int | Write () |
| Write the string to the file. More...
| vtkSetStdStringFromCharMacro (String) |
| Specify the string to write. More...
| vtkGetCharFromStdStringMacro (String) |
| vtkSetStdStringFromCharMacro (FileName) |
| Specify the file name to write to. More...
| vtkGetCharFromStdStringMacro (FileName) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
