BivariateRepresentations_server_manager_modules_data.h
1 // Loadable modules
2 //
3 // Generated by /builds/gitlab-kitware-sciviz-ci/build/bin/vtkProcessXML-pv6.0
4 //
5 #ifndef BivariateRepresentations_server_manager_modules_data_h
6 #define BivariateRepresentations_server_manager_modules_data_h
7
8 #include <cstring>
9 #include <cassert>
10 #include <algorithm>
11
12
13 // From file /builds/gitlab-kitware-sciviz-ci/Plugins/BivariateRepresentations/Representations/BivariateRepresentations.xml
15 "<ServerManagerConfiguration>\n"
16 " <ProxyGroup name=\"representations\">\n"
17 " <RepresentationProxy name=\"BivariateNoiseRepresentation\"\n"
18 " class=\"vtkBivariateNoiseRepresentation\"\n"
19 " processes=\"client|renderserver|dataserver\"\n"
20 " base_proxygroup=\"representations\"\n"
21 " base_proxyname=\"SurfaceRepresentation\">\n"
22 " <Documentation>\n"
23 " This representation displays the values of the secondary array in the form of noise.\n"
24 " </Documentation>\n"
25 "\n"
26 " <StringVectorProperty name=\"NoiseArray\"\n"
27 " command=\"SetInputArrayToProcess\"\n"
28 " number_of_elements=\"5\"\n"
29 " element_types=\"int int int int str\"\n"
30 " default_values=\"1 0 0 0 0\">\n"
31 " <ArrayListDomain name=\"array_list\"\n"
32 " attribute_type=\"Scalars\"\n"
33 " input_domain_name=\"input_array_point_1\">\n"
34 " <RequiredProperties>\n"
35 " <Property name=\"Input\" function=\"Input\"/>\n"
36 " </RequiredProperties>\n"
37 " </ArrayListDomain>\n"
38 " <Documentation>\n"
39 " This property specifies the name of the input array displayed with noise.\n"
40 " </Documentation>\n"
41 " </StringVectorProperty>\n"
42 "\n"
43 " <DoubleVectorProperty name=\"Granularity\"\n"
44 " command=\"SetFrequency\"\n"
45 " number_of_elements=\"1\"\n"
46 " default_values=\"30.0\">\n"
47 " <DoubleRangeDomain name=\"range\" min=\"0.0\" max=\"150.0\"/>\n"
48 " <Documentation>\n"
49 " This property specifies a value for the granularity (frequency) of the noise.\n"
50 " </Documentation>\n"
51 " </DoubleVectorProperty>\n"
52 "\n"
53 " <DoubleVectorProperty name=\"Amplitude\"\n"
54 " command=\"SetAmplitude\"\n"
55 " number_of_elements=\"1\"\n"
56 " default_values=\"0.5\">\n"
57 " <DoubleRangeDomain name=\"range\" min=\"0.0\" max=\"1.0\"/>\n"
58 " <Documentation>\n"
59 " This property specifies a value for the amplitude of the noise.\n"
60 " </Documentation>\n"
61 " </DoubleVectorProperty>\n"
62 "\n"
63 " <DoubleVectorProperty name=\"AnimationSpeedFactor\"\n"
64 " command=\"SetSpeed\"\n"
65 " number_of_elements=\"1\"\n"
66 " default_values=\"1.0\">\n"
67 " <DoubleRangeDomain name=\"range\" min=\"0.0\" max=\"3.0\"/>\n"
68 " <Documentation>\n"
69 " This property specifies a factor modifying the speed animation of the noise animation.\n"
70 " </Documentation>\n"
71 " </DoubleVectorProperty>\n"
72 "\n"
73 " <IntVectorProperty name=\"NbOfOctaves\"\n"
74 " command=\"SetNbOfOctaves\"\n"
75 " number_of_elements=\"1\"\n"
76 " default_values=\"3\">\n"
77 " <IntRangeDomain name=\"range\" min=\"0\" max=\"5\"/>\n"
78 " <Documentation>\n"
79 " This property specifies the number of octaves of noise (overlaping layers of noise).\n"
80 " </Documentation>\n"
81 " </IntVectorProperty>\n"
82 " <!-- End of BivariateNoiseRepresentation -->\n"
83 " </RepresentationProxy>\n"
84 "\n"
85 " <Extension name=\"GeometryRepresentation\">\n"
86 " <Documentation>\n"
87 " Extends standard GeometryRepresentation by adding\n"
88 " BivariateNoiseRepresentation as a new type of representation.\n"
89 " </Documentation>\n"
90 "\n"
91 " <RepresentationType subproxy=\"BivariateNoiseRepresentation\"\n"
92 " text=\"Bivariate Noise Surface\"\n"
93 " subtype=\"Surface\"/>\n"
94 "\n"
95 " <SubProxy>\n"
96 " <Proxy name=\"BivariateNoiseRepresentation\"\n"
97 " proxygroup=\"representations\"\n"
98 " proxyname=\"BivariateNoiseRepresentation\">\n"
99 " </Proxy>\n"
100 "\n"
101 " <ShareProperties subproxy=\"SurfaceRepresentation\">\n"
102 " <Exception name=\"Input\"/>\n"
103 " <Exception name=\"Visibility\"/>\n"
104 " <Exception name=\"Representation\"/>\n"
105 " </ShareProperties>\n"
106 "\n"
107 " <ExposedProperties>\n"
108 " <PropertyGroup label=\"Bivariate representation\">\n"
109 " <Property name=\"NoiseArray\"/>\n"
110 " <Property name=\"Granularity\"/>\n"
111 " <Property name=\"Amplitude\"/>\n"
112 " <Property name=\"AnimationSpeedFactor\"/>\n"
113 " <Property name=\"NbOfOctaves\"/>\n"
114 " <Hints>\n"
115 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
116 " mode=\"visibility\"\n"
117 " property=\"Representation\"\n"
118 " value=\"Bivariate Noise Surface\"/>\n"
119 " </Hints>\n"
120 " </PropertyGroup>\n"
121 " </ExposedProperties>\n"
122 " </SubProxy>\n"
123 " <!-- End of GeometryRepresentation Extension -->\n"
124 " </Extension>\n"
125 "\n"
126 " <Extension name=\"UnstructuredGridRepresentation\">\n"
127 " <Documentation>\n"
128 " Extends standard UnstructuredGridRepresentation by adding\n"
129 " BivariateNoiseRepresentation as a new type of representation.\n"
130 " </Documentation>\n"
131 "\n"
132 " <RepresentationType subproxy=\"BivariateNoiseRepresentation\"\n"
133 " text=\"Bivariate Noise Surface\"\n"
134 " subtype=\"Surface\"/>\n"
135 "\n"
136 " <SubProxy>\n"
137 " <Proxy name=\"BivariateNoiseRepresentation\"\n"
138 " proxygroup=\"representations\"\n"
139 " proxyname=\"BivariateNoiseRepresentation\">\n"
140 " </Proxy>\n"
141 "\n"
142 " <ShareProperties subproxy=\"SurfaceRepresentation\">\n"
143 " <Exception name=\"Input\"/>\n"
144 " <Exception name=\"Visibility\"/>\n"
145 " <Exception name=\"Representation\"/>\n"
146 " </ShareProperties>\n"
147 "\n"
148 " <ExposedProperties>\n"
149 " <PropertyGroup label=\"Bivariate representation\">\n"
150 " <Property name=\"NoiseArray\"/>\n"
151 " <Property name=\"Granularity\"/>\n"
152 " <Property name=\"Amplitude\"/>\n"
153 " <Property name=\"AnimationSpeedFactor\"/>\n"
154 " <Property name=\"NbOfOctaves\"/>\n"
155 " <Hints>\n"
156 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
157 " mode=\"visibility\"\n"
158 " property=\"Representation\"\n"
159 " value=\"Bivariate Noise Surface\"/>\n"
160 " </Hints>\n"
161 " </PropertyGroup>\n"
162 " </ExposedProperties>\n"
163 " </SubProxy>\n"
164 " <!-- End of UnstructuredGridRepresentation Extension -->\n"
165 " </Extension>\n"
166 "\n"
167 " <Extension name=\"UniformGridRepresentation\">\n"
168 " <Documentation>\n"
169 " Extends standard UniformGridRepresentation by adding\n"
170 " BivariateNoiseRepresentation as a new type of representation.\n"
171 " </Documentation>\n"
172 "\n"
173 " <RepresentationType subproxy=\"BivariateNoiseRepresentation\"\n"
174 " text=\"Bivariate Noise Surface\"\n"
175 " subtype=\"Surface\"/>\n"
176 "\n"
177 " <SubProxy>\n"
178 " <Proxy name=\"BivariateNoiseRepresentation\"\n"
179 " proxygroup=\"representations\"\n"
180 " proxyname=\"BivariateNoiseRepresentation\">\n"
181 " </Proxy>\n"
182 "\n"
183 " <ShareProperties subproxy=\"SurfaceRepresentation\">\n"
184 " <Exception name=\"Input\"/>\n"
185 " <Exception name=\"Visibility\"/>\n"
186 " <Exception name=\"Representation\"/>\n"
187 " </ShareProperties>\n"
188 "\n"
189 " <ExposedProperties>\n"
190 " <PropertyGroup label=\"Bivariate representation\">\n"
191 " <Property name=\"NoiseArray\"/>\n"
192 " <Property name=\"Granularity\"/>\n"
193 " <Property name=\"Amplitude\"/>\n"
194 " <Property name=\"AnimationSpeedFactor\"/>\n"
195 " <Property name=\"NbOfOctaves\"/>\n"
196 " <Hints>\n"
197 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
198 " mode=\"visibility\"\n"
199 " property=\"Representation\"\n"
200 " value=\"Bivariate Noise Surface\"/>\n"
201 " </Hints>\n"
202 " </PropertyGroup>\n"
203 " </ExposedProperties>\n"
204 " </SubProxy>\n"
205 " <!-- End of UniformGridRepresentation Extension -->\n"
206 " </Extension>\n"
207 "\n"
208 " <BivariateTextureRepresentationProxy name=\"BivariateTextureRepresentation\"\n"
209 " class=\"vtkBivariateTextureRepresentation\"\n"
210 " processes=\"client|renderserver|dataserver\"\n"
211 " base_proxygroup=\"representations\"\n"
212 " base_proxyname=\"SurfaceRepresentation\">\n"
213 " <Documentation>\n"
214 " This representation generates 2D texture coordinates from 2 choosen point data arrays\n"
215 " and provide default textures to visualize bi-variate data.\n"
216 " </Documentation>\n"
217 " <StringVectorProperty name=\"SecondArray\"\n"
218 " command=\"SetInputArrayToProcess\"\n"
219 " number_of_elements=\"5\"\n"
220 " element_types=\"int int int int str\"\n"
221 " default_values=\"1 0 0 0 0\">\n"
222 " <ArrayListDomain name=\"array_list\"\n"
223 " attribute_type=\"Scalars\"\n"
224 " input_domain_name=\"input_array_point_1\">\n"
225 " <RequiredProperties>\n"
226 " <Property name=\"Input\" function=\"Input\"/>\n"
227 " </RequiredProperties>\n"
228 " </ArrayListDomain>\n"
229 " <Documentation>\n"
230 " This property specifies the name of the second point data array used to compute texture\n"
231 " coordinates (second component).\n"
232 " </Documentation>\n"
233 " </StringVectorProperty>\n"
234 " <ProxyProperty command=\"SetTexture\"\n"
235 " name=\"BivariateTexture\"\n"
236 " panel_widget=\"texture_selector\"\n"
237 " null_on_empty=\"1\" >\n"
238 " <Documentation>\n"
239 " Set the diffuse color texture.\n"
240 " </Documentation>\n"
241 " <ProxyGroupDomain name=\"groups\">\n"
242 " <Group name=\"textures\" />\n"
243 " </ProxyGroupDomain>\n"
244 " </ProxyProperty>\n"
245 " <DoubleVectorProperty\n"
246 " name=\"XArrayRangeInfo\"\n"
247 " command=\"GetXArrayRange\"\n"
248 " number_of_elements=\"2\"\n"
249 " default_values=\"0 0\"\n"
250 " information_only=\"1\">\n"
251 " </DoubleVectorProperty>\n"
252 " <DoubleVectorProperty\n"
253 " name=\"XArrayRange\"\n"
254 " label=\"X Array Range\"\n"
255 " command=\"SetXArrayRange\"\n"
256 " number_of_elements=\"2\"\n"
257 " default_values=\"0 0\">\n"
258 " <Documentation>\n"
259 " Manual override for the first array range.\n"
260 " </Documentation>\n"
261 " </DoubleVectorProperty>\n"
262 " <DoubleVectorProperty\n"
263 " name=\"YArrayRangeInfo\"\n"
264 " command=\"GetYArrayRange\"\n"
265 " number_of_elements=\"2\"\n"
266 " default_values=\"0 0\"\n"
267 " information_only=\"1\">\n"
268 " </DoubleVectorProperty>\n"
269 " <DoubleVectorProperty\n"
270 " name=\"YArrayRange\"\n"
271 " label=\"Y Array Range\"\n"
272 " command=\"SetYArrayRange\"\n"
273 " number_of_elements=\"2\"\n"
274 " default_values=\"0 0\">\n"
275 " <Documentation>\n"
276 " Manual override for the second array range.\n"
277 " </Documentation>\n"
278 " </DoubleVectorProperty>\n"
279 " <StringVectorProperty\n"
280 " name=\"XArrayName\"\n"
281 " command=\"GetXArrayName\"\n"
282 " number_of_elements=\"1\"\n"
283 " default_values=\"\"\n"
284 " information_only=\"1\">\n"
285 " </StringVectorProperty>\n"
286 " <StringVectorProperty\n"
287 " name=\"YArrayName\"\n"
288 " command=\"GetYArrayName\"\n"
289 " number_of_elements=\"1\"\n"
290 " default_values=\"\"\n"
291 " information_only=\"1\">\n"
292 " </StringVectorProperty>\n"
293 " <!-- End of BivariateTextureRepresentation -->\n"
294 " </BivariateTextureRepresentationProxy>\n"
295 "\n"
296 " <Extension name=\"GeometryRepresentation\">\n"
297 " <Documentation>\n"
298 " Extends standard GeometryRepresentation by adding BivariateTextureRepresentation\n"
299 " as a new type of representation.\n"
300 " </Documentation>\n"
301 "\n"
302 " <RepresentationType subproxy=\"BivariateTextureRepresentation\"\n"
303 " text=\"Bivariate Texture Surface\"\n"
304 " subtype=\"Surface\" />\n"
305 "\n"
306 " <SubProxy>\n"
307 " <Proxy name=\"BivariateTextureRepresentation\"\n"
308 " proxygroup=\"representations\"\n"
309 " proxyname=\"BivariateTextureRepresentation\">\n"
310 " </Proxy>\n"
311 " <ShareProperties subproxy=\"SurfaceRepresentation\">\n"
312 " <Exception name=\"Input\" />\n"
313 " <Exception name=\"Visibility\" />\n"
314 " <Exception name=\"Representation\" />\n"
315 " </ShareProperties>\n"
316 " <ExposedProperties>\n"
317 " <PropertyGroup label=\"Bivariate representation\">\n"
318 " <Property name=\"SecondArray\"/>\n"
319 " <Property name=\"BivariateTexture\"/>\n"
320 " <Property name=\"XArrayRangeInfo\"/>\n"
321 " <Property name=\"YArrayRangeInfo\"/>\n"
322 " <Property name=\"XArrayRange\"/>\n"
323 " <Property name=\"YArrayRange\"/>\n"
324 " <Hints>\n"
325 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
326 " mode=\"visibility\"\n"
327 " property=\"Representation\"\n"
328 " value=\"Bivariate Texture Surface\"/>\n"
329 " </Hints>\n"
330 " </PropertyGroup>\n"
331 " </ExposedProperties>\n"
332 " </SubProxy>\n"
333 " <!-- End of GeometryRepresentation Extension -->\n"
334 " </Extension>\n"
335 "\n"
336 " <Extension name=\"UnstructuredGridRepresentation\">\n"
337 " <Documentation>\n"
338 " Extends standard UnstructuredGridRepresentation by adding BivariateTextureRepresentation\n"
339 " as a new type of representation.\n"
340 " </Documentation>\n"
341 "\n"
342 " <RepresentationType subproxy=\"BivariateTextureRepresentation\"\n"
343 " text=\"Bivariate Texture Surface\"\n"
344 " subtype=\"Surface\" />\n"
345 "\n"
346 " <SubProxy>\n"
347 " <Proxy name=\"BivariateTextureRepresentation\"\n"
348 " proxygroup=\"representations\"\n"
349 " proxyname=\"BivariateTextureRepresentation\">\n"
350 " </Proxy>\n"
351 " <ShareProperties subproxy=\"SurfaceRepresentation\">\n"
352 " <Exception name=\"Input\" />\n"
353 " <Exception name=\"Visibility\" />\n"
354 " <Exception name=\"Representation\" />\n"
355 " </ShareProperties>\n"
356 " <ExposedProperties>\n"
357 " <PropertyGroup label=\"Bivariate representation\">\n"
358 " <Property name=\"SecondArray\"/>\n"
359 " <Property name=\"BivariateTexture\"/>\n"
360 " <Property name=\"XArrayRangeInfo\"/>\n"
361 " <Property name=\"YArrayRangeInfo\"/>\n"
362 " <Property name=\"XArrayRange\"/>\n"
363 " <Property name=\"YArrayRange\"/>\n"
364 " <Hints>\n"
365 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
366 " mode=\"visibility\"\n"
367 " property=\"Representation\"\n"
368 " value=\"Bivariate Texture Surface\"/>\n"
369 " </Hints>\n"
370 " </PropertyGroup>\n"
371 " </ExposedProperties>\n"
372 " </SubProxy>\n"
373 " <!-- End of UnstructuredGridRepresentation Extension -->\n"
374 ;
375
376 // From file /builds/gitlab-kitware-sciviz-ci/Plugins/BivariateRepresentations/Representations/BivariateRepresentations.xml
378 " </Extension>\n"
379 "\n"
380 " <Extension name=\"UniformGridRepresentation\">\n"
381 " <Documentation>\n"
382 " Extends standard UniformGridRepresentation by adding BivariateTextureRepresentation\n"
383 " as a new type of representation.\n"
384 " </Documentation>\n"
385 "\n"
386 " <RepresentationType subproxy=\"BivariateTextureRepresentation\"\n"
387 " text=\"Bivariate Texture Surface\"\n"
388 " subtype=\"Surface\" />\n"
389 "\n"
390 " <SubProxy>\n"
391 " <Proxy name=\"BivariateTextureRepresentation\"\n"
392 " proxygroup=\"representations\"\n"
393 " proxyname=\"BivariateTextureRepresentation\">\n"
394 " </Proxy>\n"
395 " <ShareProperties subproxy=\"SurfaceRepresentation\">\n"
396 " <Exception name=\"Input\" />\n"
397 " <Exception name=\"Visibility\" />\n"
398 " <Exception name=\"Representation\" />\n"
399 " </ShareProperties>\n"
400 " <ExposedProperties>\n"
401 " <PropertyGroup label=\"Bivariate representation\">\n"
402 " <Property name=\"SecondArray\"/>\n"
403 " <Property name=\"BivariateTexture\"/>\n"
404 " <Property name=\"XArrayRangeInfo\"/>\n"
405 " <Property name=\"YArrayRangeInfo\"/>\n"
406 " <Property name=\"XArrayRange\"/>\n"
407 " <Property name=\"YArrayRange\"/>\n"
408 " <Hints>\n"
409 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
410 " mode=\"visibility\"\n"
411 " property=\"Representation\"\n"
412 " value=\"Bivariate Texture Surface\"/>\n"
413 " </Hints>\n"
414 " </PropertyGroup>\n"
415 " </ExposedProperties>\n"
416 " </SubProxy>\n"
417 " <!-- End of UniformGridRepresentation Extension -->\n"
418 " </Extension>\n"
419 " </ProxyGroup>\n"
420 "\n"
421 " <ProxyGroup name=\"annotations\">\n"
422 " <Proxy class=\"vtkContext2DTexturedScalarBarActor\"\n"
423 " name=\"TexturedScalarBarActor\">\n"
424 " <ProxyProperty command=\"SetLookupTable\"\n"
425 " name=\"LookupTable\"\n"
426 " number_of_elements=\"1\">\n"
427 " <ProxyGroupDomain name=\"groups\">\n"
428 " <Group name=\"lookup_tables\"/>\n"
429 " </ProxyGroupDomain>\n"
430 " </ProxyProperty>\n"
431 " <IntVectorProperty command=\"GetEstimatedNumberOfAnnotations\"\n"
432 " information_only=\"1\"\n"
433 " name=\"EstimatedNumberOfAnnotations\">\n"
434 " <SimpleIntInformationHelper/>\n"
435 " </IntVectorProperty>\n"
436 " <IntVectorProperty animateable=\"0\"\n"
437 " command=\"SetVisibility\"\n"
438 " default_values=\"1\"\n"
439 " name=\"Visibility\"\n"
440 " number_of_elements=\"1\">\n"
441 " <BooleanDomain name=\"bool\"/>\n"
442 " </IntVectorProperty>\n"
443 " <StringVectorProperty animateable=\"0\"\n"
444 " command=\"SetTitle\"\n"
445 " default_values=\"Name\"\n"
446 " no_custom_default=\"1\"\n"
447 " name=\"FirstTitle\"\n"
448 " label=\"First Title (vertical)\"\n"
449 " number_of_elements=\"1\">\n"
450 " <Documentation>\n"
451 " Set the first title text with respect to the color legend.\n"
452 " </Documentation>\n"
453 " </StringVectorProperty>\n"
454 " <StringVectorProperty animateable=\"0\"\n"
455 " command=\"SetTitle2\"\n"
456 " default_values=\"Name\"\n"
457 " no_custom_default=\"1\"\n"
458 " name=\"SecondTitle\"\n"
459 " label=\"Second Title (horizontal)\"\n"
460 " number_of_elements=\"1\">\n"
461 " <Documentation>\n"
462 " Set the second title text with respect to the color legend.\n"
463 " </Documentation>\n"
464 " </StringVectorProperty>\n"
465 " <DoubleVectorProperty command=\"SetFirstRange\"\n"
466 " name=\"FirstRange\"\n"
467 " number_of_elements=\"2\"\n"
468 " default_values=\"0 0\">\n"
469 " <Documentation>\n"
470 " Set the first (vertical) axis range of the color legend.\n"
471 " </Documentation>\n"
472 " </DoubleVectorProperty>\n"
473 " <DoubleVectorProperty command=\"SetSecondRange\"\n"
474 " name=\"SecondRange\"\n"
475 " number_of_elements=\"2\"\n"
476 " default_values=\"0 0\">\n"
477 " <Documentation>\n"
478 " Set the second (horizontal) axis range of the color legend.\n"
479 " </Documentation>\n"
480 " </DoubleVectorProperty>\n"
481 " <StringVectorProperty animateable=\"0\"\n"
482 " command=\"SetComponentTitle\"\n"
483 " default_values=\"\"\n"
484 " no_custom_default=\"1\"\n"
485 " name=\"ComponentTitle\"\n"
486 " number_of_elements=\"1\">\n"
487 " <Documentation>\n"
488 " Set the component title text with respect to the color legend.\n"
489 " </Documentation>\n"
490 " </StringVectorProperty>\n"
491 " <IntVectorProperty animateable=\"0\"\n"
492 " command=\"SetTitleJustification\"\n"
493 " default_values=\"1\"\n"
494 " name=\"TitleJustification\"\n"
495 " number_of_elements=\"1\">\n"
496 " <EnumerationDomain name=\"enum\">\n"
497 " <Entry text=\"Left\"\n"
498 " value=\"0\"/>\n"
499 " <Entry text=\"Centered\"\n"
500 " value=\"1\"/>\n"
501 " <Entry text=\"Right\"\n"
502 " value=\"2\"/>\n"
503 " </EnumerationDomain>\n"
504 " <Documentation>\n"
505 " Set the justification of the title text with respect to the color legend.\n"
506 " </Documentation>\n"
507 " </IntVectorProperty>\n"
508 " <IntVectorProperty command=\"SetDrawBackground\"\n"
509 " name=\"DrawBackground\"\n"
510 " number_of_elements=\"1\"\n"
511 " default_values=\"0\">\n"
512 " <BooleanDomain name=\"bool\"/>\n"
513 " <Documentation>\n"
514 " Enable drawing a background behind the color legend.\n"
515 " </Documentation>\n"
516 " </IntVectorProperty>\n"
517 " <DoubleVectorProperty animateable=\"0\"\n"
518 " command=\"SetBackgroundColor\"\n"
519 " default_values=\"1 1 1 0.5\"\n"
520 " name=\"BackgroundColor\"\n"
521 " panel_widget=\"color_selector\"\n"
522 " number_of_elements=\"4\">\n"
523 " <DoubleRangeDomain max=\"1 1 1 1\"\n"
524 " min=\"0 0 0 0\"\n"
525 " name=\"range\"/>\n"
526 " <Documentation>\n"
527 " Set the color and opacity of the background behind the color legend.\n"
528 " </Documentation>\n"
529 " <Hints>\n"
530 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
531 " <Property name=\"DrawBackground\" function=\"boolean\" index=\"0\"/>\n"
532 " </PropertyWidgetDecorator>\n"
533 " </Hints>\n"
534 " </DoubleVectorProperty>\n"
535 " <DoubleVectorProperty command=\"SetBackgroundPadding\"\n"
536 " default_values=\"2.0\"\n"
537 " name=\"BackgroundPadding\"\n"
538 " number_of_elements=\"1\">\n"
539 " <DoubleRangeDomain min=\"0\"/>\n"
540 " <Documentation>\n"
541 " Set the amount of padding around the outermost elements of the color legend when the background is drawn.\n"
542 " </Documentation>\n"
543 " <Hints>\n"
544 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
545 " <Property name=\"DrawBackground\" function=\"boolean\" index=\"0\"/>\n"
546 " </PropertyWidgetDecorator>\n"
547 " </Hints>\n"
548 " </DoubleVectorProperty>\n"
549 " <DoubleVectorProperty command=\"SetScalarBarLength\"\n"
550 " default_values=\"0.15\"\n"
551 " name=\"ScalarBarLength\"\n"
552 " label=\"Color Bar Size\"\n"
553 " number_of_elements=\"1\">\n"
554 " <Documentation>\n"
555 " Sets the size of the 2D scalar bar. This correspond to the size of the side of the texture square\n"
556 " (in the viewport space). Value is clamped between 0 and 1.\n"
557 " </Documentation>\n"
558 " </DoubleVectorProperty>\n"
559 " <IntVectorProperty command=\"SetDrawScalarBarOutline\"\n"
560 " default_values=\"1\"\n"
561 " name=\"DrawScalarBarOutline\"\n"
562 " number_of_elements=\"1\">\n"
563 " <BooleanDomain name=\"bool\"/>\n"
564 " <Documentation>\n"
565 " Draws an outline around the scalar bar.\n"
566 " </Documentation>\n"
567 " </IntVectorProperty>\n"
568 " <DoubleVectorProperty command=\"SetScalarBarOutlineColor\"\n"
569 " default_values=\"1 1 1\"\n"
570 " name=\"ScalarBarOutlineColor\"\n"
571 " number_of_elements=\"3\"\n"
572 " panel_widget=\"color_selector\">\n"
573 " <Documentation>\n"
574 " Color of the outline drawn around the scalar bar if it is shown.\n"
575 " </Documentation>\n"
576 " <Hints>\n"
577 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
578 " <Property name=\"DrawScalarBarOutline\" function=\"boolean\" index=\"0\"/>\n"
579 " </PropertyWidgetDecorator>\n"
580 " </Hints>\n"
581 " </DoubleVectorProperty>\n"
582 " <IntVectorProperty command=\"SetScalarBarOutlineThickness\"\n"
583 " default_values=\"1\"\n"
584 " name=\"ScalarBarOutlineThickness\"\n"
585 " number_of_elements=\"1\">\n"
586 " <Documentation>\n"
587 " Set the thickness, in pixels, of the outline drawn around the scalar bar.\n"
588 " </Documentation>\n"
589 " <Hints>\n"
590 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
591 " <Property name=\"DrawScalarBarOutline\" function=\"boolean\" index=\"0\"/>\n"
592 " </PropertyWidgetDecorator>\n"
593 " </Hints>\n"
594 " </IntVectorProperty>\n"
595 " <IntVectorProperty command=\"SetAutomaticLabelFormat\"\n"
596 " default_values=\"1\"\n"
597 " name=\"AutomaticLabelFormat\"\n"
598 " number_of_elements=\"1\">\n"
599 " <BooleanDomain name=\"bool\"/>\n"
600 " <Documentation>\n"
601 " Set if the number format used for the labels (specified as a C-style printf format string) will be\n"
602 " automatically generated to make\n"
603 " the numbers best fit within the widget. When off, the Label Format property will be used.\n"
604 " </Documentation>\n"
605 " </IntVectorProperty>\n"
606 " <StringVectorProperty animateable=\"0\"\n"
607 " command=\"SetLabelFormat\"\n"
608 " default_values=\"{:&lt;#6.3g}\"\n"
609 " name=\"LabelFormat\"\n"
610 " number_of_elements=\"1\">\n"
611 " <Hints>\n"
612 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
613 " <Property name=\"AutomaticLabelFormat\" function=\"boolean_invert\" index=\"0\"/>\n"
614 " </PropertyWidgetDecorator>\n"
615 " </Hints>\n"
616 " <Documentation>\n"
617 " Set the number format (specified as a C-style printf format string) with which to print the labels on the\n"
618 " color legend.\n"
619 " Can be used only if Automatic Label Format is off.\n"
620 " </Documentation>\n"
621 " </StringVectorProperty>\n"
622 " <IntVectorProperty command=\"SetAddRangeLabels\"\n"
623 " number_of_elements=\"1\"\n"
624 " default_values=\"1\"\n"
625 " name=\"AddRangeLabels\"\n"
626 " label=\"Add Range Labels\">\n"
627 " <BooleanDomain name=\"bool\"/>\n"
628 " <Documentation>\n"
629 " Set whether to add range labels or not. These are labels that have\n"
630 " the minimum/maximum values of the color legend range.\n"
631 " </Documentation>\n"
632 " </IntVectorProperty>\n"
633 " <StringVectorProperty animateable=\"0\"\n"
634 " command=\"SetRangeLabelFormat\"\n"
635 " number_of_elements=\"1\"\n"
636 " default_values=\"{:&lt;#6.1e}\"\n"
637 " name=\"RangeLabelFormat\"\n"
638 " label=\"Range Label Format\">\n"
639 " <Hints>\n"
640 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
641 " <Property name=\"AddRangeLabels\" function=\"boolean\" index=\"0\"/>\n"
642 " </PropertyWidgetDecorator>\n"
643 " </Hints>\n"
644 " <Documentation>\n"
645 " Set number format for range labels (specified as a C-style printf format string). Can be used only if Add\n"
646 " Range Labels is enabled.\n"
647 " </Documentation>\n"
648 " </StringVectorProperty>\n"
649 " <IntVectorProperty animateable=\"0\"\n"
650 " command=\"SetDrawTickMarks\"\n"
651 " default_values=\"1\"\n"
652 " name=\"DrawTickMarks\"\n"
653 " number_of_elements=\"1\">\n"
654 " <BooleanDomain name=\"bool\"/>\n"
655 " <Documentation>\n"
656 " Enable/disable drawing the color legend tick marks.\n"
657 " </Documentation>\n"
658 " </IntVectorProperty>\n"
659 " <IntVectorProperty animateable=\"0\"\n"
660 " command=\"SetDrawTickLabels\"\n"
661 " default_values=\"1\"\n"
662 " name=\"DrawTickLabels\"\n"
663 " number_of_elements=\"1\">\n"
664 " <BooleanDomain name=\"bool\"/>\n"
665 " <Documentation>\n"
666 " Enable/disable drawing the color legend labels for tick marks.\n"
667 " </Documentation>\n"
668 " </IntVectorProperty>\n"
669 " <IntVectorProperty animateable=\"0\"\n"
670 " command=\"SetUseCustomLabels\"\n"
671 " name=\"UseCustomLabels\"\n"
672 " number_of_elements=\"1\"\n"
673 " default_values=\"0\">\n"
674 " <BooleanDomain name=\"bool\"/>\n"
675 " <Documentation>\n"
676 " Enable the use of custom label values.\n"
677 " </Documentation>\n"
678 " </IntVectorProperty>\n"
679 " <DoubleVectorProperty command=\"SetCustomLabel\"\n"
680 " name=\"CustomLabels\"\n"
681 " set_number_command=\"SetNumberOfCustomLabels\"\n"
682 " number_of_elements=\"0\"\n"
683 " number_of_elements_per_command=\"1\"\n"
684 " repeat_command=\"1\"\n"
685 " use_index=\"1\">\n"
686 " <Hints>\n"
687 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
688 " <Property name=\"UseCustomLabels\" function=\"boolean\"/>\n"
689 " </PropertyWidgetDecorator>\n"
690 " </Hints>\n"
691 " </DoubleVectorProperty>\n"
692 " <IntVectorProperty animateable=\"0\"\n"
693 " command=\"SetTextPosition\"\n"
694 " default_values=\"1\"\n"
695 " name=\"TextPosition\"\n"
696 " label=\"Annotations Position\"\n"
697 " number_of_elements=\"1\">\n"
698 " <EnumerationDomain name=\"enum\">\n"
699 " <Entry text=\"Right and top\"\n"
700 " value=\"1\"/>\n"
701 " <Entry text=\"Left and bottom\"\n"
702 " value=\"0\"/>\n"
703 " </EnumerationDomain>\n"
704 " <Documentation>\n"
705 " Determines where the ticks, titles and labels are drawn.\n"
706 ;
707
708 // From file /builds/gitlab-kitware-sciviz-ci/Plugins/BivariateRepresentations/Representations/BivariateRepresentations.xml
710 " </Documentation>\n"
711 " </IntVectorProperty>\n"
712 " <ProxyProperty command=\"SetTexture\"\n"
713 " name=\"Texture\"\n"
714 " panel_widget=\"texture_selector\"\n"
715 " null_on_empty=\"1\" >\n"
716 " <Documentation>\n"
717 " Set the texture displayed in the scalar bar.\n"
718 " </Documentation>\n"
719 " <ProxyGroupDomain name=\"groups\">\n"
720 " <Group name=\"textures\" />\n"
721 " </ProxyGroupDomain>\n"
722 " <Hints>\n"
723 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
724 " mode=\"visibility\"\n"
725 " property=\"Interpolation\"\n"
726 " value=\"3\"\n"
727 " inverse=\"1\" />\n"
728 " <TextureSelectorWidget check_tcoords=\"1\" />\n"
729 " <!-- enable the texture selector only when tcoords is available. -->\n"
730 " </Hints>\n"
731 " </ProxyProperty>\n"
732 " <!--label text property -->\n"
733 " <SubProxy command=\"SetLabelTextProperty\">\n"
734 " <Proxy name=\"LabelTextProperty\"\n"
735 " proxygroup=\"properties\"\n"
736 " proxyname=\"TextProperty\"></Proxy>\n"
737 " <ExposedProperties>\n"
738 " <Property exposed_name=\"LabelColor\"\n"
739 " name=\"Color\"/>\n"
740 " <Property exposed_name=\"LabelOpacity\"\n"
741 " name=\"Opacity\"/>\n"
742 " <Property exposed_name=\"LabelFontFamily\"\n"
743 " name=\"FontFamily\"/>\n"
744 " <Property exposed_name=\"LabelFontFile\"\n"
745 " name=\"FontFile\"/>\n"
746 " <Property exposed_name=\"LabelBold\"\n"
747 " name=\"Bold\"/>\n"
748 " <Property exposed_name=\"LabelItalic\"\n"
749 " name=\"Italic\"/>\n"
750 " <Property exposed_name=\"LabelShadow\"\n"
751 " name=\"Shadow\"/>\n"
752 " <Property exposed_name=\"LabelFontSize\"\n"
753 " name=\"FontSize\"/>\n"
754 " </ExposedProperties>\n"
755 " </SubProxy>\n"
756 " <!--title text property -->\n"
757 " <SubProxy command=\"SetTitleTextProperty\">\n"
758 " <Proxy name=\"TitleTextProperty\"\n"
759 " proxygroup=\"properties\"\n"
760 " proxyname=\"TextProperty\"></Proxy>\n"
761 " <ExposedProperties>\n"
762 " <Property exposed_name=\"TitleColor\"\n"
763 " name=\"Color\"/>\n"
764 " <Property exposed_name=\"TitleOpacity\"\n"
765 " name=\"Opacity\"/>\n"
766 " <Property exposed_name=\"TitleFontFamily\"\n"
767 " name=\"FontFamily\"/>\n"
768 " <Property exposed_name=\"TitleFontFile\"\n"
769 " name=\"FontFile\"/>\n"
770 " <Property exposed_name=\"TitleBold\"\n"
771 " name=\"Bold\"/>\n"
772 " <Property exposed_name=\"TitleItalic\"\n"
773 " name=\"Italic\"/>\n"
774 " <Property exposed_name=\"TitleShadow\"\n"
775 " name=\"Shadow\"/>\n"
776 " <Property exposed_name=\"TitleFontSize\"\n"
777 " name=\"FontSize\"/>\n"
778 " </ExposedProperties>\n"
779 " </SubProxy>\n"
780 " <!-- End of TexturedScalarBarActor -->\n"
781 " </Proxy>\n"
782 " </ProxyGroup>\n"
783 "\n"
784 " <!-- ProxyGroup should be different from \"representations\" since this ScalarBarWidgetRepresentationProxy name -->\n"
785 " <!-- Has to be the same than the one defined in ParaView. This proxy name is used to retrieve the scalar bar -->\n"
786 " <!-- proxy and is not parametrable yet (see vtkSMTransferFunctionProxy::FindScalarBarRepresentation) -->\n"
787 " <ProxyGroup name=\"CustomScalarBarWidgetRepresentation\">\n"
788 " <Proxy class=\"vtkContext2DTexturedScalarBarRepresentation\"\n"
789 " name=\"ScalarBarRepresentation\">\n"
790 " <IntVectorProperty animateable=\"1\"\n"
791 " command=\"SetVisibility\"\n"
792 " default_values=\"1\"\n"
793 " name=\"Visibility\"\n"
794 " number_of_elements=\"1\">\n"
795 " <BooleanDomain name=\"bool\" />\n"
796 " </IntVectorProperty>\n"
797 " <DoubleVectorProperty command=\"SetPosition\"\n"
798 " default_values=\"0.89 0.02\"\n"
799 " information_property=\"PositionInfo\"\n"
800 " name=\"Position\"\n"
801 " number_of_elements=\"2\">\n"
802 " <DoubleRangeDomain max=\"1 1\"\n"
803 " min=\"0 0\"\n"
804 " name=\"range\" />\n"
805 " <Documentation>\n"
806 " Specify the anchor position (bottom-left corner of the scalar bar) in normalized\n"
807 " viewport coordinates in range [0, 1]. This is used only when **Window Location**\n"
808 " is set to **AnyLocation**.\n"
809 " </Documentation>\n"
810 " <Hints>\n"
811 " <!-- Enable \"Position\" widget only when WindowLocation == AnyLocation -->\n"
812 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
813 " mode=\"enabled_state\"\n"
814 " property=\"WindowLocation\"\n"
815 " value=\"0\" />\n"
816 " </Hints>\n"
817 " </DoubleVectorProperty>\n"
818 " <DoubleVectorProperty command=\"GetPosition\"\n"
819 " information_only=\"1\"\n"
820 " name=\"PositionInfo\">\n"
821 " <SimpleDoubleInformationHelper />\n"
822 " </DoubleVectorProperty>\n"
823 " <IntVectorProperty command=\"SetAutoOrient\"\n"
824 " default_values=\"0\"\n"
825 " name=\"AutoOrient\"\n"
826 " number_of_elements=\"1\">\n"
827 " <BooleanDomain name=\"bool\" />\n"
828 " <Hints>\n"
829 " <NoDefault />\n"
830 " </Hints>\n"
831 " <Documentation>\n"
832 " Set if color legend's orientation will be updated based on its position.\n"
833 " This parameter as no effect in the case of this scalar bar representation.\n"
834 " </Documentation>\n"
835 " </IntVectorProperty>\n"
836 " <IntVectorProperty command=\"GetAutoOrient\"\n"
837 " information_only=\"1\"\n"
838 " name=\"AutoOrientInfo\">\n"
839 " <BooleanDomain name=\"bool\" />\n"
840 " </IntVectorProperty>\n"
841 " <IntVectorProperty command=\"SetOrientation\"\n"
842 " default_values=\"1\"\n"
843 " information_property=\"OrientationInfo\"\n"
844 " name=\"Orientation\"\n"
845 " number_of_elements=\"1\">\n"
846 " <Hints>\n"
847 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
848 " <Property name=\"AutoOrient\" function=\"boolean_invert\" index=\"0\" />\n"
849 " </PropertyWidgetDecorator>\n"
850 " <NoDefault />\n"
851 " </Hints>\n"
852 " <EnumerationDomain name=\"enum\">\n"
853 " <Entry text=\"Horizontal\"\n"
854 " value=\"0\" />\n"
855 " <Entry text=\"Vertical\"\n"
856 " value=\"1\" />\n"
857 " </EnumerationDomain>\n"
858 " <Documentation>\n"
859 " Specify orientation of the color legend. Can be used only if Auto Orient is disabled.\n"
860 " This parameter as no effect in the case of this scalar bar representation.\n"
861 " </Documentation>\n"
862 " </IntVectorProperty>\n"
863 " <IntVectorProperty command=\"GetOrientation\"\n"
864 " information_only=\"1\"\n"
865 " name=\"OrientationInfo\">\n"
866 " <SimpleIntInformationHelper />\n"
867 " </IntVectorProperty>\n"
868 " <IntVectorProperty command=\"SetWindowLocation\"\n"
869 " default_values=\"2\"\n"
870 " name=\"WindowLocation\"\n"
871 " number_of_elements=\"1\">\n"
872 " <EnumerationDomain name=\"enum\">\n"
873 " <Entry text=\"Any Location\"\n"
874 " value=\"0\" />\n"
875 " <Entry text=\"Lower Left Corner\"\n"
876 " value=\"1\" />\n"
877 " <Entry text=\"Lower Right Corner\"\n"
878 " value=\"2\" />\n"
879 " <Entry text=\"Lower Center\"\n"
880 " value=\"3\" />\n"
881 " <Entry text=\"Upper Left Corner\"\n"
882 " value=\"4\" />\n"
883 " <Entry text=\"Upper Right Corner\"\n"
884 " value=\"5\" />\n"
885 " <Entry text=\"Upper Center\"\n"
886 " value=\"6\" />\n"
887 " </EnumerationDomain>\n"
888 " <Documentation>\n"
889 " Specify placement of the color legend.\n"
890 " </Documentation>\n"
891 " </IntVectorProperty>\n"
892 " <ProxyProperty command=\"SetScalarBarActor\"\n"
893 " name=\"ScalarBarActor\">\n"
894 " <ProxyGroupDomain name=\"groups\">\n"
895 " <Group name=\"annotations\" />\n"
896 " </ProxyGroupDomain>\n"
897 " </ProxyProperty>\n"
898 " <!-- End of ScalarBarRepresentation -->\n"
899 " </Proxy>\n"
900 "\n"
901 " <ScalarBarWidgetRepresentationProxy class=\"vtk3DWidgetRepresentation\"\n"
902 " name=\"ScalarBarWidgetRepresentation\">\n"
903 " <Documentation>\n"
904 " This custom ScalarBarWidgetRepresentation is used for displaying the textured 2D\n"
905 " scalar bar including a widget to control the position and the size of the scalar bar.\n"
906 " </Documentation>\n"
907 " <IntVectorProperty command=\"SetEnabled\"\n"
908 " default_values=\"1\"\n"
909 " name=\"Enabled\"\n"
910 " number_of_elements=\"1\"\n"
911 " panel_visibility=\"never\" >\n"
912 " <BooleanDomain name=\"bool\" />\n"
913 " <Documentation>\n"
914 " Enable/Disable widget interaction.\n"
915 " </Documentation>\n"
916 " </IntVectorProperty>\n"
917 " <IntVectorProperty command=\"SetUseNonCompositedRenderer\"\n"
918 " default_values=\"1\"\n"
919 " name=\"UseNonCompositedRenderer\"\n"
920 " number_of_elements=\"1\"\n"
921 " panel_visibility=\"never\"></IntVectorProperty>\n"
922 " <IntVectorProperty default_values=\"0\"\n"
923 " name=\"LockPosition\"\n"
924 " number_of_elements=\"1\"\n"
925 " panel_visibility=\"never\">\n"
926 " <BooleanDomain name=\"bool\" />\n"
927 " <Documentation>\n"
928 " Set this to 1 if you don't want the application to change the scalar bar position\n"
929 " when placing automatically.\n"
930 " </Documentation>\n"
931 " </IntVectorProperty>\n"
932 " <IntVectorProperty name=\"StickyVisible\"\n"
933 " default_values=\"1\"\n"
934 " panel_visibility=\"never\">\n"
935 " <BooleanDomain name=\"bool\" />\n"
936 " <Documentation>\n"
937 " If the user manually toggles the scalar bar visibility, we keep that information\n"
938 " in the scalar bar representation, and will never / always show it until the\n"
939 " scalar bar button is toggled again on this array.\n"
940 " </Documentation>\n"
941 " </IntVectorProperty>\n"
942 " <SubProxy>\n"
943 " <Proxy name=\"Prop2D\"\n"
944 " proxygroup=\"CustomScalarBarWidgetRepresentation\"\n"
945 " proxyname=\"ScalarBarRepresentation\"></Proxy>\n"
946 " <ExposedProperties>\n"
947 " <Property name=\"Visibility\" panel_visibility=\"never\"/>\n"
948 " <Property name=\"ScalarBarActor\" panel_visibility=\"never\"/>\n"
949 " <PropertyGroup label=\"Layout\">\n"
950 " <Property name=\"AutoOrient\" panel_visibility=\"never\"/>\n"
951 " <Property name=\"AutoOrientInfo\" />\n"
952 " <Property name=\"Orientation\" panel_visibility=\"never\"/>\n"
953 " <Property name=\"OrientationInfo\" />\n"
954 " <Property name=\"WindowLocation\" />\n"
955 " <Property name=\"Position\" />\n"
956 " <Property name=\"PositionInfo\" />\n"
957 " </PropertyGroup>\n"
958 " </ExposedProperties>\n"
959 " </SubProxy>\n"
960 " <SubProxy>\n"
961 " <Proxy name=\"Prop2DActor\"\n"
962 " proxygroup=\"annotations\"\n"
963 " proxyname=\"TexturedScalarBarActor\"></Proxy>\n"
964 "\n"
965 " <ExposedProperties>\n"
966 " <Property name=\"EstimatedNumberOfAnnotations\" panel_visibility=\"never\"/>\n"
967 " <Property name=\"LookupTable\" panel_visibility=\"never\" />\n"
968 " <Property name=\"FirstRange\" panel_visibility=\"never\" />\n"
969 " <Property name=\"SecondRange\" panel_visibility=\"never\" />\n"
970 " <!-- Appearance -->\n"
971 " <PropertyGroup label=\"General Appearance\">\n"
972 " <Property name=\"Texture\" />\n"
973 " <Property name=\"ScalarBarLength\" />\n"
974 " <Property name=\"TextPosition\" />\n"
975 " <Property name=\"DrawBackground\" panel_visibility=\"advanced\" />\n"
976 " <Property name=\"BackgroundColor\" panel_visibility=\"advanced\" />\n"
977 " <Property name=\"BackgroundPadding\" panel_visibility=\"advanced\" />\n"
978 " <Property name=\"DrawScalarBarOutline\" panel_visibility=\"advanced\" />\n"
979 " <Property name=\"ScalarBarOutlineColor\" panel_visibility=\"advanced\" />\n"
980 " <Property name=\"ScalarBarOutlineThickness\" panel_visibility=\"advanced\" />\n"
981 " </PropertyGroup>\n"
982 " <!-- Axis titles -->\n"
983 " <PropertyGroup label=\"Axis Titles\">\n"
984 " <Property name=\"FirstTitle\" />\n"
985 " <Property name=\"SecondTitle\" />\n"
986 " <Property name=\"ComponentTitle\" />\n"
987 " <Property name=\"TitleJustification\" />\n"
988 " </PropertyGroup>\n"
989 " <!-- Properties for Title -->\n"
990 " <PropertyGroup label=\"Axis Titles Font Properties\"\n"
991 " panel_widget=\"FontEditor\">\n"
992 " <Property name=\"TitleColor\" function=\"Color\"/>\n"
993 " <Property name=\"TitleOpacity\" function=\"Opacity\"/>\n"
994 " <Property name=\"TitleFontFamily\" function=\"Family\"/>\n"
995 " <Property name=\"TitleFontFile\" function=\"File\"/>\n"
996 " <Property name=\"TitleBold\" function=\"Bold\" />\n"
997 " <Property name=\"TitleItalic\" function=\"Italics\"/>\n"
998 " <Property name=\"TitleShadow\" function=\"Shadow\" />\n"
999 " <Property name=\"TitleFontSize\" function=\"Size\"\n"
1000 " number_of_elements=\"1\" default_values=\"16\" />\n"
1001 " </PropertyGroup>\n"
1002 " <!-- Ticks and Labels -->\n"
1003 " <PropertyGroup label=\"Ticks and Labels\">\n"
1004 " <Property name=\"AutomaticLabelFormat\" panel_visibility=\"advanced\" />\n"
1005 " <Property name=\"LabelFormat\" panel_visibility=\"advanced\" />\n"
1006 " <Property name=\"DrawTickMarks\" panel_visibility=\"advanced\" />\n"
1007 " <Property name=\"DrawTickLabels\" panel_visibility=\"advanced\" />\n"
1008 " <Property name=\"UseCustomLabels\" panel_visibility=\"advanced\" />\n"
1009 " <Property name=\"CustomLabels\" panel_visibility=\"advanced\" />\n"
1010 " <Property name=\"AddRangeLabels\" panel_visibility=\"advanced\" />\n"
1011 " <Property name=\"RangeLabelFormat\" panel_visibility=\"advanced\" />\n"
1012 " </PropertyGroup>\n"
1013 " <!-- Properties for Label -->\n"
1014 " <PropertyGroup label=\"Labels Font Properties\"\n"
1015 " panel_widget=\"FontEditor\">\n"
1016 " <Property name=\"LabelColor\" function=\"Color\"/>\n"
1017 " <Property name=\"LabelOpacity\" function=\"Opacity\" />\n"
1018 " <Property name=\"LabelFontFamily\" function=\"Family\"/>\n"
1019 " <Property name=\"LabelFontFile\" function=\"File\"/>\n"
1020 " <Property name=\"LabelBold\" function=\"Bold\" />\n"
1021 " <Property name=\"LabelItalic\" function=\"Italics\" />\n"
1022 " <Property name=\"LabelShadow\" function=\"Shadow\" />\n"
1023 " <Property name=\"LabelFontSize\" function=\"Size\"\n"
1024 ;
1025
1026 // From file /builds/gitlab-kitware-sciviz-ci/Plugins/BivariateRepresentations/Representations/BivariateRepresentations.xml
1028 " number_of_elements=\"1\" default_values=\"16\"/>\n"
1029 " </PropertyGroup>\n"
1030 " </ExposedProperties>\n"
1031 " </SubProxy>\n"
1032 " <SubProxy>\n"
1033 " <Proxy name=\"Widget\"\n"
1034 " proxygroup=\"3d_widgets\"\n"
1035 " proxyname=\"ScalarBarWidget\"></Proxy>\n"
1036 " <ExposedProperties>\n"
1037 " <Property name=\"Selectable\" panel_visibility=\"never\"/>\n"
1038 " <Property name=\"Resizable\" panel_visibility=\"never\"/>\n"
1039 " <Property name=\"Repositionable\" panel_visibility=\"never\"/>\n"
1040 " </ExposedProperties>\n"
1041 " </SubProxy>\n"
1042 " <!-- End of ScalarBarWidgetRepresentation -->\n"
1043 " </ScalarBarWidgetRepresentationProxy>\n"
1044 " </ProxyGroup>\n"
1045 "</ServerManagerConfiguration>\n"
1046 "\n";
1047 // Get single string
1049 {
1050
1055  size_t len = ( 0
1056  + len0
1057  + len1
1058  + len2
1059  + len3 );
1060  char* res = new char[ len + 1];
1061  size_t offset = 0;
1066  assert(offset == len);
1067  res[offset] = 0;
1068  return res;
1069 }
1070
1071
1072
1073 #endif
offset
static const char *const BivariateRepresentations_server_manager_modulesBivariateRepresentationsInterface1
char * BivariateRepresentations_server_manager_modulesBivariateRepresentationsGetInterfaces()
static const char *const BivariateRepresentations_server_manager_modulesBivariateRepresentationsInterface3
static const char *const BivariateRepresentations_server_manager_modulesBivariateRepresentationsInterface0
static const char *const BivariateRepresentations_server_manager_modulesBivariateRepresentationsInterface2
