Encoding.h
1 /* Distributed under the OSI-approved BSD 3-Clause License. See accompanying
2  file Copyright.txt or https://cmake.org/licensing#kwsys for details. */
3 #ifndef vtksys_Encoding_h
4 #define vtksys_Encoding_h
5
6 #include <vtksys/Configure.h>
7
8 #include <wchar.h>
9
10 /* Redefine all public interface symbol names to be in the proper
11  namespace. These macros are used internally to kwsys only, and are
12  not visible to user code. Use kwsysHeaderDump.pl to reproduce
13  these macros after making changes to the interface. */
14 #if !defined(KWSYS_NAMESPACE)
15 # define kwsys_ns(x) vtksys##x
16 # define kwsysEXPORT vtksys_EXPORT
17 #endif
18 #if !vtksys_NAME_IS_KWSYS
19 # define kwsysEncoding kwsys_ns(Encoding)
20 # define kwsysEncoding_mbstowcs kwsys_ns(Encoding_mbstowcs)
21 # define kwsysEncoding_DupToWide kwsys_ns(Encoding_DupToWide)
22 # define kwsysEncoding_wcstombs kwsys_ns(Encoding_wcstombs)
23 # define kwsysEncoding_DupToNarrow kwsys_ns(Encoding_DupToNarrow)
24 #endif
25
26 #if defined(__cplusplus)
27 extern "C" {
28 #endif
30 /* Convert a narrow string to a wide string.
31  On Windows, UTF-8 is assumed, and on other platforms,
32  the current locale is assumed.
33  */
34 kwsysEXPORT size_t kwsysEncoding_mbstowcs(wchar_t* dest, const char* src,
35  size_t n);
36
37 /* Convert a narrow string to a wide string.
38  This can return NULL if the conversion fails. */
39 kwsysEXPORT wchar_t* kwsysEncoding_DupToWide(const char* src);
40
41 /* Convert a wide string to a narrow string.
42  On Windows, UTF-8 is assumed, and on other platforms,
43  the current locale is assumed. */
44 kwsysEXPORT size_t kwsysEncoding_wcstombs(char* dest, const wchar_t* src,
45  size_t n);
46
47 /* Convert a wide string to a narrow string.
48  This can return NULL if the conversion fails. */
49 kwsysEXPORT char* kwsysEncoding_DupToNarrow(const wchar_t* str);
50
51 #if defined(__cplusplus)
52 } /* extern "C" */
53 #endif
54
55 /* If we are building a kwsys .c or .cxx file, let it use these macros.
56  Otherwise, undefine them to keep the namespace clean. */
57 #if !defined(KWSYS_NAMESPACE)
58 # undef kwsys_ns
59 # undef kwsysEXPORT
60 # if !defined(KWSYS_NAMESPACE) && !vtksys_NAME_IS_KWSYS
61 # undef kwsysEncoding
62 # undef kwsysEncoding_mbstowcs
63 # undef kwsysEncoding_DupToWide
64 # undef kwsysEncoding_wcstombs
65 # undef kwsysEncoding_DupToNarrow
66 # endif
67 #endif
68
69 #endif
#define kwsysEncoding_DupToNarrow
Definition: Encoding.h:23
#define kwsysEncoding_wcstombs
Definition: Encoding.h:22
#define kwsysEXPORT
Definition: Encoding.h:16
#define kwsysEncoding_mbstowcs
Definition: Encoding.h:20
#define kwsysEncoding_DupToWide
Definition: Encoding.h:21
