2 list(APPEND TESTS_WITH_BASELINES
3 #
Test uses D3 which is available in MPI only builds.
6 #
7 ExportSelectionToCSV.xml
8 # This test check spreadsheet values which include processID
9 ManyTypesXMLWriterReaderMPI.xml
10 #
Test Use Data Partitions
for volume rendering
11 #UseDataPartitions.xml
14 list(APPEND TESTS_WITH_INLINE_COMPARES
15 # needs parallel server
for the columns to match those in the test.
16 SpreadSheetParallelData.xml)
18 # test only checks for spreadsheet columns correctly in 19 # parallel client-server mode. 20 set (SpreadSheetParallelData_DISABLE_C TRUE)
22 # DistributePoints is only tested in non-built-in
mode.
23 paraview_add_client_server_tests(
24 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
25 TEST_SCRIPTS DistributePoints.xml
28 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
29 TEST_SCRIPTS DistributePoints.xml
32 # Process IDs tests are only tested in non-built-in
mode.
33 paraview_add_client_server_tests(
34 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
35 TEST_SCRIPTS GenerateProcessIds.xml ProcessIdsHTG.xml
38 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
39 TEST_SCRIPTS GenerateProcessIds.xml ProcessIdsHTG.xml
42 # Global IDs tests are only tested in non-built-in
mode.
43 paraview_add_client_server_tests(
44 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
45 TEST_SCRIPTS GlobalPointAndCellIdsHTG.xml
48 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
49 TEST_SCRIPTS GlobalPointAndCellIdsHTG.xml
52 # Volume rendering seems to work better in serial
53 set (UseDataPartitions_FORCE_SERIAL TRUE)
54 # This test requires a parallel partition to make sense so we 55 # skip running it with the built-in server. 57 TEST_SCRIPTS UseDataPartitions.xml
60 # Test a bug (#22337) that could only happen in non built-in mode 61 # This test has no baseline. 63 TEST_SCRIPTS POpenFoamUpdate.xml
66 # Test AppendReduce which can only be tested with non-built-in mode 68 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
69 TEST_SCRIPTS AppendReduce.xml
71 #
73 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
74 TEST_SCRIPTS AppendReduce.xml
77 #
Test uses GhostCellsGenerator which is available in MPI only builds.
78 # As the test use pvtu writer/reader it does not work in built-in
mode.
79 paraview_add_client_server_tests(
80 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
81 TEST_SCRIPTS GhostCellsGenerator.xml
84 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
85 TEST_SCRIPTS GhostCellsGenerator.xml
88 # GhostCellGeneratorSynchronize is only tested in non-built-in
mode.
89 paraview_add_client_server_tests(
90 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
91 TEST_SCRIPTS GhostCellsGeneratorSynchronize.xml
94 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
95 TEST_SCRIPTS GhostCellsGeneratorSynchronize.xml
98 # GhostCellsGeneratorImageDistributed needs specifically two servers
100 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
101 TEST_SCRIPTS GhostCellsGeneratorImageDistributed.xml
105 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
106 TEST_SCRIPTS GhostCellsGeneratorImageDistributed.xml
111 TEST_SCRIPTS GhostFeatureEdgesAndWireframe.xml
114 TEST_SCRIPTS GhostFeatureEdgesAndWireframe.xml
118 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
119 TEST_SCRIPTS RemoveGhostInterfaces.xml
122 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
123 TEST_SCRIPTS RemoveGhostInterfaces.xml
126 # Regression test
for https:
127 # Opacity rendering specifically needs to be tested with >4 procs and remote rendering
129 TEST_SCRIPTS TestOpacityRendering.xml
132 TEST_SCRIPTS TestOpacityRendering.xml
136 TEST_SCRIPTS TestOpacityRendering.xml
140 # Regression test for https://gitlab.kitware.com/paraview/paraview/-/issues/22681 141 # as it occurs when we have >=4 procs 143 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
144 TEST_SCRIPTS VolumeCrop.xml
147 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
148 TEST_SCRIPTS VolumeCrop.xml
152 if (PARAVIEW_ENABLE_COSMOTOOLS)
153 # Test the Generic IO file writer in VTKExtensions/CosmoTools 154 ExternalData_Expand_Arguments(ParaViewData _
155 "DATA{${paraview_test_data_directory_input}/Data/genericio/m000.499.allparticles}")
158 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
159 TEST_SCRIPTS GenericIOReadWrite.xml
162 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
163 TEST_SCRIPTS GenericIOReadWrite.xml
166 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
167 TEST_SCRIPTS GenericIOReadWrite.xml
171 list(APPEND TESTS_WITH_BASELINES
172 CGNSReader-5blocks_cgns.xml)
174 # PointInterpolator only works in non-distributed modes. 175 set(PointInterpolator_DISABLE_CRS TRUE)
176 set(PointInterpolator_DISABLE_CS TRUE)
177 set(PointVolumeInterpolator_DISABLE_CS TRUE)
179 #
Test uses distributed sources
180 set(GhostCellsGeneratorImageSerial_DISABLE_CS TRUE)
181 set(GhostCellsGeneratorImageSerial_DISABLE_CRS TRUE)
183 # The following tests are only run in client-server
mode.
184 # They are needed to verify the remote saving/loading of different files, such as states and screenshots, work.
185 paraview_add_client_server_tests(
186 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
187 TEST_SCRIPTS SaveLoadRemoteState.xml
190 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
191 TEST_SCRIPTS SaveRemoteScreenshot.xml
194 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
195 TEST_SCRIPTS SaveRemoteAnimation.xml
198 SET (SpreadSheet1_DISABLE_CS TRUE)
199 SET (SpreadSheet1_DISABLE_CRS TRUE)
201 # Disabled since the 1 column in spreadsheet view ends up being "Process ID" 202 # which messes up the sorting in this test. Need to extend the testing framework 203 # or fix spreadsheet view for these to work properly. 204 SET (SpreadSheet3_DISABLE_CS TRUE)
205 SET (SpreadSheet3_DISABLE_CRS TRUE)
207 # The hierchical fractal source is a temporary testing source and it does not 208 # create the dataset correctly in parallel. Since it's a testing source, I am 209 # just going to disable the test in parallel. We can fix the source when 211 SET (RectilinearFractal_DISABLE_CS TRUE)
212 SET (RectilinearFractal_DISABLE_CRS TRUE)
214 # Selections end up highlighting different set of ID based points in parallel. 215 # Hence disable them. 216 set (LineChartSelection_DISABLE_CS TRUE)
217 set (LineChartSelection_DISABLE_CRS TRUE)
219 # For the same reasons 220 set (MultiBlockChartSelection_DISABLE_CS TRUE)
221 set (MultiBlockChartSelection_DISABLE_CRS TRUE)
223 # Selection link may highlight incorrect ID in parallel, 224 # hence disable them. 225 set(SelectionLinkBasic_DISABLE_CS TRUE)
226 set(SelectionLinkInitial_DISABLE_CS TRUE)
227 set(SelectionLinkMultiple_DISABLE_CS TRUE)
228 set(SelectionLinkRemove_DISABLE_CS TRUE)
229 set(SelectionLinkReaction_DISABLE_CS TRUE)
230 set(SelectionLinkScripting_DISABLE_CS TRUE)
232 # Many types has a MPI version and Sequential version 233 set(ManyTypesXMLWriterReader_DISABLE_CS TRUE)
234 set(ManyTypesXMLWriterReader_DISABLE_CRS TRUE)
235 set(ManyTypesXMLWriterReaderMPI_DISABLE_C TRUE)
function paraview_add_client_server_render_tests()
function paraview_add_client_server_tests()
function paraview_add_client_tests()
