void | Start () |
| Start a new animation with the current set of inputs. More...
void | WriteTime (double time) |
| Write the current time step. More...
void | Finish () |
| Finish an animation by writing the collection file. More...
void | AddRepresentation (vtkAlgorithm *, const char *groupname) |
| Add/Remove representations. More...
void | RemoveAllRepresentations () |
const char * | GetDefaultFileExtension () override |
| Get the default file extension for files written by this writer. More...
| Add an input of this algorithm. More...
int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
virtual int | GetPiece () |
| Get/Set the piece number to write. More...
virtual void | SetPiece (int) |
virtual int | GetNumberOfPieces () |
| Get/Set the number of pieces into which the inputs are split. More...
virtual void | SetNumberOfPieces (int) |
virtual int | GetGhostLevel () |
| Get/Set the number of ghost levels to be written for unstructured data. More...
virtual void | SetGhostLevel (int) |
virtual void | SetWriteAllTimeSteps (int) |
| When WriteAllTimeSteps is turned ON, the writer is executed once for each timestep available from its input. More...
virtual int | GetWriteAllTimeSteps () |
virtual void | WriteAllTimeStepsOn () |
virtual void | WriteAllTimeStepsOff () |
virtual int | GetWriteCollectionFile () |
| Get/Set whether this instance will write the main collection file. More...
virtual void | SetWriteCollectionFile (int flag) |
vtkXMLWriter * | NewInstance () const |
int | Write () |
virtual void | SetByteOrder (int) |
virtual int | GetByteOrder () |
void | SetByteOrderToBigEndian () |
void | SetByteOrderToLittleEndian () |
virtual void | SetHeaderType (int) |
virtual int | GetHeaderType () |
void | SetHeaderTypeToUInt32 () |
void | SetHeaderTypeToUInt64 () |
virtual void | SetIdType (int) |
virtual int | GetIdType () |
void | SetIdTypeToInt32 () |
void | SetIdTypeToInt64 () |
virtual void | SetFileName (const char *) |
virtual char * | GetFileName () |
virtual void | SetWriteToOutputString (int) |
virtual int | GetWriteToOutputString () |
virtual void | WriteToOutputStringOn () |
virtual void | WriteToOutputStringOff () |
std::string | GetOutputString () |
virtual void | SetCompressor (vtkDataCompressor *) |
virtual vtkDataCompressor * | GetCompressor () |
void | SetCompressorType (int compressorType) |
void | SetCompressorTypeToNone () |
void | SetCompressorTypeToZLib () |
virtual void | SetBlockSize (size_t blockSize) |
virtual size_t | GetBlockSize () |
virtual void | SetDataMode (int) |
virtual int | GetDataMode () |
void | SetDataModeToAscii () |
void | SetDataModeToBinary () |
void | SetDataModeToAppended () |
virtual void | SetEncodeAppendedData (int) |
virtual int | GetEncodeAppendedData () |
virtual void | EncodeAppendedDataOn () |
virtual void | EncodeAppendedDataOff () |
virtual int | GetNumberOfTimeSteps () |
virtual void | SetNumberOfTimeSteps (int) |
void | Start () |
void | Stop () |
void | WriteNextTime (double time) |
void | Start () |
void | Stop () |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
