Serialize/deserialize vtkSelection to/from xml. More...
#include <vtkSelectionSerializer.h>
virtual void | Modified () |
static vtkSelectionSerializer * | New () |
static vtkSelectionSerializer * | SafeDownCast (vtkObject *o) |
static vtkInformationIntegerKey * | ORIGINAL_SOURCE_ID () |
ID of the dataset or algorithm that the selection belongs to. More... | |
static void | PrintXML (int printData, vtkSelection *selection) |
Serialize the selection tree to a stream as xml. More... | |
static void | PrintXML (ostream &os, vtkIndent indent, int printData, vtkSelection *selection) |
static void | Parse (const char *xml, vtkSelection *root) |
Parse an xml string to create a new selection tree. More... | |
static void | Parse (const char *xml, unsigned int length, vtkSelection *root) |
static vtkObject * | New () |
vtkSelectionSerializer () | |
~vtkSelectionSerializer () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
bool | Debug |
vtkTimeStamp | MTime |
vtkSelectionSerializer is a helper class that can serialize/deserialize vtkSelection to/from xml. Currently, it supports only a subset of properties: CONTENT_TYPE, SOURCE_ID, PROP_ID, PROCESS_ID, ORIGINAL_SOURCE_ID
Definition at line 26 of file vtkSelectionSerializer.h.
Definition at line 30 of file vtkSelectionSerializer.h.
For now, only keys of type vtkInformationIntegerKey are supported.
The string is 0 terminated for the first version of this function, or we specify the length of the string for the second version. Currently, this supports only a subset of properties: CONTENT_TYPE, SOURCE_ID, PROP_ID, PROCESS_ID
What ID means is application specific.
