Macros | Functions
xmlversion.h File Reference
#include <libxml/xmlexports.h>
Include dependency graph for xmlversion.h:
Macros
#define LIBXML_DOTTED_VERSION   "2.10.1"
 LIBXML_DOTTED_VERSION: More...
#define LIBXML_VERSION   21001
 LIBXML_VERSION: More...
#define LIBXML_VERSION_STRING   "21001"
 LIBXML_VERSION_STRING: More...
#define LIBXML_VERSION_EXTRA   ""
 LIBXML_VERSION_EXTRA: More...
#define LIBXML_TEST_VERSION   xmlCheckVersion(21001);
 LIBXML_TEST_VERSION: More...
#define WITHOUT_TRIO
 WITHOUT_TRIO: More...
#define LIBXML_THREAD_ENABLED
 LIBXML_THREAD_ENABLED: More...
#define LIBXML_THREAD_ALLOC_ENABLED
 LIBXML_THREAD_ALLOC_ENABLED: More...
#define LIBXML_TREE_ENABLED
 LIBXML_TREE_ENABLED: More...
#define LIBXML_OUTPUT_ENABLED
 LIBXML_OUTPUT_ENABLED: More...
#define LIBXML_PUSH_ENABLED
 LIBXML_PUSH_ENABLED: More...
#define LIBXML_READER_ENABLED
 LIBXML_READER_ENABLED: More...
#define LIBXML_PATTERN_ENABLED
 LIBXML_PATTERN_ENABLED: More...
#define LIBXML_WRITER_ENABLED
 LIBXML_WRITER_ENABLED: More...
#define LIBXML_SAX1_ENABLED
 LIBXML_SAX1_ENABLED: More...
#define LIBXML_VALID_ENABLED
 LIBXML_FTP_ENABLED: More...
#define LIBXML_HTML_ENABLED
 LIBXML_HTML_ENABLED: More...
#define LIBXML_C14N_ENABLED
 LIBXML_LEGACY_ENABLED: More...
#define LIBXML_CATALOG_ENABLED
 LIBXML_CATALOG_ENABLED: More...
#define LIBXML_XPATH_ENABLED
 LIBXML_XPATH_ENABLED: More...
#define LIBXML_XPTR_ENABLED
 LIBXML_XPTR_ENABLED: More...
#define LIBXML_XINCLUDE_ENABLED
 LIBXML_XPTR_LOCS_ENABLED: More...
#define LIBXML_ISO8859X_ENABLED
 LIBXML_ICONV_ENABLED: More...
#define LIBXML_UNICODE_ENABLED
 LIBXML_DEBUG_ENABLED: More...
#define LIBXML_REGEXP_ENABLED
 LIBXML_REGEXP_ENABLED: More...
#define LIBXML_AUTOMATA_ENABLED
 LIBXML_AUTOMATA_ENABLED: More...
#define LIBXML_SCHEMAS_ENABLED
 LIBXML_EXPR_ENABLED: More...
#define LIBXML_SCHEMATRON_ENABLED
 LIBXML_SCHEMATRON_ENABLED: More...
#define LIBXML_MODULES_ENABLED
 LIBXML_MODULES_ENABLED: More...
#define LIBXML_MODULE_EXTENSION   ".so"
 LIBXML_MODULE_EXTENSION: More...
#define LIBXML_ZLIB_ENABLED
 LIBXML_ZLIB_ENABLED: More...
#define ATTRIBUTE_UNUSED
 LIBXML_LZMA_ENABLED: More...
#define LIBXML_ATTR_ALLOC_SIZE(x)
 LIBXML_ATTR_ALLOC_SIZE: More...
#define LIBXML_ATTR_FORMAT(fmt, args)
 LIBXML_ATTR_FORMAT: More...
#define XML_DEPRECATED
 XML_DEPRECATED: More...
Functions
XMLPUBFUN void XMLCALL xmlCheckVersion (int version)
Macro Definition Documentation
◆ LIBXML_DOTTED_VERSION
the version string like "1.2.3"
Definition at line 32 of file xmlversion.h.
◆ LIBXML_VERSION
LIBXML_VERSION:
the version number: 1.2.3 value is 10203
Definition at line 39 of file xmlversion.h.
◆ LIBXML_VERSION_STRING
the version number string, 1.2.3 value is "10203"
Definition at line 46 of file xmlversion.h.
◆ LIBXML_VERSION_EXTRA
extra version information, used to show a git commit description
Definition at line 53 of file xmlversion.h.
◆ LIBXML_TEST_VERSION
Macro to check that the libxml version in use is compatible with the version the software has been compiled against
Definition at line 61 of file xmlversion.h.
◆ WITHOUT_TRIO
WITHOUT_TRIO:
defined if the trio support should not be configured in
Definition at line 77 of file xmlversion.h.
◆ LIBXML_THREAD_ENABLED
Whether the thread support is configured in
Definition at line 94 of file xmlversion.h.
◆ LIBXML_THREAD_ALLOC_ENABLED
Whether the allocation hooks are per-thread
Definition at line 103 of file xmlversion.h.
◆ LIBXML_TREE_ENABLED
Whether the DOM like tree manipulation API support is configured in
Definition at line 112 of file xmlversion.h.
◆ LIBXML_OUTPUT_ENABLED
Whether the serialization/saving support is configured in
Definition at line 121 of file xmlversion.h.
◆ LIBXML_PUSH_ENABLED
Whether the push parsing interfaces are configured in
Definition at line 130 of file xmlversion.h.
◆ LIBXML_READER_ENABLED
Whether the xmlReader parsing interface is configured in
Definition at line 139 of file xmlversion.h.
◆ LIBXML_PATTERN_ENABLED
Whether the xmlPattern node selection interface is configured in
Definition at line 148 of file xmlversion.h.
◆ LIBXML_WRITER_ENABLED
Whether the xmlWriter saving interface is configured in
Definition at line 157 of file xmlversion.h.
◆ LIBXML_SAX1_ENABLED
Whether the older SAX1 interface is configured in
Definition at line 166 of file xmlversion.h.
◆ LIBXML_VALID_ENABLED
LIBXML_FTP_ENABLED:
Whether the FTP support is configured in LIBXML_HTTP_ENABLED:
Whether the HTTP support is configured in LIBXML_VALID_ENABLED:
Whether the DTD validation support is configured in
Definition at line 193 of file xmlversion.h.
◆ LIBXML_HTML_ENABLED
Whether the HTML support is configured in
Definition at line 202 of file xmlversion.h.
◆ LIBXML_C14N_ENABLED
Whether the deprecated APIs are compiled in for compatibility LIBXML_C14N_ENABLED:
Whether the Canonicalization support is configured in
Definition at line 220 of file xmlversion.h.
◆ LIBXML_CATALOG_ENABLED
Whether the Catalog support is configured in
Definition at line 229 of file xmlversion.h.
◆ LIBXML_XPATH_ENABLED
Whether XPath is configured in
Definition at line 238 of file xmlversion.h.
◆ LIBXML_XPTR_ENABLED
Whether XPointer is configured in
Definition at line 247 of file xmlversion.h.
◆ LIBXML_XINCLUDE_ENABLED
Whether support for XPointer locations is configured in LIBXML_XINCLUDE_ENABLED:
Whether XInclude is configured in
Definition at line 265 of file xmlversion.h.
◆ LIBXML_ISO8859X_ENABLED
Whether iconv support is available LIBXML_ICU_ENABLED:
Whether icu support is available LIBXML_ISO8859X_ENABLED:
Whether ISO-8859-* support is made available in case iconv is not
Definition at line 292 of file xmlversion.h.
◆ LIBXML_UNICODE_ENABLED
Whether Debugging module is configured in DEBUG_MEMORY_LOCATION:
Whether the memory debugging is configured in LIBXML_DEBUG_RUNTIME:
Whether the runtime debugging is configured in LIBXML_UNICODE_ENABLED:
Whether the Unicode related interfaces are compiled in
Definition at line 328 of file xmlversion.h.
◆ LIBXML_REGEXP_ENABLED
Whether the regular expressions interfaces are compiled in
Definition at line 337 of file xmlversion.h.
◆ LIBXML_AUTOMATA_ENABLED
Whether the automata interfaces are compiled in
Definition at line 346 of file xmlversion.h.
◆ LIBXML_SCHEMAS_ENABLED
Whether the formal expressions interfaces are compiled in
This code is unused and disabled unconditionally for now. LIBXML_SCHEMAS_ENABLED:
Whether the Schemas validation interfaces are compiled in
Definition at line 366 of file xmlversion.h.
◆ LIBXML_SCHEMATRON_ENABLED
Whether the Schematron validation interfaces are compiled in
Definition at line 375 of file xmlversion.h.
◆ LIBXML_MODULES_ENABLED
Whether the module interfaces are compiled in
Definition at line 384 of file xmlversion.h.
◆ LIBXML_MODULE_EXTENSION
the string suffix used by dynamic modules (usually shared libraries)
Definition at line 390 of file xmlversion.h.
◆ LIBXML_ZLIB_ENABLED
Whether the Zlib support is compiled in
Definition at line 399 of file xmlversion.h.
◆ ATTRIBUTE_UNUSED
Whether the Lzma support is compiled in ATTRIBUTE_UNUSED:
Macro used to signal to GCC unused function parameters
Definition at line 474 of file xmlversion.h.
◆ LIBXML_ATTR_ALLOC_SIZE
#define LIBXML_ATTR_ALLOC_SIZE (   x)
Macro used to indicate to GCC this is an allocator function
Definition at line 480 of file xmlversion.h.
◆ LIBXML_ATTR_FORMAT
#define LIBXML_ATTR_FORMAT (   fmt,
  args
LIBXML_ATTR_FORMAT:
Macro used to indicate to GCC the parameter are printf like
Definition at line 486 of file xmlversion.h.
◆ XML_DEPRECATED
XML_DEPRECATED:
Macro used to indicate that a function, variable, type or struct member is deprecated.
Definition at line 494 of file xmlversion.h.
Function Documentation
◆ xmlCheckVersion()
XMLPUBFUN void XMLCALL xmlCheckVersion ( int  version)
