Image compressor/decompressor using SQUIRT. More...
#include <vtkSquirtCompressor.h>
typedef vtkImageCompressor | Superclass |
const char * | SaveConfiguration () override |
Serialize compressor configuration (but not the data) into the stream. More... | |
const char * | RestoreConfiguration (const char *stream) override |
Restore state from the stream, The stream format for all image compressor is: [ClassName, LossLessMode, [Derived Class Stream]]. More... | |
virtual void | SetSquirtLevel (int) |
Set Squirt compression level. More... | |
virtual int | GetSquirtLevel () |
int | Compress () override |
Compress/Decompress data array on the objects input with results in the objects output. More... | |
int | Decompress () override |
void | SaveConfiguration (vtkMultiProcessStream *stream) override |
Serialize/Restore compressor configuration (but not the data) into the stream. More... | |
bool | RestoreConfiguration (vtkMultiProcessStream *stream) override |
virtual void | SetImageResolution (int width, int height) |
Communicates the next expected image resolution. More... | |
void | SetInput (vtkUnsignedCharArray *input) |
Get/Set the input to this compressor. More... | |
virtual vtkUnsignedCharArray * | GetInput () |
virtual vtkUnsignedCharArray * | GetOutput () |
Get/Set the output of the compressor. More... | |
void | SetOutput (vtkUnsignedCharArray *) |
virtual void | SetLossLessMode (int) |
When set the implementation must use loss-less compression, otherwise implemnetation should user provided settings. More... | |
virtual int | GetLossLessMode () |
virtual void | Modified () |
static vtkSquirtCompressor * | New () |
static vtkSquirtCompressor * | SafeDownCast (vtkObject *o) |
static vtkImageCompressor * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkSquirtCompressor () | |
~vtkSquirtCompressor () override | |
int | DecompressRGB () |
int | DecompressRGBA () |
virtual void | SetConfiguration (const char *) |
vtkImageCompressor () | |
Construct with nullptr input array and empty but allocated output array. More... | |
~vtkImageCompressor () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
int | SquirtLevel |
vtkUnsignedCharArray * | Output |
vtkUnsignedCharArray * | Input |
int | LossLessMode |
char * | Configuration |
bool | Debug |
vtkTimeStamp | MTime |
This class compresses Image data using SQUIRT a Run-Length-Encoded compression scheme. The Squirt Level controls the compression. 0 is lossless compression, 1 through 5 are lossy compression levels with 5 being maximum compression.
Squirt produces smaller compression ratio than some other popular compression algorithm. However, Squirt has a relatively high throughput compared to some other compression algorithm. Squirt's performance is optimized for RGBa images, however the class can also work with RGB images. There is no performance hit when applying the lossy comrpession levels.
Levels 1 through 5 apply a color reducing mask to the run computation, not to the pixel directly. This is clever in that no new colors are introduced to the image, and as a result one doesn't see drastic changes between the reduced color image and the original. However, when using the higher levels one may get runs that produce visual artifiacts. For example when a run starts in one actor whose reduced color matches the background the background is colored with the actor color.
The compressor uses a modified SQUIRT implementation where encode 4-bit opacity information as well. This is needed to improve background color blending for translucent renderings in ParaView.
Definition at line 44 of file vtkSquirtCompressor.h.
Definition at line 48 of file vtkSquirtCompressor.h.
Reimplemented from vtkImageCompressor.
Level 0 is lossless compression, 1 through 5 are lossy compression levels with 5 being maximum compression.
See also Set/GetInput/Output.
Implements vtkImageCompressor.
A pointer to the internally managed stream is returned (ie do not free it!).
Upon success the stream is returned otherwise 0 is returned indicating an error.
Definition at line 87 of file vtkSquirtCompressor.h.
