Public Types | Public Member Functions | Protected Attributes | List of all members
pqLinkedObjectInterface Struct Referenceabstract
The interface to a linked Qt text widget. More...
#include <pqLinkedObjectInterface.h>
Inheritance diagram for pqLinkedObjectInterface:
Collaboration diagram for pqLinkedObjectInterface:
enum  QtSignalState : bool { QtSignalState::On = true, QtSignalState::Off = false }
 Used to trigger on and off an object signal. More...
 pqLinkedObjectInterface ()=default
 Default constructor. More...
 pqLinkedObjectInterface (const pqLinkedObjectInterface &)=default
 Copy constructor needed for the clone method. More...
virtual ~pqLinkedObjectInterface () noexcept=default
 Default virtual destructor. More...
virtual std::unique_ptr< pqLinkedObjectInterfaceclone () const =0
 Pure virtual cloning this widget. More...
virtual void link (pqLinkedObjectInterface *other)=0
 Link this object to the other. More...
virtual void unlink ()=0
 Unlinks the objects. More...
virtual void setText (const QString &txt)=0
 Updates the object text. More...
virtual QString getText () const =0
 Returns the current buffer associated with this widget. More...
virtual QObject * getLinked () const noexcept=0
 Returns the linked QOBject. More...
virtual QString getName () const =0
 Returns the linked QObject name. More...
bool isLinked () const noexcept
 Returns true if this object is connected to another one. More...
pqLinkedObjectInterfaceConnectedTo = nullptr
QMetaObject::Connection Connection
bool SettingText = false
Derived classes should implement the proper behavior for all abstract functions.
The pqLinkedObjectInterface acts as an interface between two Qt text widgets that needs to be linked: when the associated text is updated the linked one gets updated too.
Definition at line 21 of file pqLinkedObjectInterface.h.
◆ QtSignalState
Enumerator
On
Off
Definition at line 57 of file pqLinkedObjectInterface.h.
◆ pqLinkedObjectInterface() [1/2]
pqLinkedObjectInterface::pqLinkedObjectInterface ( )
default
◆ pqLinkedObjectInterface() [2/2]
pqLinkedObjectInterface::pqLinkedObjectInterface ( const pqLinkedObjectInterface )
explicitdefault
◆ ~pqLinkedObjectInterface()
virtual pqLinkedObjectInterface::~pqLinkedObjectInterface ( )
virtualdefaultnoexcept
◆ clone()
virtual std::unique_ptr<pqLinkedObjectInterface> pqLinkedObjectInterface::clone ( ) const
pure virtual
Implemented in pqLinkedObjectQTextEdit, and pqLinkedObjectPythonTextArea.
◆ link()
virtual void pqLinkedObjectInterface::link ( pqLinkedObjectInterface other)
pure virtual
The expected behavior should be that when this object is updated, the other is too.
◆ unlink()
virtual void pqLinkedObjectInterface::unlink ( )
pure virtual
Implemented in pqLinkedObjectQTextEdit.
◆ setText()
virtual void pqLinkedObjectInterface::setText ( const QString &  txt)
pure virtual
This effectively should override the current content of the widget
◆ getText()
virtual QString pqLinkedObjectInterface::getText ( ) const
pure virtual
◆ getLinked()
virtual QObject* pqLinkedObjectInterface::getLinked ( ) const
pure virtualnoexcept
◆ getName()
virtual QString pqLinkedObjectInterface::getName ( ) const
pure virtual
◆ isLinked()
bool pqLinkedObjectInterface::isLinked ( ) const
inlinenoexcept
Definition at line 86 of file pqLinkedObjectInterface.h.
◆ ConnectedTo
pqLinkedObjectInterface* pqLinkedObjectInterface::ConnectedTo = nullptr
Definition at line 89 of file pqLinkedObjectInterface.h.
◆ Connection
QMetaObject::Connection pqLinkedObjectInterface::Connection
Definition at line 90 of file pqLinkedObjectInterface.h.
◆ SettingText
bool pqLinkedObjectInterface::SettingText = false
Definition at line 91 of file pqLinkedObjectInterface.h.
The documentation for this struct was generated from the following file:
