pqProxyCategory.h
3 #ifndef pqProxyCategory_h
4 #define pqProxyCategory_h
5
7
8 #include "pqProxyInfo.h" // for pqProxyInfoMap
9 #include <QMap> // for QMap
10 #include <QString> // for QString
11
12 class vtkPVXMLElement;
13
61 {
62  Q_OBJECT
63  typedef QObject Superclass;
64
65 public:
66  pqProxyCategory(pqProxyCategory* parent = nullptr);
67  pqProxyCategory(pqProxyCategory* parent, const QString& name, const QString& label);
68  ~pqProxyCategory() override;
69
73  bool parseXML(vtkPVXMLElement* root);
77  void convertToXML(vtkPVXMLElement* root) { this->convertToXML(this, root); }
92  bool parseXMLHintsTag(
93  const QString& proxyGroup, const QString& proxyName, vtkPVXMLElement* hints);
95  static void convertLegacyXML(vtkPVXMLElement* root);
97
101  void writeSettings(const QString& resourceTag);
105  void loadSettings(const QString& resourceTag);
107
111
116  void copyAttributes(pqProxyCategory* other);
120  void deepCopy(pqProxyCategory* other);
122
126  bool hasProxy(const QString& name);
131  pqProxyInfo* findProxy(const QString& name, bool recursive = false);
133  QList<pqProxyInfo*> getRootProxies();
135  QList<pqProxyInfo*> getProxiesRecursive();
137  QStringList getOrderedRootProxiesNames();
139
143  pqProxyCategory* findSubCategory(const QString& name);
147  QMap<QString, pqProxyCategory*> getSubCategories();
149  QMap<QString, pqProxyCategory*> getSubCategoriesRecursive();
151  QList<pqProxyCategory*> getCategoriesAlphabetically();
153  QString makeUniqueCategoryName(const QString& name);
155  QString makeUniqueCategoryLabel(const QString& label);
157
161  void addCategory(pqProxyCategory* category);
165  void removeCategory(const QString& name);
167  void addProxy(pqProxyInfo* info);
169  void removeProxy(const QString& name);
171  void clear();
173
177  bool hasProxiesRecursive();
181  pqProxyCategory* parentCategory() { return dynamic_cast<pqProxyCategory*>(this->parent()); }
183  bool isEmpty();
185  QString name() { return this->Name; }
187  QString label();
189  bool preserveOrder() { return this->PreserveOrder; }
191  bool showInToolbar() { return this->ShowInToolbar; }
193
197  void rename(const QString& name);
201  void updateLabel(const QString& label = "");
203  void setShowInToolbar(bool show);
205
206 protected:
211  pqProxyCategory* addCategory(const QString& name, vtkPVXMLElement* node);
212
213 protected Q_SLOTS: // NOLINT(readability-redundant-access-specifiers)
214
215  void cleanDeletedProxy(QObject* deleted);
216
217 private:
221  bool parseXML(pqProxyCategory* categoryRoot, vtkPVXMLElement* root);
222
226  void convertToXML(pqProxyCategory* parent, vtkPVXMLElement* root);
227
228  QString Name;
229  QString Label;
230
231  bool PreserveOrder = false;
232  bool ShowInToolbar = false;
233
234  pqProxyInfoMap Proxies;
235  QMap<QString, pqProxyCategory*> SubCategories;
236  QStringList OrderedProxies;
237 };
238
240 using pqCategoryMap = QMap<QString, pqProxyCategory*>;
241
242 #endif
QMap< QString, pqProxyInfo * > pqProxyInfoMap
map a proxy name to its pqProxyInfo
Definition: pqProxyInfo.h:100
info
pqProxyCategory * parentCategory()
Return parent category.
QMap< QString, pqProxyCategory * > pqCategoryMap
map a category name to its pqProxyCategory
#define PQAPPLICATIONCOMPONENTS_EXPORT
Proxy meta data structure for the User Interface.
Definition: pqProxyInfo.h:20
QString name()
Return category name.
Return true if a toolbar should be created.
name
Return true if read order should be used in display.
void convertToXML(vtkPVXMLElement *root)
Add Proxies and SubCategories XML declaration to root element.
The pqProxyCategory class reads and writes XML that describes the proxies organisation into categorie...
