vtkMTimeType | GetMTime () override |
| Override GetMTime because we rely on internal filters that have their own MTime. More...
void | SetCutNormal (int cutIndex, double normal[3]) |
| Set a Slice Normal for a given cutter. More...
void | SetCutOrigin (int cutIndex, double origin[3]) |
| Set a slice Origin for a given cutter. More...
void | SetCutValue (int cutIndex, int index, double value) |
| Set a slice value for a given cutter. More...
void | SetNumberOfSlice (int cutIndex, int size) |
| Set number of slices for a given cutter. More...
void | SetToDefaultSettings () |
| Default settings: More...
void | SetCutOrigins (double origin[3]) |
| Set slice Origin for all cutter. More...
void | SetCutOrigins (double x, double y, double z) |
void | EnableProbe (int enable) |
| Enable to probe the dataset at the given cut origin. More...
bool | GetProbedPointData (const char *arrayName, double &value) |
| Return true if any data is available and provide the value as argument. More...
vtkPolyDataAlgorithm * | NewInstance () const |
vtkPolyData * | GetPolyDataInput (int port) |
vtkPolyData * | GetOutput () |
vtkPolyData * | GetOutput (int) |
virtual void | SetOutput (vtkDataObject *d) |
virtual int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
