virtual vtkGenericOpenGLRenderWindow * | GetWindow () |
| Returns the render window where the scene is rendered. More...
virtual vtkRenderer * | GetRenderer () |
| Returns the renderer for the simple scene. More...
void | Render () |
| Renders the scene. More...
void | ResetOSPrayPass () |
| Resets the vtkOSPRayPass of the scene. More...
void | Modified () override |
void | SetMaterialName (const char *) |
| Updates the sphere material with the given material name Default is empty. More...
const char * | GetMaterialName () const |
void | SetNumberOfSamples (int numberOfSamples) |
| Setup the number of samples to use in the Shader ball scene. More...
int | GetNumberOfSamples () const |
void | SetVisible (bool visible) |
| Set the value of visible and render the scene if value is true. More...
virtual bool | GetVisible () |
virtual void | VisibleOn () |
virtual void | VisibleOff () |
