EnSightGoldCombinedReader_server_manager_data.h
1 // Loadable modules
2 //
3 // Generated by /builds/gitlab-kitware-sciviz-ci/build/bin/vtkProcessXML-pv6.0
4 //
5 #ifndef EnSightGoldCombinedReader_server_manager_data_h
6 #define EnSightGoldCombinedReader_server_manager_data_h
7
8 #include <cstring>
9 #include <cassert>
10 #include <algorithm>
11
12
13 // From file /builds/gitlab-kitware-sciviz-ci/Plugins/EnSightGoldCombinedReader/EnSightGoldCombinedReader.xml
15 "<ServerManagerConfiguration>\n"
16 " <!-- ==================================================================== -->\n"
17 " <ProxyGroup name=\"sources\">\n"
18 " <SourceProxy name=\"EnSightGoldCombinedReader\"\n"
19 " label=\"EnSight Gold Combined Reader\"\n"
20 " class=\"vtkEnSightGoldCombinedReader\">\n"
21 " <Documentation short_help=\"Read EnSight Gold files.\">\n"
22 " Reader for EnSight Gold binary and ASCII files.\n"
23 " </Documentation>\n"
24 " <DoubleVectorProperty information_only=\"1\"\n"
25 " name=\"TimestepValues\"\n"
26 " repeatable=\"1\">\n"
27 " <TimeStepsInformationHelper />\n"
28 " <Documentation>Available timestep values.</Documentation>\n"
29 " </DoubleVectorProperty>\n"
30 " <StringVectorProperty\n"
31 " name=\"CaseFileName\"\n"
32 " animateable=\"0\"\n"
33 " command=\"SetCaseFileName\"\n"
34 " number_of_elements=\"1\">\n"
35 " <FileListDomain name=\"files\"/>\n"
36 " <Documentation>\n"
37 " This property sets the case file to be read.\n"
38 " </Documentation>\n"
39 " </StringVectorProperty>\n"
40 " <Hints>\n"
41 " <ReaderFactory extensions=\"case encas\"\n"
42 " file_description=\"EnSight Gold files\" />\n"
43 " </Hints>\n"
44 "\n"
45 " <StringVectorProperty name=\"BlockInfo\"\n"
46 " command=\"GetPartSelection\"\n"
47 " number_of_elements_per_command=\"2\"\n"
48 " information_only=\"1\"\n"
49 " si_class=\"vtkSIDataArraySelectionProperty\" />\n"
50 " <StringVectorProperty\n"
51 " name=\"Parts\"\n"
52 " command=\"GetPartSelection\"\n"
53 " information_property=\"BlockInfo\"\n"
54 " number_of_elements_per_command=\"2\"\n"
55 " element_types=\"2 0\"\n"
56 " repeat_command=\"1\"\n"
57 " si_class=\"vtkSIDataArraySelectionProperty\">\n"
58 " <ArraySelectionDomain name=\"array_list\">\n"
59 " <RequiredProperties>\n"
60 " <Property function=\"ArrayList\" name=\"BlockInfo\" />\n"
61 " </RequiredProperties>\n"
62 " </ArraySelectionDomain>\n"
63 " <Documentation>Select which data elements to read.</Documentation>\n"
64 " </StringVectorProperty>\n"
65 " <StringVectorProperty name=\"PointArrayInfo\"\n"
66 " command=\"GetPointArraySelection\"\n"
67 " number_of_elements_per_command=\"2\"\n"
68 " information_only=\"1\"\n"
69 " si_class=\"vtkSIDataArraySelectionProperty\" />\n"
70 " <StringVectorProperty\n"
71 " name=\"Point Arrays\"\n"
72 " command=\"GetPointArraySelection\"\n"
73 " information_property=\"PointArrayInfo\"\n"
74 " number_of_elements_per_command=\"2\"\n"
75 " element_types=\"2 0\"\n"
76 " repeat_command=\"1\"\n"
77 " si_class=\"vtkSIDataArraySelectionProperty\">\n"
78 " <ArraySelectionDomain name=\"array_list\">\n"
79 " <RequiredProperties>\n"
80 " <Property function=\"ArrayList\" name=\"PointArrayInfo\" />\n"
81 " </RequiredProperties>\n"
82 " </ArraySelectionDomain>\n"
83 " <Documentation>Select which point arrays to read.</Documentation>\n"
84 " </StringVectorProperty>\n"
85 " <StringVectorProperty name=\"CellArrayInfo\"\n"
86 " command=\"GetCellArraySelection\"\n"
87 " number_of_elements_per_command=\"2\"\n"
88 " information_only=\"1\"\n"
89 " si_class=\"vtkSIDataArraySelectionProperty\" />\n"
90 " <StringVectorProperty\n"
91 " name=\"Cell Arrays\"\n"
92 " command=\"GetCellArraySelection\"\n"
93 " information_property=\"CellArrayInfo\"\n"
94 " number_of_elements_per_command=\"2\"\n"
95 " element_types=\"2 0\"\n"
96 " repeat_command=\"1\"\n"
97 " si_class=\"vtkSIDataArraySelectionProperty\">\n"
98 " <ArraySelectionDomain name=\"array_list\">\n"
99 " <RequiredProperties>\n"
100 " <Property function=\"ArrayList\" name=\"CellArrayInfo\" />\n"
101 " </RequiredProperties>\n"
102 " </ArraySelectionDomain>\n"
103 " <Documentation>Select which cell arrays to read.</Documentation>\n"
104 " </StringVectorProperty>\n"
105 " <StringVectorProperty name=\"FieldArrayInfo\"\n"
106 " command=\"GetFieldArraySelection\"\n"
107 " number_of_elements_per_command=\"2\"\n"
108 " information_only=\"1\"\n"
109 " si_class=\"vtkSIDataArraySelectionProperty\" />\n"
110 " <StringVectorProperty\n"
111 " name=\"Field Arrays\"\n"
112 " command=\"GetFieldArraySelection\"\n"
113 " information_property=\"FieldArrayInfo\"\n"
114 " number_of_elements_per_command=\"2\"\n"
115 " element_types=\"2 0\"\n"
116 " repeat_command=\"1\"\n"
117 " si_class=\"vtkSIDataArraySelectionProperty\">\n"
118 " <ArraySelectionDomain name=\"array_list\">\n"
119 " <RequiredProperties>\n"
120 " <Property function=\"ArrayList\" name=\"FieldArrayInfo\" />\n"
121 " </RequiredProperties>\n"
122 " </ArraySelectionDomain>\n"
123 " <Documentation>Select which field data arrays to read.</Documentation>\n"
124 " </StringVectorProperty>\n"
125 " </SourceProxy>\n"
126 " <SourceProxy name=\"EnSightSOSGoldReader\"\n"
127 " label=\"EnSight SOS Gold Reader\"\n"
128 " class=\"vtkEnSightSOSGoldReader\">\n"
129 " <Documentation short_help=\"Read EnSight Gold SOS files.\">\n"
130 " Reader for EnSight Gold SOS files.\n"
131 " </Documentation>\n"
132 " <DoubleVectorProperty information_only=\"1\"\n"
133 " name=\"TimestepValues\"\n"
134 " repeatable=\"1\">\n"
135 " <TimeStepsInformationHelper />\n"
136 " <Documentation>Available timestep values.</Documentation>\n"
137 " </DoubleVectorProperty>\n"
138 " <StringVectorProperty\n"
139 " name=\"CaseFileName\"\n"
140 " animateable=\"0\"\n"
141 " command=\"SetCaseFileName\"\n"
142 " number_of_elements=\"1\">\n"
143 " <FileListDomain name=\"files\"/>\n"
144 " <Documentation>\n"
145 " This property sets the SOS file to be read.\n"
146 " </Documentation>\n"
147 " </StringVectorProperty>\n"
148 " <Hints>\n"
149 " <ReaderFactory extensions=\"sos\"\n"
150 " file_description=\"EnSight Gold Server of Server (SOS) files\" />\n"
151 " </Hints>\n"
152 " <StringVectorProperty name=\"BlockInfo\"\n"
153 " command=\"GetPartSelection\"\n"
154 " number_of_elements_per_command=\"2\"\n"
155 " information_only=\"1\"\n"
156 " si_class=\"vtkSIDataArraySelectionProperty\" />\n"
157 " <StringVectorProperty\n"
158 " name=\"Parts\"\n"
159 " command=\"GetPartSelection\"\n"
160 " information_property=\"BlockInfo\"\n"
161 " number_of_elements_per_command=\"2\"\n"
162 " element_types=\"2 0\"\n"
163 " repeat_command=\"1\"\n"
164 " si_class=\"vtkSIDataArraySelectionProperty\">\n"
165 " <ArraySelectionDomain name=\"array_list\">\n"
166 " <RequiredProperties>\n"
167 " <Property function=\"ArrayList\" name=\"BlockInfo\" />\n"
168 " </RequiredProperties>\n"
169 " </ArraySelectionDomain>\n"
170 " <Documentation>Select which data elements to read.</Documentation>\n"
171 " </StringVectorProperty>\n"
172 " <StringVectorProperty name=\"PointArrayInfo\"\n"
173 " command=\"GetPointArraySelection\"\n"
174 " number_of_elements_per_command=\"2\"\n"
175 " information_only=\"1\"\n"
176 " si_class=\"vtkSIDataArraySelectionProperty\" />\n"
177 " <StringVectorProperty\n"
178 " name=\"Point Arrays\"\n"
179 " command=\"GetPointArraySelection\"\n"
180 " information_property=\"PointArrayInfo\"\n"
181 " number_of_elements_per_command=\"2\"\n"
182 " element_types=\"2 0\"\n"
183 " repeat_command=\"1\"\n"
184 " si_class=\"vtkSIDataArraySelectionProperty\">\n"
185 " <ArraySelectionDomain name=\"array_list\">\n"
186 " <RequiredProperties>\n"
187 " <Property function=\"ArrayList\" name=\"PointArrayInfo\" />\n"
188 " </RequiredProperties>\n"
189 " </ArraySelectionDomain>\n"
190 " <Documentation>Select which point arrays to read.</Documentation>\n"
191 " </StringVectorProperty>\n"
192 " <StringVectorProperty name=\"CellArrayInfo\"\n"
193 " command=\"GetCellArraySelection\"\n"
194 " number_of_elements_per_command=\"2\"\n"
195 " information_only=\"1\"\n"
196 " si_class=\"vtkSIDataArraySelectionProperty\" />\n"
197 " <StringVectorProperty\n"
198 " name=\"Cell Arrays\"\n"
199 " command=\"GetCellArraySelection\"\n"
200 " information_property=\"CellArrayInfo\"\n"
201 " number_of_elements_per_command=\"2\"\n"
202 " element_types=\"2 0\"\n"
203 " repeat_command=\"1\"\n"
204 " si_class=\"vtkSIDataArraySelectionProperty\">\n"
205 " <ArraySelectionDomain name=\"array_list\">\n"
206 " <RequiredProperties>\n"
207 " <Property function=\"ArrayList\" name=\"CellArrayInfo\" />\n"
208 " </RequiredProperties>\n"
209 " </ArraySelectionDomain>\n"
210 " <Documentation>Select which cell arrays to read.</Documentation>\n"
211 " </StringVectorProperty>\n"
212 " <StringVectorProperty name=\"FieldArrayInfo\"\n"
213 " command=\"GetFieldArraySelection\"\n"
214 " number_of_elements_per_command=\"2\"\n"
215 " information_only=\"1\"\n"
216 " si_class=\"vtkSIDataArraySelectionProperty\" />\n"
217 " <StringVectorProperty\n"
218 " name=\"Field Arrays\"\n"
219 " command=\"GetFieldArraySelection\"\n"
220 " information_property=\"FieldArrayInfo\"\n"
221 " number_of_elements_per_command=\"2\"\n"
222 " element_types=\"2 0\"\n"
223 " repeat_command=\"1\"\n"
224 " si_class=\"vtkSIDataArraySelectionProperty\">\n"
225 " <ArraySelectionDomain name=\"array_list\">\n"
226 " <RequiredProperties>\n"
227 " <Property function=\"ArrayList\" name=\"FieldArrayInfo\" />\n"
228 " </RequiredProperties>\n"
229 " </ArraySelectionDomain>\n"
230 " <Documentation>Select which field data arrays to read.</Documentation>\n"
231 " </StringVectorProperty>\n"
232 "\n"
233 " </SourceProxy>\n"
234 " </ProxyGroup>\n"
235 "</ServerManagerConfiguration>\n"
236 "\n";
237 // Get single string
239 {
240
242  size_t len = ( 0
243  + len0 );
244  char* res = new char[ len + 1];
245  size_t offset = 0;
247  assert(offset == len);
248  res[offset] = 0;
249  return res;
250 }
251
252
253
254 #endif
offset
static const char *const EnSightGoldCombinedReader_server_managerEnSightGoldCombinedReaderInterface0
char * EnSightGoldCombinedReader_server_managerEnSightGoldCombinedReaderGetInterfaces()
