12 #ifndef vtkPVCompositeOrthographicSliceRepresentation_h 13 #define vtkPVCompositeOrthographicSliceRepresentation_h 31 this->SetSliceRepresentation(0, repr);
35 this->SetSliceRepresentation(1, repr);
39 this->SetSliceRepresentation(2, repr);
71 unsigned int Initialize(
unsigned int minIdAvailable,
unsigned int maxIdAvailable)
override;
void SetSliceRepresentation2(vtkGeometrySliceRepresentation *repr)
a data-representation used by ParaView.
bool RemoveFromView(vtkView *view) override
unsigned int Initialize(unsigned int minIdAvailable, unsigned int maxIdAvailable) override
Override because of internal composite representations that need to be initialized as well...
void SetSliceRepresentation0(vtkGeometrySliceRepresentation *repr)
void MarkModified() override
Propagate the modification to all internal representations.
void SetVisibility(bool visible) override
Set visibility of the representation.
void RemoveInputConnection(int port, vtkAlgorithmOutput *input) override
Passed on to internal representations as well.
static vtkPVCompositeRepresentation * New()
vtkPVCompositeOrthographicSliceRepresentation is designed for use with vtkPVOrthographicSliceView.
void SetInputConnection(int port, vtkAlgorithmOutput *input) override
void AddInputConnection(int port, vtkAlgorithmOutput *input) override
bool AddToView(vtkView *view) override
void SetSliceRepresentation1(vtkGeometrySliceRepresentation *repr)
extends vtkGeometryRepresentation to add support for showing just specific slices from the dataset...
