int | GetNumberOfAttributes () |
| Get the number of distinct attribute values present in the file. More...
const char * | GetAttributeName (int attribute) |
| Get the name of an attribute. More...
int | GetAttributeIndex (const char *name) |
| Get the index of the attribute with the given name. More...
int | GetNumberOfAttributeValues (int attribute) |
| Get the number of distinct values for the given attribute. More...
vtkXMLDataElement * | GetOutputXMLDataElement (int index) |
| Get the vtkXMLDataElement representing the collection element corresponding to the output with the given index. More...
virtual void | SetRestriction (const char *name, const char *value) |
| Get/Set the required value for a particular named attribute. More...
virtual const char * | GetRestriction (const char *name) |
virtual void | SetRestrictionAsIndex (const char *name, int index) |
| Get/set the required value for a particular named attribute. More...
virtual int | GetRestrictionAsIndex (const char *name) |
const char * | GetAttributeValue (int attribute, int index) |
| Get one of the possible values for a given attribute. More...
const char * | GetAttributeValue (const char *name, int index) |
int | GetAttributeValueIndex (int attribute, const char *value) |
| Get the index of the attribute value with the given name. More...
int | GetAttributeValueIndex (const char *name, const char *value) |
virtual void | SetForceOutputTypeToMultiBlock (int) |
| If ForceOutputTypeToMultiBlock is set to 1, the output of this reader will always be a multi-block dataset, even if there is 1 simple output. More...
virtual int | GetForceOutputTypeToMultiBlock () |
virtual void | ForceOutputTypeToMultiBlockOn () |
virtual void | ForceOutputTypeToMultiBlockOff () |
vtkXMLReader * | NewInstance () const |
virtual int | CanReadFile (const char *name) |
virtual void | CopyOutputInformation (vtkInformation *vtkNotUsed(outInfo), int vtkNotUsed(port)) |
virtual int | GetNumberOfTimeSteps () |
virtual int | ProcessRequest (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) |
virtual void | SetFileName (const char *) |
virtual char * | GetFileName () |
virtual void | SetReadFromInputString (int) |
virtual int | GetReadFromInputString () |
virtual void | ReadFromInputStringOn () |
virtual void | ReadFromInputStringOff () |
void | SetInputString (std::string s) |
vtkDataSet * | GetOutputAsDataSet () |
vtkDataSet * | GetOutputAsDataSet (int index) |
virtual vtkDataArraySelection * | GetPointDataArraySelection () |
virtual vtkDataArraySelection * | GetCellDataArraySelection () |
int | GetNumberOfPointArrays () |
int | GetNumberOfCellArrays () |
const char * | GetPointArrayName (int index) |
const char * | GetCellArrayName (int index) |
int | GetPointArrayStatus (const char *name) |
int | GetCellArrayStatus (const char *name) |
void | SetPointArrayStatus (const char *name, int status) |
void | SetCellArrayStatus (const char *name, int status) |
virtual void | SetTimeStep (int) |
virtual int | GetTimeStep () |
virtual int * | GetTimeStepRange () |
virtual void | GetTimeStepRange (int &, int &) |
virtual void | GetTimeStepRange (int[2]) |
virtual void | SetTimeStepRange (int, int) |
void | SetTimeStepRange (int[2]) |
vtkXMLDataParser * | GetXMLParser () |
void | SetReaderErrorObserver (vtkCommand *) |
virtual vtkCommand * | GetReaderErrorObserver () |
void | SetParserErrorObserver (vtkCommand *) |
virtual vtkCommand * | GetParserErrorObserver () |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
