#include "vtkPVAdaptorsCTHModule.h"
| void VTKPVADAPTORSCTH_EXPORT | handler (int sig) |
| void VTKPVADAPTORSCTH_EXPORT | pvspy_qa (char *qadate, char *qatime, char *qajobn) |
| CTH INTERFACE. More... | |
| void VTKPVADAPTORSCTH_EXPORT | pvspy_fil (char *filename, int len, char *runid, int *error) |
| int VTKPVADAPTORSCTH_EXPORT | pvspy_vizcheck (int cycle, double ptime) |
| void VTKPVADAPTORSCTH_EXPORT | pvspy_viz (int cycle, double ptime, double pdt, int, int) |
| void VTKPVADAPTORSCTH_EXPORT | pvspy_fin () |
| void VTKPVADAPTORSCTH_EXPORT | pvspy_stm (int igm, int n_blocks, int nmat, int max_mat, int NCFieldNames, int NMFieldNames, double *x0, double *x1, int max_level) |
| void VTKPVADAPTORSCTH_EXPORT | pvspy_scf (int field_id, char *field_name, char *comment, int matid) |
| void VTKPVADAPTORSCTH_EXPORT | pvspy_smf (int field_id, char *field_name, char *comment) |
| void VTKPVADAPTORSCTH_EXPORT | pvspy_scx (int block_id, int field_id, int k, int j, double *istrip) |
| void VTKPVADAPTORSCTH_EXPORT | pvspy_smx (int block_id, int field_id, int mat, int k, int j, double *istrip) |
| void VTKPVADAPTORSCTH_EXPORT | pvspy_stb (int block_id, int Nx, int Ny, int Nz, double *x, double *y, double *z, int allocated, int active, int level) |
| void VTKPVADAPTORSCTH_EXPORT | pvspy_sta (int block_id, int allocated, int active, int level, int max_level, int bxbot, int bxtop, int bybot, int bytop, int bzbot, int bztop, int npxma11, int npxma21, int npxma12, int npxma22, int npyma11, int npyma21, int npyma12, int npyma22, int npzma11, int npzma21, int npzma12, int npzma22, int npxpa11, int npxpa21, int npxpa12, int npxpa22, int npypa11, int npypa21, int npypa12, int npypa22, int npzpa11, int npzpa21, int npzpa12, int npzpa22, int nbxma11, int nbxma21, int nbxma12, int nbxma22, int nbyma11, int nbyma21, int nbyma12, int nbyma22, int nbzma11, int nbzma21, int nbzma12, int nbzma22, int nbxpa11, int nbxpa21, int nbxpa12, int nbxpa22, int nbypa11, int nbypa21, int nbypa12, int nbypa22, int nbzpa11, int nbzpa21, int nbzpa12, int nbzpa22) |
| void | pvspy_trc (int num, double *xt, double *yt, double *zt, int *id, int *lt, int *it, int *jt, int *kt) |
| void VTKPVADAPTORSCTH_EXPORT handler | ( | int | sig | ) |
| void VTKPVADAPTORSCTH_EXPORT pvspy_qa | ( | char * | qadate, |
| char * | qatime, | ||
| char * | qajobn | ||
CTH INTERFACE.
C functions prototyped in pvspy_public.h. called from within spy_fortran.c in cth
| void VTKPVADAPTORSCTH_EXPORT pvspy_fil | ( | char * | filename, |
| int | len, | ||
| char * | runid, | ||
| int * | error | ||
| int VTKPVADAPTORSCTH_EXPORT pvspy_vizcheck | ( | int | cycle, |
| double | ptime | ||
| void VTKPVADAPTORSCTH_EXPORT pvspy_fin | ( | ) |
| void VTKPVADAPTORSCTH_EXPORT pvspy_stm | ( | int | igm, |
| int | n_blocks, | ||
| int | nmat, | ||
| int | max_mat, | ||
| int | NCFieldNames, | ||
| int | NMFieldNames, | ||
| double * | x0, | ||
| double * | x1, | ||
| int | max_level | ||
| void VTKPVADAPTORSCTH_EXPORT pvspy_scf | ( | int | field_id, |
| char * | field_name, | ||
| char * | comment, | ||
| int | matid | ||
| void VTKPVADAPTORSCTH_EXPORT pvspy_smf | ( | int | field_id, |
| char * | comment | ||
| void VTKPVADAPTORSCTH_EXPORT pvspy_scx | ( | int | block_id, |
| int | field_id, | ||
| int | k, | ||
| int | j, | ||
| double * | istrip | ||
| void VTKPVADAPTORSCTH_EXPORT pvspy_smx | ( | int | block_id, |
| int | mat, | ||
| int | k, | ||
| int | j, | ||
| void VTKPVADAPTORSCTH_EXPORT pvspy_stb | ( | int | block_id, |
| int | Nx, | ||
| int | Ny, | ||
| int | Nz, | ||
| double * | x, | ||
| double * | y, | ||
| double * | z, | ||
| int | allocated, | ||
| int | active, | ||
| int | level | ||
| void VTKPVADAPTORSCTH_EXPORT pvspy_sta | ( | int | block_id, |
| int | active, | ||
| int | level, | ||
| int | max_level, | ||
| int | bxbot, | ||
| int | bxtop, | ||
| int | bybot, | ||
| int | bytop, | ||
| int | bzbot, | ||
| int | bztop, | ||
| int | npxma11, | ||
| int | npxma21, | ||
| int | npxma12, | ||
| int | npxma22, | ||
| int | npyma11, | ||
| int | npyma21, | ||
| int | npyma12, | ||
| int | npyma22, | ||
| int | npzma11, | ||
| int | npzma21, | ||
| int | npzma12, | ||
| int | npzma22, | ||
| int | npxpa11, | ||
| int | npxpa21, | ||
| int | npxpa12, | ||
| int | npxpa22, | ||
| int | npypa11, | ||
| int | npypa21, | ||
| int | npypa12, | ||
| int | npypa22, | ||
| int | npzpa11, | ||
| int | npzpa21, | ||
| int | npzpa12, | ||
| int | npzpa22, | ||
| int | nbxma11, | ||
| int | nbxma21, | ||
| int | nbxma12, | ||
| int | nbxma22, | ||
| int | nbyma11, | ||
| int | nbyma21, | ||
| int | nbyma12, | ||
| int | nbyma22, | ||
| int | nbzma11, | ||
| int | nbzma21, | ||
| int | nbzma12, | ||
| int | nbzma22, | ||
| int | nbxpa11, | ||
| int | nbxpa21, | ||
| int | nbxpa12, | ||
| int | nbxpa22, | ||
| int | nbypa11, | ||
| int | nbypa21, | ||
| int | nbypa12, | ||
| int | nbypa22, | ||
| int | nbzpa11, | ||
| int | nbzpa21, | ||
| int | nbzpa12, | ||
| int | nbzpa22 | ||
1.8.13 on Sun Dec 14 2025
