void | PrintBlockList (vtkNonOverlappingAMR *hbds, int myProcId) |
void | SetGlobalController (vtkMultiProcessController *controller) |
| Set the controller used to coordinate parallel reading. More...
virtual int | CanReadFile (const char *fname) |
| Determine if the file can be read with this reader. More...
virtual void | SetFileName (const char *filename) |
| Get and set the file name. More...
virtual char * | GetFileName () |
virtual void | SetTimeStep (int) |
| Set and get the time step. More...
virtual int | GetTimeStep () |
virtual void | SetDistributeFiles (int) |
| If true, the reader distributes files over processors. More...
virtual int | GetDistributeFiles () |
virtual void | DistributeFilesOn () |
virtual void | DistributeFilesOff () |
virtual void | SetGenerateLevelArray (int) |
| If true, the reader generate a cell array in each block that stores the level in the hierarchy, starting from 0. More...
virtual int | GetGenerateLevelArray () |
virtual void | GenerateLevelArrayOn () |
virtual void | GenerateLevelArrayOff () |
virtual void | SetGenerateBlockIdArray (int) |
| If true, the reader generate a cell array in each block that stores a unique but not necessarily contiguous id. More...
virtual int | GetGenerateBlockIdArray () |
virtual void | GenerateBlockIdArrayOn () |
virtual void | GenerateBlockIdArrayOff () |
virtual void | SetGenerateActiveBlockArray (int) |
| If true, the reader generate a cell array in each block that corresponds to the Active field in the file. More...
virtual int | GetGenerateActiveBlockArray () |
virtual void | GenerateActiveBlockArrayOn () |
virtual void | GenerateActiveBlockArrayOff () |
virtual void | SetGenerateTracerArray (int) |
| If true, the reader will extract tracer data at each time step and include a field data array for the tracers at that time. More...
virtual int | GetGenerateTracerArray () |
virtual void | GenerateTracerArrayOn () |
virtual void | GenerateTracerArrayOff () |
void | SetGenerateMarkers (int gm) |
| if true, the reader will extract the marker data at each time step and create a set of vtkPoints in the second output port. More...
virtual int | GetGenerateMarkers () |
virtual void | GenerateMarkersOn () |
virtual void | GenerateMarkersOff () |
void | SetDownConvertVolumeFraction (int vf) |
| If true, the reader will convert volume fraction arrays to unsigned char. More...
virtual int | GetDownConvertVolumeFraction () |
virtual void | DownConvertVolumeFractionOn () |
virtual void | DownConvertVolumeFractionOff () |
virtual void | SetComputeDerivedVariables (int) |
| If true, the reader will calculate all derived variables it can given which properties the user has selected True by default. More...
virtual int | GetComputeDerivedVariables () |
virtual void | ComputeDerivedVariablesOn () |
virtual void | ComputeDerivedVariablesOff () |
void | SetMergeXYZComponents (int merge) |
| If true, the reader will merge scalar arrays named, for example, "X velocity" "Y velocity" and "Z velocity" into a vector array named "velocity" with scalar components X, Y and Z. More...
virtual int | GetMergeXYZComponents () |
virtual void | MergeXYZComponentsOn () |
virtual void | MergeXYZComponentsOff () |
virtual int * | GetTimeStepRange () |
| Get the time step range. More...
virtual void | GetTimeStepRange (int &, int &) |
virtual void | GetTimeStepRange (int [2]) |
int | GetNumberOfCellArrays () |
| Cell array selection. More...
const char * | GetCellArrayName (int idx) |
int | GetCellArrayStatus (const char *name) |
void | SetCellArrayStatus (const char *name, int status) |
vtkCompositeDataSetAlgorithm * | NewInstance () const |
vtkCompositeDataSet * | GetOutput () |
vtkCompositeDataSet * | GetOutput (int) |
virtual int | ProcessRequest (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
