Public Attributes | List of all members
NC_Dispatch Struct Reference
#include <netcdf_dispatch.h>
Public Attributes
int model
int dispatch_version
int(* create )(const char *path, int cmode, size_t initialsz, int basepe, size_t *chunksizehintp, void *parameters, const struct NC_Dispatch *table, int ncid)
int(* open )(const char *path, int mode, int basepe, size_t *chunksizehintp, void *parameters, const struct NC_Dispatch *table, int ncid)
int(* redef )(int)
int(* _enddef )(int, size_t, size_t, size_t, size_t)
int(* sync )(int)
int(* abort )(int)
int(* close )(int, void *)
int(* set_fill )(int, int, int *)
int(* inq_format )(int, int *)
int(* inq_format_extended )(int, int *, int *)
int(* inq )(int, int *, int *, int *, int *)
int(* inq_type )(int, nc_type, char *, size_t *)
int(* def_dim )(int, const char *, size_t, int *)
int(* inq_dimid )(int, const char *, int *)
int(* inq_dim )(int, int, char *, size_t *)
int(* inq_unlimdim )(int ncid, int *unlimdimidp)
int(* rename_dim )(int, int, const char *)
int(* inq_att )(int, int, const char *, nc_type *, size_t *)
int(* inq_attid )(int, int, const char *, int *)
int(* inq_attname )(int, int, int, char *)
int(* rename_att )(int, int, const char *, const char *)
int(* del_att )(int, int, const char *)
int(* get_att )(int, int, const char *, void *, nc_type)
int(* put_att )(int, int, const char *, nc_type, size_t, const void *, nc_type)
int(* def_var )(int, const char *, nc_type, int, const int *, int *)
int(* inq_varid )(int, const char *, int *)
int(* rename_var )(int, int, const char *)
int(* get_vara )(int, int, const size_t *, const size_t *, void *, nc_type)
int(* put_vara )(int, int, const size_t *, const size_t *, const void *, nc_type)
int(* get_vars )(int, int, const size_t *, const size_t *, const ptrdiff_t *, void *, nc_type)
int(* put_vars )(int, int, const size_t *, const size_t *, const ptrdiff_t *, const void *, nc_type)
int(* get_varm )(int, int, const size_t *, const size_t *, const ptrdiff_t *, const ptrdiff_t *, void *, nc_type)
int(* put_varm )(int, int, const size_t *, const size_t *, const ptrdiff_t *, const ptrdiff_t *, const void *, nc_type)
int(* inq_var_all )(int ncid, int varid, char *name, nc_type *xtypep, int *ndimsp, int *dimidsp, int *nattsp, int *shufflep, int *deflatep, int *deflate_levelp, int *fletcher32p, int *contiguousp, size_t *chunksizesp, int *no_fill, void *fill_valuep, int *endiannessp, unsigned int *idp, size_t *nparamsp, unsigned int *params)
int(* var_par_access )(int, int, int)
int(* def_var_fill )(int, int, int, const void *)
int(* show_metadata )(int)
int(* inq_unlimdims )(int, int *, int *)
int(* inq_ncid )(int, const char *, int *)
int(* inq_grps )(int, int *, int *)
int(* inq_grpname )(int, char *)
int(* inq_grpname_full )(int, size_t *, char *)
int(* inq_grp_parent )(int, int *)
int(* inq_grp_full_ncid )(int, const char *, int *)
int(* inq_varids )(int, int *nvars, int *)
int(* inq_dimids )(int, int *ndims, int *, int)
int(* inq_typeids )(int, int *ntypes, int *)
int(* inq_type_equal )(int, nc_type, int, nc_type, int *)
int(* def_grp )(int, const char *, int *)
int(* rename_grp )(int, const char *)
int(* inq_user_type )(int, nc_type, char *, size_t *, nc_type *, size_t *, int *)
int(* inq_typeid )(int, const char *, nc_type *)
int(* def_compound )(int, size_t, const char *, nc_type *)
int(* insert_compound )(int, nc_type, const char *, size_t, nc_type)
int(* insert_array_compound )(int, nc_type, const char *, size_t, nc_type, int, const int *)
int(* inq_compound_field )(int, nc_type, int, char *, size_t *, nc_type *, int *, int *)
int(* inq_compound_fieldindex )(int, nc_type, const char *, int *)
int(* def_vlen )(int, const char *, nc_type base_typeid, nc_type *)
int(* put_vlen_element )(int, int, void *, size_t, const void *)
int(* get_vlen_element )(int, int, const void *, size_t *, void *)
int(* def_enum )(int, nc_type, const char *, nc_type *)
int(* insert_enum )(int, nc_type, const char *, const void *)
int(* inq_enum_member )(int, nc_type, int, char *, void *)
int(* inq_enum_ident )(int, nc_type, long long, char *)
int(* def_opaque )(int, size_t, const char *, nc_type *)
int(* def_var_deflate )(int, int, int, int, int)
int(* def_var_fletcher32 )(int, int, int)
int(* def_var_chunking )(int, int, int, const size_t *)
int(* def_var_endian )(int, int, int)
int(* def_var_filter )(int, int, unsigned int, size_t, const unsigned int *)
int(* set_var_chunk_cache )(int, int, size_t, size_t, float)
int(* get_var_chunk_cache )(int ncid, int varid, size_t *sizep, size_t *nelemsp, float *preemptionp)
int(* inq_var_filter_ids )(int ncid, int varid, size_t *nfilters, unsigned int *filterids)
int(* inq_var_filter_info )(int ncid, int varid, unsigned int id, size_t *nparams, unsigned int *params)
int(* def_var_quantize )(int ncid, int varid, int quantize_mode, int nsd)
int(* inq_var_quantize )(int ncid, int varid, int *quantize_modep, int *nsdp)
int(* inq_filter_avail )(int ncid, unsigned id)
Definition at line 34 of file netcdf_dispatch.h.
◆ model
int NC_Dispatch::model
Definition at line 36 of file netcdf_dispatch.h.
◆ dispatch_version
int NC_Dispatch::dispatch_version
Definition at line 37 of file netcdf_dispatch.h.
◆ create
int(* NC_Dispatch::create) (const char *path, int cmode, size_t initialsz, int basepe, size_t *chunksizehintp, void *parameters, const struct NC_Dispatch *table, int ncid)
Definition at line 39 of file netcdf_dispatch.h.
◆ open
int(* NC_Dispatch::open) (const char *path, int mode, int basepe, size_t *chunksizehintp, void *parameters, const struct NC_Dispatch *table, int ncid)
Definition at line 42 of file netcdf_dispatch.h.
◆ redef
int(* NC_Dispatch::redef) (int)
Definition at line 45 of file netcdf_dispatch.h.
◆ _enddef
int(* NC_Dispatch::_enddef) (int, size_t, size_t, size_t, size_t)
Definition at line 46 of file netcdf_dispatch.h.
◆ sync
int(* NC_Dispatch::sync) (int)
Definition at line 47 of file netcdf_dispatch.h.
◆ abort
int(* NC_Dispatch::abort) (int)
Definition at line 48 of file netcdf_dispatch.h.
◆ close
int(* NC_Dispatch::close) (int, void *)
Definition at line 49 of file netcdf_dispatch.h.
◆ set_fill
int(* NC_Dispatch::set_fill) (int, int, int *)
Definition at line 50 of file netcdf_dispatch.h.
◆ inq_format
int(* NC_Dispatch::inq_format) (int, int *)
Definition at line 51 of file netcdf_dispatch.h.
◆ inq_format_extended
int(* NC_Dispatch::inq_format_extended) (int, int *, int *)
Definition at line 52 of file netcdf_dispatch.h.
◆ inq
int(* NC_Dispatch::inq) (int, int *, int *, int *, int *)
Definition at line 54 of file netcdf_dispatch.h.
◆ inq_type
int(* NC_Dispatch::inq_type) (int, nc_type, char *, size_t *)
Definition at line 55 of file netcdf_dispatch.h.
◆ def_dim
int(* NC_Dispatch::def_dim) (int, const char *, size_t, int *)
Definition at line 57 of file netcdf_dispatch.h.
◆ inq_dimid
int(* NC_Dispatch::inq_dimid) (int, const char *, int *)
Definition at line 58 of file netcdf_dispatch.h.
◆ inq_dim
int(* NC_Dispatch::inq_dim) (int, int, char *, size_t *)
Definition at line 59 of file netcdf_dispatch.h.
◆ inq_unlimdim
int(* NC_Dispatch::inq_unlimdim) (int ncid, int *unlimdimidp)
Definition at line 60 of file netcdf_dispatch.h.
◆ rename_dim
int(* NC_Dispatch::rename_dim) (int, int, const char *)
Definition at line 61 of file netcdf_dispatch.h.
◆ inq_att
int(* NC_Dispatch::inq_att) (int, int, const char *, nc_type *, size_t *)
Definition at line 63 of file netcdf_dispatch.h.
◆ inq_attid
int(* NC_Dispatch::inq_attid) (int, int, const char *, int *)
Definition at line 64 of file netcdf_dispatch.h.
◆ inq_attname
int(* NC_Dispatch::inq_attname) (int, int, int, char *)
Definition at line 65 of file netcdf_dispatch.h.
◆ rename_att
int(* NC_Dispatch::rename_att) (int, int, const char *, const char *)
Definition at line 66 of file netcdf_dispatch.h.
◆ del_att
int(* NC_Dispatch::del_att) (int, int, const char *)
Definition at line 67 of file netcdf_dispatch.h.
◆ get_att
int(* NC_Dispatch::get_att) (int, int, const char *, void *, nc_type)
Definition at line 68 of file netcdf_dispatch.h.
◆ put_att
int(* NC_Dispatch::put_att) (int, int, const char *, nc_type, size_t, const void *, nc_type)
Definition at line 69 of file netcdf_dispatch.h.
◆ def_var
int(* NC_Dispatch::def_var) (int, const char *, nc_type, int, const int *, int *)
Definition at line 72 of file netcdf_dispatch.h.
◆ inq_varid
int(* NC_Dispatch::inq_varid) (int, const char *, int *)
Definition at line 73 of file netcdf_dispatch.h.
◆ rename_var
int(* NC_Dispatch::rename_var) (int, int, const char *)
Definition at line 74 of file netcdf_dispatch.h.
◆ get_vara
int(* NC_Dispatch::get_vara) (int, int, const size_t *, const size_t *, void *, nc_type)
Definition at line 76 of file netcdf_dispatch.h.
◆ put_vara
int(* NC_Dispatch::put_vara) (int, int, const size_t *, const size_t *, const void *, nc_type)
Definition at line 77 of file netcdf_dispatch.h.
◆ get_vars
int(* NC_Dispatch::get_vars) (int, int, const size_t *, const size_t *, const ptrdiff_t *, void *, nc_type)
Definition at line 80 of file netcdf_dispatch.h.
◆ put_vars
int(* NC_Dispatch::put_vars) (int, int, const size_t *, const size_t *, const ptrdiff_t *, const void *, nc_type)
Definition at line 82 of file netcdf_dispatch.h.
◆ get_varm
int(* NC_Dispatch::get_varm) (int, int, const size_t *, const size_t *, const ptrdiff_t *, const ptrdiff_t *, void *, nc_type)
Definition at line 85 of file netcdf_dispatch.h.
◆ put_varm
int(* NC_Dispatch::put_varm) (int, int, const size_t *, const size_t *, const ptrdiff_t *, const ptrdiff_t *, const void *, nc_type)
Definition at line 87 of file netcdf_dispatch.h.
◆ inq_var_all
int(* NC_Dispatch::inq_var_all) (int ncid, int varid, char *name, nc_type *xtypep, int *ndimsp, int *dimidsp, int *nattsp, int *shufflep, int *deflatep, int *deflate_levelp, int *fletcher32p, int *contiguousp, size_t *chunksizesp, int *no_fill, void *fill_valuep, int *endiannessp, unsigned int *idp, size_t *nparamsp, unsigned int *params)
Definition at line 90 of file netcdf_dispatch.h.
◆ var_par_access
int(* NC_Dispatch::var_par_access) (int, int, int)
Definition at line 98 of file netcdf_dispatch.h.
◆ def_var_fill
int(* NC_Dispatch::def_var_fill) (int, int, int, const void *)
Definition at line 99 of file netcdf_dispatch.h.
◆ show_metadata
int(* NC_Dispatch::show_metadata) (int)
Definition at line 107 of file netcdf_dispatch.h.
◆ inq_unlimdims
int(* NC_Dispatch::inq_unlimdims) (int, int *, int *)
Definition at line 108 of file netcdf_dispatch.h.
◆ inq_ncid
int(* NC_Dispatch::inq_ncid) (int, const char *, int *)
Definition at line 109 of file netcdf_dispatch.h.
◆ inq_grps
int(* NC_Dispatch::inq_grps) (int, int *, int *)
Definition at line 110 of file netcdf_dispatch.h.
◆ inq_grpname
int(* NC_Dispatch::inq_grpname) (int, char *)
Definition at line 111 of file netcdf_dispatch.h.
◆ inq_grpname_full
int(* NC_Dispatch::inq_grpname_full) (int, size_t *, char *)
Definition at line 112 of file netcdf_dispatch.h.
◆ inq_grp_parent
int(* NC_Dispatch::inq_grp_parent) (int, int *)
Definition at line 113 of file netcdf_dispatch.h.
◆ inq_grp_full_ncid
int(* NC_Dispatch::inq_grp_full_ncid) (int, const char *, int *)
Definition at line 114 of file netcdf_dispatch.h.
◆ inq_varids
int(* NC_Dispatch::inq_varids) (int, int *nvars, int *)
Definition at line 115 of file netcdf_dispatch.h.
◆ inq_dimids
int(* NC_Dispatch::inq_dimids) (int, int *ndims, int *, int)
Definition at line 116 of file netcdf_dispatch.h.
◆ inq_typeids
int(* NC_Dispatch::inq_typeids) (int, int *ntypes, int *)
Definition at line 117 of file netcdf_dispatch.h.
◆ inq_type_equal
int(* NC_Dispatch::inq_type_equal) (int, nc_type, int, nc_type, int *)
Definition at line 118 of file netcdf_dispatch.h.
◆ def_grp
int(* NC_Dispatch::def_grp) (int, const char *, int *)
Definition at line 119 of file netcdf_dispatch.h.
◆ rename_grp
int(* NC_Dispatch::rename_grp) (int, const char *)
Definition at line 120 of file netcdf_dispatch.h.
◆ inq_user_type
int(* NC_Dispatch::inq_user_type) (int, nc_type, char *, size_t *, nc_type *, size_t *, int *)
Definition at line 121 of file netcdf_dispatch.h.
◆ inq_typeid
int(* NC_Dispatch::inq_typeid) (int, const char *, nc_type *)
Definition at line 122 of file netcdf_dispatch.h.
◆ def_compound
int(* NC_Dispatch::def_compound) (int, size_t, const char *, nc_type *)
Definition at line 124 of file netcdf_dispatch.h.
◆ insert_compound
int(* NC_Dispatch::insert_compound) (int, nc_type, const char *, size_t, nc_type)
Definition at line 125 of file netcdf_dispatch.h.
◆ insert_array_compound
int(* NC_Dispatch::insert_array_compound) (int, nc_type, const char *, size_t, nc_type, int, const int *)
Definition at line 126 of file netcdf_dispatch.h.
◆ inq_compound_field
int(* NC_Dispatch::inq_compound_field) (int, nc_type, int, char *, size_t *, nc_type *, int *, int *)
Definition at line 128 of file netcdf_dispatch.h.
◆ inq_compound_fieldindex
int(* NC_Dispatch::inq_compound_fieldindex) (int, nc_type, const char *, int *)
Definition at line 130 of file netcdf_dispatch.h.
◆ def_vlen
int(* NC_Dispatch::def_vlen) (int, const char *, nc_type base_typeid, nc_type *)
Definition at line 131 of file netcdf_dispatch.h.
◆ put_vlen_element
int(* NC_Dispatch::put_vlen_element) (int, int, void *, size_t, const void *)
Definition at line 132 of file netcdf_dispatch.h.
◆ get_vlen_element
int(* NC_Dispatch::get_vlen_element) (int, int, const void *, size_t *, void *)
Definition at line 133 of file netcdf_dispatch.h.
◆ def_enum
int(* NC_Dispatch::def_enum) (int, nc_type, const char *, nc_type *)
Definition at line 134 of file netcdf_dispatch.h.
◆ insert_enum
int(* NC_Dispatch::insert_enum) (int, nc_type, const char *, const void *)
Definition at line 135 of file netcdf_dispatch.h.
◆ inq_enum_member
int(* NC_Dispatch::inq_enum_member) (int, nc_type, int, char *, void *)
Definition at line 136 of file netcdf_dispatch.h.
◆ inq_enum_ident
int(* NC_Dispatch::inq_enum_ident) (int, nc_type, long long, char *)
Definition at line 137 of file netcdf_dispatch.h.
◆ def_opaque
int(* NC_Dispatch::def_opaque) (int, size_t, const char *, nc_type *)
Definition at line 138 of file netcdf_dispatch.h.
◆ def_var_deflate
int(* NC_Dispatch::def_var_deflate) (int, int, int, int, int)
Definition at line 139 of file netcdf_dispatch.h.
◆ def_var_fletcher32
int(* NC_Dispatch::def_var_fletcher32) (int, int, int)
Definition at line 140 of file netcdf_dispatch.h.
◆ def_var_chunking
int(* NC_Dispatch::def_var_chunking) (int, int, int, const size_t *)
Definition at line 141 of file netcdf_dispatch.h.
◆ def_var_endian
int(* NC_Dispatch::def_var_endian) (int, int, int)
Definition at line 142 of file netcdf_dispatch.h.
◆ def_var_filter
int(* NC_Dispatch::def_var_filter) (int, int, unsigned int, size_t, const unsigned int *)
Definition at line 143 of file netcdf_dispatch.h.
◆ set_var_chunk_cache
int(* NC_Dispatch::set_var_chunk_cache) (int, int, size_t, size_t, float)
Definition at line 144 of file netcdf_dispatch.h.
◆ get_var_chunk_cache
int(* NC_Dispatch::get_var_chunk_cache) (int ncid, int varid, size_t *sizep, size_t *nelemsp, float *preemptionp)
Definition at line 145 of file netcdf_dispatch.h.
◆ inq_var_filter_ids
int(* NC_Dispatch::inq_var_filter_ids) (int ncid, int varid, size_t *nfilters, unsigned int *filterids)
Definition at line 148 of file netcdf_dispatch.h.
◆ inq_var_filter_info
int(* NC_Dispatch::inq_var_filter_info) (int ncid, int varid, unsigned int id, size_t *nparams, unsigned int *params)
Definition at line 149 of file netcdf_dispatch.h.
◆ def_var_quantize
int(* NC_Dispatch::def_var_quantize) (int ncid, int varid, int quantize_mode, int nsd)
Definition at line 151 of file netcdf_dispatch.h.
◆ inq_var_quantize
int(* NC_Dispatch::inq_var_quantize) (int ncid, int varid, int *quantize_modep, int *nsdp)
Definition at line 152 of file netcdf_dispatch.h.
◆ inq_filter_avail
int(* NC_Dispatch::inq_filter_avail) (int ncid, unsigned id)
Definition at line 154 of file netcdf_dispatch.h.
The documentation for this struct was generated from the following file:
