virtual void ChildSaveState(vtkPVXMLElement *domainElement)
Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attribut...
virtual void Update(vtkSMProperty *requestingProperty)
Update self based on the "unchecked" values of all required properties.
virtual int SetDefaultValues(vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
represents the possible values a property can have
virtual int ReadXMLAttributes(vtkSMProperty *prop, vtkPVXMLElement *elem)
virtual int IsInDomain(vtkSMProperty *vtkNotUsed(property))
Is the (unchecked) value of the property in the domain? Overwritten by sub-classes.
list of integers with associated strings
static vtkSMDomain * New()
