluginConfigurationXML (const char *configurationFile, vtkSMSession *session, bool remote) |
virtual void | Modified () |
static vtkSMPluginManager * | New () |
static vtkSMPluginManager * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkSMPluginManager () | |
~vtkSMPluginManager () override | |
void | OnPluginRegistered () |
void | OnPluginAvailable () |
void | UpdateLocalPluginInformation () |
bool | FulfillPluginClientServerRequirements (vtkSMSession *session, const std::map< std::string, unsigned int > &inputMap, vtkPVPluginsInformation *inputPluginInfo, const std::map< std::string, unsigned int > &outputMap, vtkPVPluginsInformation *outputPluginInfo, bool inputClient, bool onlyCheck) |
Protected method used by FulfillPluginRequirements to check and load client/server plugin requirements. More... | |
vtkSMObject () | |
~vtkSMObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
bool | InLoadPlugin |
vtkPVPluginsInformation * | LocalInformation |
bool | Debug |
vtkTimeStamp | MTime |
vtkSMPluginManager is used to load plugins as well as discover information about currently loaded and available plugins.
vtkSMPluginManager supports multiple sessions. Every vtkSMSession registers itself with the vtkSMPluginManager during initialization.
Definition at line 23 of file vtkSMPluginManager.h.
Definition at line 27 of file vtkSMPluginManager.h.
anonymous enum |
Enumerator | |
PluginLoadedEvent | |
LocalPluginLoadedEvent | |
RemotePluginLoadedEvent |
Definition at line 99 of file vtkSMPluginManager.h.
void vtkSMPluginManager::RegisterSession | ( | vtkSMSession * | ) |
Every vtkSMSession must be registered with the vtkSMPluginManager. This is done automatically by vtkSMSession during the initialization stage. Note that the vtkSMSession is not reference counted.
void vtkSMPluginManager::UnRegisterSession | ( | vtkSMSession * | ) |
LocalInformation corresponds to plugins loaded on the local process. For remote sessions i.e. those that connect to a remote server process, one can use GetRemoteInformation() to access information about plugins on the remote process.
vtkPVPluginsInformation* vtkSMPluginManager::GetRemoteInformation | ( | vtkSMSession * | ) |
const char* vtkSMPluginManager::GetLocalPluginSearchPaths | ( | ) |
For non-remote sessions, GetRemotePluginSearchPaths() returns the same value as GetLocalPluginSearchPaths().
const char* vtkSMPluginManager::GetRemotePluginSearchPaths | ( | vtkSMSession * | ) |
bool vtkSMPluginManager::LoadRemotePlugin | ( | const char * | plugin, |
vtkSMSession * | |||
plugin can either be a full path or a plugin name.
bool vtkSMPluginManager::LoadLocalPlugin | ( | const char * | plugin | ) |
void vtkSMPluginManager::LoadPluginConfigurationXMLFromString | ( | const char * | xmlcontents, |
vtkSMSession * | session, | ||
bool | remote | ||
In ParaView application there are two uses for this:
This method loads the plugin configuration xml content or file either on the local process or the remote server process(es). session
is only used when remote==true and session itself is a remote session.
void vtkSMPluginManager::LoadPluginConfigurationXML | ( | const char * | configurationFile, |
bool | remote | ||
bool vtkSMPluginManager::FulfillPluginRequirements | ( | vtkSMSession * | session, |
bool | onlyCheck = false |
This also updates the "StatusMessage" for all the plugins. If StatusMessage is empty for a loaded plugin, it implies that everything is fine. If some requirement is not met, the StatusMessage includes the error message. Set onlyCheck to true to only check and set status without loading plugins.
Definition at line 110 of file vtkSMPluginManager.h.
Definition at line 124 of file vtkSMPluginManager.h.
