int | FillInputPortInformation (int port, vtkInformation *info) override |
| Only one input which is the table to sort. More...
const char * | GetColumnNameToSort () |
| Choose on which column the sort operation should occur. More...
void | SetColumnNameToSort (const char *columnName) |
void | SetInvertOrder (int newValue) |
virtual int | GetInvertOrder () |
virtual vtkIdType | GetBlock () |
| Block index used to select a data range. More...
virtual void | SetBlock (vtkIdType) |
virtual vtkIdType | GetBlockSize () |
| Set the block size. More...
virtual void | SetBlockSize (vtkIdType) |
virtual int | GetSelectedComponent () |
virtual void | SetSelectedComponent (int) |
virtual void | SetShowFieldData (bool) |
| Allow user to enable/disable field data visibility. More...
virtual bool | GetShowFieldData () |
virtual void | ShowFieldDataOn () |
virtual void | ShowFieldDataOff () |
void | SetController (vtkMultiProcessController *) |
| Get/Set the MPI controller used for gathering. More...
virtual vtkMultiProcessController * | GetController () |
vtkTableAlgorithm * | NewInstance () const |
virtual int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
vtkTable * | GetOutput () |
vtkTable * | GetOutput (int index) |
void | SetInputData (vtkDataObject *obj) |
void | SetInputData (int index, vtkDataObject *obj) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
