10 #ifndef vtkSIDirectoryProxy_h 11 #define vtkSIDirectoryProxy_h
void Pull(vtkSMMessage *msg) override
vtkSIDirectoryProxy is the server-implementation for a vtkSMDirectory which will customly handle serv...
virtual bool ReadXMLProperty(vtkPVXMLElement *property_element)
Parses the XML to create property/subproxy helpers.
vtkSIProxy is the server-implementation for a vtkSMProxy that helps the vtkSMProxy with managing/upda...
static vtkSIProxy * New()
object responsible for managing XML proxies definitions
Basic ServerImplementation property used to call a method with no argument on a VTK object...
