vtkSelectionRepresentation is a representation to show the extracted cells. More...
#include <vtkSelectionRepresentation.h>
typedef vtkPVDataRepresentation | Superclass |
enum | { SkippedUpdateDataEvent = vtkCommand::UserEvent + 91, UpdateTimeChangedEvent } |
typedef vtkDataRepresentation | Superclass |
typedef vtkPassInputTypeAlgorithm | Superclass |
typedef vtkAlgorithm | Superclass |
enum | DesiredOutputPrecision |
int | ProcessViewRequest (vtkInformationRequestKey *request_type, vtkInformation *inInfo, vtkInformation *outInfo) override |
vtkAlgorithm::ProcessRequest() equivalent for rendering passes. More... | |
void | SetLabelRepresentation (vtkDataLabelRepresentation *) |
One must change the internal representations only before the representation is added to a view, after that it should not be touched. More... | |
void | MarkModified () override |
This needs to be called on all instances of vtkSelectionRepresentation when the input is modified. More... | |
void | SetVisibility (bool val) override |
Get/Set the visibility for this representation. More... | |
unsigned int | Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) override |
Override because of internal composite representations that need to be initialized as well. More... | |
void | SetLogName (const std::string &) override |
Overridden to pass logname to internal GeometryRepresentation. More... | |
void | SetInputConnection (int port, vtkAlgorithmOutput *input) override |
Overridden to simply pass the input to the internal representations. More... | |
void | SetInputConnection (vtkAlgorithmOutput *input) override |
void | AddInputConnection (int port, vtkAlgorithmOutput *input) override |
void | AddInputConnection (vtkAlgorithmOutput *input) override |
void | RemoveInputConnection (int port, vtkAlgorithmOutput *input) override |
void | RemoveInputConnection (int port, int idx) override |
void | SetUpdateTime (double time) override |
Passed on to internal representations as well. More... | |
void | SetForceUseCache (bool val) override |
void | SetForcedCacheKey (double val) override |
void | SetColor (double r, double g, double b) |
Forwarded to GeometryRepresentation. More... | |
void | SetLineWidth (double val) |
void | SetOpacity (double val) |
void | SetPointSize (double val) |
void | SetRepresentation (int val) |
void | SetUseOutline (int) |
void | SetRenderPointsAsSpheres (bool) |
void | SetRenderLinesAsTubes (bool) |
void | SetOrientation (double, double, double) |
Forwarded to GeometryRepresentation and LabelRepresentation. More... | |
void | SetOrigin (double, double, double) |
void | SetPosition (double, double, double) |
void | SetScale (double, double, double) |
void | SetUserTransform (const double[16]) |
virtual void | SetPointFieldDataArrayName (const char *val) |
Forwarded to vtkDataLabelRepresentation. More... | |
virtual void | SetCellFieldDataArrayName (const char *val) |
unsigned int | GetUniqueIdentifier () |
Return 0 if the Initialize() method was not called otherwise a unique ID that will be shared across the processes for that same object. More... | |
virtual bool | GetVisibility () |
virtual vtkDataObject * | GetRenderedDataObject (int vtkNotUsed(port)) |
Returns the data object that is rendered from the given input port. More... | |
double | GetCacheKey () const |
Returns the cache-key the representation is currently using. More... | |
vtkAlgorithmOutput * | GetInternalOutputPort () override |
Retrieves an output port for the input data object at the specified port and connection index. More... | |
vtkAlgorithmOutput * | GetInternalOutputPort (int port) override |
vtkAlgorithmOutput * | GetInternalOutputPort (int port, int conn) override |
vtkView * | GetView () const |
Provides access to the view. More... | |
vtkMTimeType | GetPipelineDataTime () |
Returns the timestamp when RequestData was executed on the representation. More... | |
bool | GetNeedsUpdate () |
Returns true if the representation needs an update. More... | |
virtual void | SetArrayIdNames (const char *vtkNotUsed(pointArray), const char *vtkNotUsed(cellArray)) |
Specify the array names used for the selection. More... | |
virtual double | GetUpdateTime () |
Set the update time. More... | |
virtual bool | GetUpdateTimeValid () |
Get whether the UpdateTime is valid. More... | |
void | ResetUpdateTime () |
virtual double | GetForcedCacheKey () |
Generally, caching is within the purview of the vtkPVView (and subclasses). More... | |
virtual bool | GetForceUseCache () |
bool | AddToView (vtkView *view) override |
Making these methods public. More... | |
bool | RemoveFromView (vtkView *view) override |
const std::string & | GetLogName () const |
This is solely intended to simplify debugging and use for any other purpose is vehemently discouraged. More... | |
virtual bool | GetHasTemporalPipeline () |
This flag indicates if the representation is for a temporal pipeline. More... | |
virtual void | SetHasTemporalPipeline (bool) |
vtkDataRepresentation * | NewInstance () const |
virtual void | ApplyViewTheme (vtkViewTheme *vtkNotUsed(theme)) |
virtual vtkSelection * | ConvertSelection (vtkView *view, vtkSelection *selection) |
vtkAlgorithmOutput * | GetInputConnection (int port=0, int index=0) |
vtkAnnotationLink * | GetAnnotationLink () |
void | SetAnnotationLink (vtkAnnotationLink *link) |
void | Select (vtkView *view, vtkSelection *selection) |
void | Select (vtkView *view, vtkSelection *selection, bool extend) |
void | Annotate (vtkView *view, vtkAnnotationLayers *annotations) |
void | Annotate (vtkView *view, vtkAnnotationLayers *annotations, bool extend) |
virtual void | SetSelectable (bool) |
virtual bool | GetSelectable () |
virtual void | SelectableOn () |
virtual void | SelectableOff () |
void | UpdateSelection (vtkSelection *selection) |
void | UpdateSelection (vtkSelection *selection, bool extend) |
void | UpdateAnnotations (vtkAnnotationLayers *annotations) |
void | UpdateAnnotations (vtkAnnotationLayers *annotations, bool extend) |
virtual vtkAlgorithmOutput * | GetInternalAnnotationOutputPort () |
virtual vtkAlgorithmOutput * | GetInternalAnnotationOutputPort (int port) |
virtual vtkAlgorithmOutput * | GetInternalAnnotationOutputPort (int port, int conn) |
virtual vtkAlgorithmOutput * | GetInternalSelectionOutputPort () |
virtual vtkAlgorithmOutput * | GetInternalSelectionOutputPort (int port) |
virtual vtkAlgorithmOutput * | GetInternalSelectionOutputPort (int port, int conn) |
virtual void | SetSelectionType (int) |
virtual int | GetSelectionType () |
virtual void | SetSelectionArrayNames (vtkStringArray *names) |
virtual vtkStringArray * | GetSelectionArrayNames () |
virtual void | SetSelectionArrayName (const char *name) |
virtual const char * | GetSelectionArrayName () |
vtkPassInputTypeAlgorithm * | NewInstance () const |
vtkPolyData * | GetPolyDataOutput () |
vtkStructuredPoints * | GetStructuredPointsOutput () |
vtkImageData * | GetImageDataOutput () |
vtkStructuredGrid * | GetStructuredGridOutput () |
vtkUnstructuredGrid * | GetUnstructuredGridOutput () |
vtkRectilinearGrid * | GetRectilinearGridOutput () |
vtkTable * | GetTableOutput () |
vtkGraph * | GetGraphOutput () |
virtual int | ProcessRequest (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
Protected Attributes | |
vtkGeometryRepresentation * | GeometryRepresentation |
vtkDataLabelRepresentation * | LabelRepresentation |
double | UpdateTime |
bool | UpdateTimeValid |
unsigned int | UniqueIdentifier |
bool | Selectable |
int | SelectionType |
vtkStringArray * | SelectionArrayNames |
Command * | Observer |
vtkAnnotationLink * | AnnotationLinkInternal |
vtkInformation * | Information |
double | Progress |
char * | ProgressText |
vtkProgressObserver * | ProgressObserver |
unsigned long | ErrorCode |
bool | Debug |
vtkTimeStamp | MTime |
SINGLE_PRECISION | |
DOUBLE_PRECISION | |
DEFAULT_PRECISION | |
int | AbortExecute |
static vtkInformationIntegerKey * | PORT_REQUIREMENTS_FILLED () |
static vtkExecutive * | DefaultExecutivePrototype |
It uses vtkGeometryRepresentation and vtkPVDataRepresentation internally.
Definition at line 23 of file vtkSelectionRepresentation.h.
Definition at line 27 of file vtkSelectionRepresentation.h.
vtkDataRepresentation::GetVisibility()
returns false. Reimplemented from vtkPVDataRepresentation.
void vtkSelectionRepresentation::SetLabelRepresentation | ( | vtkDataLabelRepresentation * | ) |
We won't need this if vtkPVDataRepresentation correctly respected in the arguments passed to it during ProcessRequest() etc.
This is essential since the geometry filter does not have any real-input on the client side which messes with the Update requests.
When the visibility of representation of false, all view passes are ignored. Overridden to propagate to the active representation.
void vtkSelectionRepresentation::SetLineWidth | ( | double | val | ) |
void vtkSelectionRepresentation::SetOpacity | ( | double | val | ) |
void vtkSelectionRepresentation::SetPointSize | ( | double | val | ) |
void vtkSelectionRepresentation::SetRepresentation | ( | int | val | ) |
void vtkSelectionRepresentation::SetUseOutline | ( | int | ) |
void vtkSelectionRepresentation::SetRenderPointsAsSpheres | ( | bool | ) |
void vtkSelectionRepresentation::SetRenderLinesAsTubes | ( | bool | ) |
overrideprotectedvirtual |
protectedvirtual |
Fires UpdateDataEvent.
Definition at line 146 of file vtkSelectionRepresentation.h.
Definition at line 147 of file vtkSelectionRepresentation.h.
