vtkLegacyParticleTracerBase.h
1 // SPDX-FileCopyrightText: Copyright (c) Ken Martin, Will Schroeder, Bill Lorensen
16 #ifndef vtkLegacyParticleTracerBase_h
17 #define vtkLegacyParticleTracerBase_h
18
19 #include "vtkDeprecation.h" // For VTK_DEPRECATED_IN_9_2_0
20 #include "vtkPVVTKExtensionsFiltersGeneralMPIModule.h" // For export macro
21 #include "vtkPolyDataAlgorithm.h"
22 #include "vtkSmartPointer.h" // For vtkSmartPointer
23
24 #include <list> // STL Header
25 #include <mutex> // STL Header
26 #include <vector> // STL Header
27
30 class vtkCellArray;
32 class vtkDataArray;
33 class vtkDataSet;
34 class vtkDoubleArray;
35 class vtkFloatArray;
36 class vtkGenericCell;
38 class vtkIntArray;
41 class vtkPointData;
42 class vtkPoints;
43 class vtkPolyData;
44 class vtkSignedCharArray;
47
49 {
51 struct Position_t
52 {
53  double x[4];
54 };
55 using Position = struct Position_t;
56
58 {
59  // These are used during iteration
61  int CachedDataSetId[2];
62  vtkIdType CachedCellId[2];
64  // These are computed scalars we might display
65  int SourceID;
66  int TimeStepAge; // amount of time steps the particle has advanced
68  int InjectedStepId; // time step the particle was injected
71  // These are useful to track for debugging etc
72  int ErrorCode;
73  float age;
74  // these are needed across time steps to compute vorticity
75  float rotation;
76  float angularVel;
77  float time;
78  float speed;
79  // once the particle is added, PointId is valid and is the tuple location
80  // in ProtoPD.
82  // if PointId is negative then in parallel this particle was just
83  // received and we need to get the tuple value from vtkPParticleTracerBase::Tail.
85 };
87
88 typedef std::vector<ParticleInformation> ParticleVector;
89 typedef ParticleVector::iterator ParticleIterator;
90 typedef std::list<ParticleInformation> ParticleDataList;
91 typedef ParticleDataList::iterator ParticleListIterator;
92 struct ParticleTracerFunctor;
94 }
95
98  : public vtkPolyDataAlgorithm
99 {
100 public:
101  friend struct vtkLegacyParticleTracerBaseNamespace::ParticleTracerFunctor;
102  enum Solvers
103  {
108  UNKNOWN
109  };
110
112  void PrintSelf(ostream& os, vtkIndent indent) override;
113  void PrintParticleHistories();
114
116
121  vtkGetMacro(ComputeVorticity, bool);
122  void SetComputeVorticity(bool);
124
126
129  vtkGetMacro(TerminalSpeed, double);
130  void SetTerminalSpeed(double);
132
134
138  vtkGetMacro(RotationScale, double);
139  void SetRotationScale(double);
141
143
147  vtkSetMacro(IgnorePipelineTime, vtkTypeBool);
148  vtkGetMacro(IgnorePipelineTime, vtkTypeBool);
149  vtkBooleanMacro(IgnorePipelineTime, vtkTypeBool);
151
153
162  vtkGetMacro(ForceReinjectionEveryNSteps, int);
163  void SetForceReinjectionEveryNSteps(int);
165
167
173  void SetTerminationTime(double t);
174  vtkGetMacro(TerminationTime, double);
176
177  void SetIntegrator(vtkInitialValueProblemSolver*);
178  vtkGetObjectMacro(Integrator, vtkInitialValueProblemSolver);
179
180  void SetIntegratorType(int type);
181  int GetIntegratorType();
182
184
188  vtkGetMacro(StartTime, double);
189  void SetStartTime(double t);
191
193
202  vtkSetMacro(StaticSeeds, vtkTypeBool);
203  vtkGetMacro(StaticSeeds, vtkTypeBool);
205
210  {
211  DIFFERENT = 0,
212  STATIC = 1,
213  LINEAR_TRANSFORMATION = 2,
214  SAME_TOPOLOGY = 3
215  };
216
218  /*
219  * Set/Get the type of variance of the mesh over time.
220  *
221  * DIFFERENT = 0,
222  * STATIC = 1,
223  * LINEAR_TRANSFORMATION = 2
224  * SAME_TOPOLOGY = 3
225  */
226  virtual void SetMeshOverTime(int meshOverTime);
227  virtual int GetMeshOverTimeMinValue() { return DIFFERENT; }
228  virtual int GetMeshOverTimeMaxValue() { return SAME_TOPOLOGY; }
229  void SetMeshOverTimeToDifferent() { this->SetMeshOverTime(DIFFERENT); }
230  void SetMeshOverTimeToStatic() { this->SetMeshOverTime(STATIC); }
231  void SetMeshOverTimeToLinearTransformation() { this->SetMeshOverTime(LINEAR_TRANSFORMATION); }
232  void SetMeshOverTimeToSameTopology() { this->SetMeshOverTime(SAME_TOPOLOGY); }
233  vtkGetMacro(MeshOverTime, int);
235
237
246  VTK_DEPRECATED_IN_9_2_0("Use SetMeshOverTime instead")
247  virtual void SetStaticMesh(vtkTypeBool staticMesh)
248  {
249  this->SetMeshOverTime(staticMesh ? STATIC : DIFFERENT);
250  }
251  VTK_DEPRECATED_IN_9_2_0("Use GetMeshOverTime instead")
252  virtual vtkTypeBool GetStaticMesh() { return this->MeshOverTime == STATIC; }
254
255  enum
256  {
258  INTERPOLATOR_WITH_CELL_LOCATOR
259  };
260
272  void SetInterpolatorType(int interpolatorType);
273
281  void SetInterpolatorTypeToDataSetPointLocator();
282
289  void SetInterpolatorTypeToCellLocator();
290
292
298  virtual void SetParticleWriter(vtkAbstractParticleWriter* pw);
299  vtkGetObjectMacro(ParticleWriter, vtkAbstractParticleWriter);
301
303
307  vtkSetFilePathMacro(ParticleFileName);
308  vtkGetFilePathMacro(ParticleFileName);
310
312
316  vtkSetMacro(EnableParticleWriting, vtkTypeBool);
317  vtkGetMacro(EnableParticleWriting, vtkTypeBool);
318  vtkBooleanMacro(EnableParticleWriting, vtkTypeBool);
320
322
327  vtkSetMacro(DisableResetCache, vtkTypeBool);
328  vtkGetMacro(DisableResetCache, vtkTypeBool);
329  vtkBooleanMacro(DisableResetCache, vtkTypeBool);
331
333
336  void AddSourceConnection(vtkAlgorithmOutput* input);
337  void RemoveAllSources();
339
341
345  vtkGetMacro(ForceSerialExecution, bool);
346  vtkSetMacro(ForceSerialExecution, bool);
347  vtkBooleanMacro(ForceSerialExecution, bool);
349 protected:
350  vtkSmartPointer<vtkPolyData> Output; // managed by child classes
352
357  vtkIdType UniqueIdCounter; // global Id counter used to give particles a stamp
359  vtkSmartPointer<vtkPointData> ParticlePointData; // the current particle point data consistent
360  // with particle history
361  // Everything related to time
362  vtkTypeBool IgnorePipelineTime; // whether to use the pipeline time for termination
363  vtkTypeBool DisableResetCache; // whether to enable ResetCache() method
365
366  // Control execution as serial or threaded
368
370  ~vtkLegacyParticleTracerBase() override;
371
372  //
373  // Make sure the pipeline knows what type we expect as input
374  //
375  int FillInputPortInformation(int port, vtkInformation* info) override;
376
377  //
378  // The usual suspects
379  //
380  vtkTypeBool ProcessRequest(vtkInformation* request, vtkInformationVector** inputVector,
381  vtkInformationVector* outputVector) override;
382
383  //
384  // Store any information we need in the output and fetch what we can
385  // from the input
386  //
387  int RequestInformation(vtkInformation* request, vtkInformationVector** inputVector,
388  vtkInformationVector* outputVector) override;
389
390  //
391  // Compute input time steps given the output step
392  //
393  int RequestUpdateExtent(vtkInformation* request, vtkInformationVector** inputVector,
394  vtkInformationVector* outputVector) override;
395
396  //
397  // what the pipeline calls for each time step
398  //
399  int RequestData(vtkInformation* request, vtkInformationVector** inputVector,
400  vtkInformationVector* outputVector) override;
401
402  //
403  // these routines are internally called to actually generate the output
404  //
405  virtual int ProcessInput(vtkInformationVector** inputVector);
406
407  // This is the main part of the algorithm:
408  // * move all the particles one step
409  // * Reinject particles (by adding them to this->ParticleHistories)
410  // either at the beginning or at the end of each step (modulo
411  // this->ForceReinjectionEveryNSteps)
412  // * Output a polydata representing the moved particles
413  // Note that if the starting and the ending time coincide, the polydata is still valid.
414  virtual vtkPolyData* Execute(vtkInformationVector** inputVector);
415
416  // the RequestData will call these methods in turn
417  virtual void Initialize() {} // the first iteration
418  virtual int OutputParticles(vtkPolyData* poly) = 0; // every iteration
419  virtual void Finalize() {} // the last iteration
420
425  virtual std::vector<vtkDataSet*> GetSeedSources(vtkInformationVector* inputVector, int timeStep);
426
427  // Initialization of input (vector-field) geometry
428  int InitializeInterpolator();
429  int UpdateDataCache(vtkDataObject* td);
430
435  void TestParticles(vtkLegacyParticleTracerBaseNamespace::ParticleVector& candidates,
437
438  void TestParticles(
439  vtkLegacyParticleTracerBaseNamespace::ParticleVector& candidates, std::vector<int>& passed);
440
447  virtual void AssignSeedsToProcessors(double time, vtkDataSet* source, int sourceID, int ptId,
448  vtkLegacyParticleTracerBaseNamespace::ParticleVector& localSeedPoints, int& localAssignedCount);
449
454  virtual void AssignUniqueIds(
456
461  void UpdateParticleList(vtkLegacyParticleTracerBaseNamespace::ParticleVector& candidates);
462
468  virtual bool UpdateParticleListFromOtherProcesses() { return false; }
469
474  double currentTime, double targetTime, vtkInitialValueProblemSolver* integrator,
475  vtkTemporalInterpolatedVelocityField* interpolator, vtkDoubleArray* cellVectors,
476  std::atomic<vtkIdType>& particleCount, std::mutex& eraseMutex, bool sequential);
477
478  // if the particle is added to send list, then returns value is 1,
479  // if it is kept on this process after a retry return value is 0
483  {
484  return true;
485  }
486
493  bool ComputeDomainExitLocation(
494  double pos[4], double p2[4], double intersection[4], vtkGenericCell* cell);
495
496  //
497  // Scalar arrays that are generated as each particle is updated
498  //
499  void CreateProtoPD(vtkDataObject* input);
500
501  vtkFloatArray* GetParticleAge(vtkPointData*);
502  vtkIntArray* GetParticleIds(vtkPointData*);
503  vtkSignedCharArray* GetParticleSourceIds(vtkPointData*);
504  vtkIntArray* GetInjectedPointIds(vtkPointData*);
505  vtkIntArray* GetInjectedStepIds(vtkPointData*);
506  vtkIntArray* GetErrorCodeArr(vtkPointData*);
507  vtkFloatArray* GetParticleVorticity(vtkPointData*);
508  vtkFloatArray* GetParticleRotation(vtkPointData*);
509  vtkFloatArray* GetParticleAngularVel(vtkPointData*);
510
511  // utility function we use to test if a point is inside any of our local datasets
512  bool InsideBounds(double point[]);
513
514  void CalculateVorticity(
515  vtkGenericCell* cell, double pcoords[3], vtkDoubleArray* cellVectors, double vorticity[3]);
516
517  //------------------------------------------------------
518
519  double GetCacheDataTime(int i);
520  double GetCacheDataTime();
521
522  virtual void ResetCache();
524  double* velocity, vtkTemporalInterpolatedVelocityField* interpolator, vtkIdType particleId,
525  vtkDoubleArray* cellVectors);
526
528
533  virtual bool IsPointDataValid(vtkDataObject* input);
534  bool IsPointDataValid(vtkCompositeDataSet* input, std::vector<std::string>& arrayNames);
535  void GetPointDataArrayNames(vtkDataSet* input, std::vector<std::string>& names);
537
538  vtkGetMacro(ReinjectionCounter, int);
539  vtkGetMacro(CurrentTimeValue, double);
540
541  void ResizeArrays(vtkIdType numTuples);
542
547  virtual void InitializeExtraPointDataArrays(vtkPointData* vtkNotUsed(outputPD)) {}
548
551  {
552  }
553
554  vtkTemporalInterpolatedVelocityField* GetInterpolator();
555
560  virtual void AddRestartSeeds(vtkInformationVector** /*inputVector*/) {}
561
566  virtual void RenameGhostArray(vtkPointData* pd);
567
568 private:
579  double* point1, double delT, int subSteps, vtkTemporalInterpolatedVelocityField* interpolator);
580
581  bool SetTerminationTimeNoModify(double t);
582
583  // Parameters of tracing
584  vtkInitialValueProblemSolver* Integrator;
585  double IntegrationStep;
586  double MaximumError;
587  bool ComputeVorticity;
588  double RotationScale;
589  double TerminalSpeed;
590
591  // A counter to keep track of how many times we reinjected
592  int ReinjectionCounter;
593
594  // Important for Caching of Cells/Ids/Weights etc
595  vtkTypeBool AllFixedGeometry;
596  int MeshOverTime;
597  vtkTypeBool StaticSeeds;
598
599  std::vector<double> InputTimeValues;
600  double StartTime;
601  double TerminationTime;
602  double CurrentTimeValue;
603
604  int StartTimeStep; // InputTimeValues[StartTimeStep] <= StartTime <=
605  // InputTimeValues[StartTimeStep+1]
606  int CurrentTimeStep;
607  int TerminationTimeStep; // computed from start time
608  bool FirstIteration;
609
610  // Innjection parameters
611  int ForceReinjectionEveryNSteps;
612  vtkTimeStamp ParticleInjectionTime;
613  bool HasCache;
614
615  // Particle writing to disk
616  vtkAbstractParticleWriter* ParticleWriter;
617  char* ParticleFileName;
618  vtkTypeBool EnableParticleWriting;
619
620  // The main lists which are held during operation- between time step updates
622
623  // The velocity interpolator
625
626  // Data for time step CurrentTimeStep-1 and CurrentTimeStep
628
629  // Cache bounds info for each dataset we will use repeatedly
630  struct bounds_t
631  {
632  double b[6];
633  };
634  using bounds = struct bounds_t;
635  std::vector<bounds> CachedBounds[2];
636
637  // variables used by Execute() to produce output
638
639  vtkSmartPointer<vtkDataSet> DataReferenceT[2];
640
641  vtkSmartPointer<vtkPoints> OutputCoordinates;
642  vtkSmartPointer<vtkIdTypeArray> ParticleCellsConnectivity;
643  vtkSmartPointer<vtkIdTypeArray> ParticleCellsOffsets;
644  vtkSmartPointer<vtkCellArray> ParticleCells;
645
646  vtkSmartPointer<vtkFloatArray> ParticleAge;
647  vtkSmartPointer<vtkIntArray> ParticleIds;
648  vtkSmartPointer<vtkSignedCharArray> ParticleSourceIds;
649  vtkSmartPointer<vtkIntArray> InjectedPointIds;
650  vtkSmartPointer<vtkIntArray> InjectedStepIds;
651  vtkSmartPointer<vtkIntArray> ErrorCodeArray;
652  vtkSmartPointer<vtkFloatArray> ParticleVorticity;
653  vtkSmartPointer<vtkFloatArray> ParticleRotation;
654  vtkSmartPointer<vtkFloatArray> ParticleAngularVel;
655  vtkSmartPointer<vtkPointData> OutputPointData;
656
657  // temp array
659
661  void operator=(const vtkLegacyParticleTracerBase&) = delete;
662  vtkTimeStamp ExecuteTime;
663
664  unsigned int NumberOfParticles();
665
667
668  static const double Epsilon;
669 };
670
672 #endif
A particle tracer for vector fields.
std::list< ParticleInformation > ParticleDataList
virtual void AddRestartSeeds(vtkInformationVector **)
For restarts of particle paths, we add in the ability to add in particles from a previous computation...
ProtoPD is used just to keep track of the input array names and number of components for copy allocat...
#define VTK_ABI_NAMESPACE_END
MeshOverTimeTypes
Types of Variance of Mesh over time.
info
int vtkIdType
vtkLegacyParticleTracerBaseNamespace::ParticleDataList ParticleHistories
vtkSmartPointer< vtkPolyData > Output
vtkSmartPointer< vtkPointData > ProtoPD
int vtkTypeBool
#define VTK_ABI_NAMESPACE_BEGIN
time
source
A Parallel Particle tracer for unsteady vector fields.
std::vector< ParticleInformation > ParticleVector
virtual bool SendParticleToAnotherProcess(vtkLegacyParticleTracerBaseNamespace::ParticleInformation &, vtkLegacyParticleTracerBaseNamespace::ParticleInformation &, vtkPointData *)
this is used during classification of seed points and also between iterations of the main loop as par...
virtual void SetToExtraPointDataArrays(vtkIdType, vtkLegacyParticleTracerBaseNamespace::ParticleInformation &)
point
virtual void InitializeExtraPointDataArrays(vtkPointData *vtkNotUsed(outputPD))
Methods to append values to existing point data arrays that may only be desired on specific concrete ...
#define VTKPVVTKEXTENSIONSFILTERSGENERALMPI_EXPORT
vtkSmartPointer< vtkPointData > ParticlePointData
