vtkOMETIFFChannelCalculator.h
13 #ifndef vtkOMETIFFChannelCalculator_h
14 #define vtkOMETIFFChannelCalculator_h
15
16 #include "vtkPVVTKExtensionsFiltersGeneralModule.h" //needed for exports
18 #include "vtkSmartPointer.h" // needed for vtkSmartPointer
20 #include <map> // needed for map
21
23 class vtkScalarsToColors;
26 {
27 public:
30  void PrintSelf(ostream& os, vtkIndent indent) override;
31
33
36  vtkGetObjectMacro(ChannelSelection, vtkDataArraySelection);
38
40
43  void SetChannel1LUT(vtkScalarsToColors* stc) { this->SetLUT("Channel_1", stc); }
44  void SetChannel2LUT(vtkScalarsToColors* stc) { this->SetLUT("Channel_2", stc); }
45  void SetChannel3LUT(vtkScalarsToColors* stc) { this->SetLUT("Channel_3", stc); }
46  void SetChannel4LUT(vtkScalarsToColors* stc) { this->SetLUT("Channel_4", stc); }
47  void SetChannel5LUT(vtkScalarsToColors* stc) { this->SetLUT("Channel_5", stc); }
48  void SetChannel6LUT(vtkScalarsToColors* stc) { this->SetLUT("Channel_6", stc); }
49  void SetChannel7LUT(vtkScalarsToColors* stc) { this->SetLUT("Channel_7", stc); }
50  void SetChannel8LUT(vtkScalarsToColors* stc) { this->SetLUT("Channel_8", stc); }
51  void SetChannel9LUT(vtkScalarsToColors* stc) { this->SetLUT("Channel_9", stc); }
52  void SetChannel10LUT(vtkScalarsToColors* stc) { this->SetLUT("Channel_10", stc); }
53  void SetLUT(const char* channelName, vtkScalarsToColors*);
55
57
60  void SetChannel1Weight(double wght) { this->SetWeight("Channel_1", wght); }
61  void SetChannel2Weight(double wght) { this->SetWeight("Channel_2", wght); }
62  void SetChannel3Weight(double wght) { this->SetWeight("Channel_3", wght); }
63  void SetChannel4Weight(double wght) { this->SetWeight("Channel_4", wght); }
64  void SetChannel5Weight(double wght) { this->SetWeight("Channel_5", wght); }
65  void SetChannel6Weight(double wght) { this->SetWeight("Channel_6", wght); }
66  void SetChannel7Weight(double wght) { this->SetWeight("Channel_7", wght); }
67  void SetChannel8Weight(double wght) { this->SetWeight("Channel_8", wght); }
68  void SetChannel9Weight(double wght) { this->SetWeight("Channel_9", wght); }
69  void SetChannel10Weight(double wght) { this->SetWeight("Channel_10", wght); }
70  void SetWeight(const char* channelName, double weight);
72  vtkMTimeType GetMTime() override;
73
74 protected:
76  ~vtkOMETIFFChannelCalculator() override;
77
80
81  struct LUTItem
82  {
84  double Weight;
85  };
86
87  std::map<std::string, LUTItem> LUTMap;
89
90 private:
92  void operator=(const vtkOMETIFFChannelCalculator&) = delete;
93 };
94
95 #endif
weight
void SetChannel9LUT(vtkScalarsToColors *stc)
Set the transfer functions to use to map scalars to colors.
void SetChannel3LUT(vtkScalarsToColors *stc)
void SetChannel1LUT(vtkScalarsToColors *stc)
info
vtkSmartPointer< vtkScalarsToColors > LUT
Set weights for each of the channels.
void SetChannel7LUT(vtkScalarsToColors *stc)
void SetChannel8LUT(vtkScalarsToColors *stc)
vtkTypeUInt64 vtkMTimeType
vtkDataArraySelection * ChannelSelection
virtual int FillInputPortInformation(int port, vtkInformation *info)
void SetChannel2LUT(vtkScalarsToColors *stc)
virtual vtkMTimeType GetMTime()
filter to combine multiple channels into colors
#define VTKPVVTKEXTENSIONSFILTERSGENERAL_EXPORT
void SetChannel4LUT(vtkScalarsToColors *stc)
void SetChannel5LUT(vtkScalarsToColors *stc)
void SetChannel10LUT(vtkScalarsToColors *stc)
std::map< std::string, LUTItem > LUTMap
port
void SetChannel6LUT(vtkScalarsToColors *stc)
virtual int RequestData(vtkInformation *, vtkInformationVector **, vtkInformationVector *)
static vtkPassInputTypeAlgorithm * New()
