BivariateRepresentationsPlugin.h
1 #define _paraview_add_plugin_built_shared 1
2 #define _paraview_add_plugin_with_initializers 0
3 #define _paraview_add_plugin_with_python 0
4 #define _paraview_add_plugin_with_ui 1
5 #define _paraview_add_plugin_with_xml 1
6
7 #define PARAVIEW_BUILDING_PLUGIN
8 #define PARAVIEW_PLUGIN_BUILT_SHARED _paraview_add_plugin_built_shared
9 #include "vtkPVPlugin.h"
10
11 #if _paraview_add_plugin_with_ui
13 #include <QObject>
14 #include <QtPlugin>
15 #endif
16
17 #if _paraview_add_plugin_with_xml
19 #endif
20
21 #if _paraview_add_plugin_with_python
23 #endif
24
25 #if _paraview_add_plugin_with_initializers
27 #endif
28
30 #if _paraview_add_plugin_with_ui
31  public QObject,
33 #endif
35  public vtkPVPlugin
36
37 #if _paraview_add_plugin_with_initializers
39 #endif
40 #if _paraview_add_plugin_with_xml
42 #endif
43 #if _paraview_add_plugin_with_python
45 #endif
46
47 {
48 #if _paraview_add_plugin_with_ui
49  Q_OBJECT
50  Q_INTERFACES(vtkPVGUIPluginInterface)
51  Q_PLUGIN_METADATA(IID "com.kitware/paraview/BivariateRepresentationsPlugin")
52 #endif
53 public:
55
59  const char* GetPluginName() override
60  {return "BivariateRepresentations"; }
61
65  const char* GetPluginVersionString() override
66  { return "1.0"; }
67
71  bool GetRequiredOnServer() override
72  { return true; }
73
77  bool GetRequiredOnClient() override
78  { return true; }
79
83  const char* GetRequiredPlugins() override
84  { return ""; }
85
89  const char* GetDescription() override
90  { return "Representations to visualize bivariate data"; }
91
95  const char* GetEULA() override;
96
102  void GetBinaryResources(std::vector<std::string>& resources) override;
103
104 #if _paraview_add_plugin_with_xml
105
108  void GetXMLs(std::vector<std::string> &xmls) override;
109
117 #endif
118
119 #if _paraview_add_plugin_with_ui
120
123  QObjectList interfaces() override;
124 #endif
125
126 #if _paraview_add_plugin_with_python
127  void GetPythonSourceList(std::vector<std::string>& modules,
128  std::vector<std::string>& sources,
129  std::vector<int>& package_flags) override;
130 #endif
131
132 #if _paraview_add_plugin_with_initializers
133  void Initialize() override;
134 #endif
135 };
Returns the list of ParaView-Interfaces provided by this plugin.
void GetXMLs(std::vector< std::string > &xmls) override
vtkClientServerInterpreterInitializer::InterpreterInitializationCallback GetInitializeInterpreterCallback() override
Returns the callback function to call to initialize the interpretor for the new vtk/server-manager cl...
Definition: vtkPVPlugin.h:38
Returns a &#39;;&#39; separated list of plugin names required by this plugin.
