#define | kwsys_ns(x) vtksys##x |
#define | kwsysEXPORT vtksys_EXPORT |
#define | kwsysBase64 kwsys_ns(Base64) |
#define | kwsysBase64_Decode kwsys_ns(Base64_Decode) |
#define | kwsysBase64_Decode3 kwsys_ns(Base64_Decode3) |
#define | kwsysBase64_Encode kwsys_ns(Base64_Encode) |
#define | kwsysBase64_Encode1 kwsys_ns(Base64_Encode1) |
#define | kwsysBase64_Encode2 kwsys_ns(Base64_Encode2) |
#define | kwsysBase64_Encode3 kwsys_ns(Base64_Encode3) |
kwsysEXPORT void | kwsysBase64_Encode3 (const unsigned char *src, unsigned char *dest) |
Encode 3 bytes into a 4 byte string. More... | |
kwsysEXPORT void | kwsysBase64_Encode2 (const unsigned char *src, unsigned char *dest) |
Encode 2 bytes into a 4 byte string. More... | |
kwsysEXPORT void | kwsysBase64_Encode1 (const unsigned char *src, unsigned char *dest) |
Encode 1 bytes into a 4 byte string. More... | |
kwsysEXPORT size_t | kwsysBase64_Encode (const unsigned char *input, size_t length, unsigned char *output, int mark_end) |
Encode 'length' bytes from the input buffer and store the encoded stream into the output buffer. More... | |
kwsysEXPORT int | kwsysBase64_Decode3 (const unsigned char *src, unsigned char *dest) |
Decode 4 bytes into a 3 byte string. More... | |
kwsysEXPORT size_t | kwsysBase64_Decode (const unsigned char *input, size_t length, unsigned char *output, size_t max_input_length) |
Decode bytes from the input buffer and store the decoded stream into the output buffer until 'length' bytes have been decoded. More... | |
#define kwsysEXPORT vtksys_EXPORT |
kwsysEXPORT void kwsysBase64_Encode3 | ( | const unsigned char * | src, |
unsigned char * | dest | ||
kwsysEXPORT void kwsysBase64_Encode2 | ( | const unsigned char * | src, |
kwsysEXPORT void kwsysBase64_Encode1 | ( | const unsigned char * | src, |
kwsysEXPORT size_t kwsysBase64_Encode | ( | const unsigned char * | input, |
size_t | length, | ||
unsigned char * | output, | ||
int | mark_end | ||
Return the length of the encoded buffer (output). Note that the output buffer must be allocated by the caller (length * 1.5 should be a safe estimate). If 'mark_end' is true than an extra set of 4 bytes is added to the end of the stream if the input is a multiple of 3 bytes. These bytes are invalid chars and therefore they will stop the decoder thus enabling the caller to decode a stream without actually knowing how much data to expect (if the input is not a multiple of 3 bytes then the extra padding needed to complete the encode 4 bytes will stop the decoding anyway).
kwsysEXPORT int kwsysBase64_Decode3 | ( | const unsigned char * | src, |
Returns the number of bytes actually decoded.
kwsysEXPORT size_t kwsysBase64_Decode | ( | const unsigned char * | input, |
size_t | max_input_length | ||
Return the real length of the decoded stream (which should be equal to 'length'). Note that the output buffer must be allocated by the caller. If 'max_input_length' is not null, then it specifies the number of encoded bytes that should be at most read from the input buffer. In that case the 'length' parameter is ignored. This enables the caller to decode a stream without actually knowing how much decoded data to expect (of course, the buffer must be large enough).
