Macros
moc_predefs.h File Reference
Macros
#define __DBL_MIN_EXP__   (-1021)
#define __cpp_attributes   200809L
#define __cpp_nontype_template_parameter_auto   201606L
#define __UINT_LEAST16_MAX__   0xffff
#define __ATOMIC_ACQUIRE   2
#define __FLT128_MAX_10_EXP__   4932
#define __FLT_MIN__   1.17549435082228750796873653722224568e-38F
#define __GCC_IEC_559_COMPLEX   2
#define __cpp_aggregate_nsdmi   201304L
#define __UINT_LEAST8_TYPE__   unsigned char
#define __SIZEOF_FLOAT80__   16
#define __INTMAX_C(c)   c ## L
#define __CHAR_BIT__   8
#define __UINT8_MAX__   0xff
#define __SCHAR_WIDTH__   8
#define __WINT_MAX__   0xffffffffU
#define __FLT32_MIN_EXP__   (-125)
#define __cpp_static_assert   201411L
#define QT_GUI_LIB   1
#define __ORDER_LITTLE_ENDIAN__   1234
#define __SIZE_MAX__   0xffffffffffffffffUL
#define __WCHAR_MAX__   0x7fffffff
#define __GCC_HAVE_SYNC_COMPARE_AND_SWAP_1   1
#define __GCC_HAVE_SYNC_COMPARE_AND_SWAP_2   1
#define __GCC_HAVE_SYNC_COMPARE_AND_SWAP_4   1
#define __DBL_DENORM_MIN__   double(4.94065645841246544176568792868221372e-324L)
#define __GCC_HAVE_SYNC_COMPARE_AND_SWAP_8   1
#define __GCC_ATOMIC_CHAR_LOCK_FREE   2
#define __GCC_IEC_559   2
#define __FLT32X_DECIMAL_DIG__   17
#define __FLT_EVAL_METHOD__   0
#define __cpp_binary_literals   201304L
#define __FLT64_DECIMAL_DIG__   17
#define __cpp_noexcept_function_type   201510L
#define __GCC_ATOMIC_CHAR32_T_LOCK_FREE   2
#define __cpp_variadic_templates   200704L
#define __UINT_FAST64_MAX__   0xffffffffffffffffUL
#define __SIG_ATOMIC_TYPE__   int
#define __DBL_MIN_10_EXP__   (-307)
#define __FINITE_MATH_ONLY__   0
#define __cpp_variable_templates   201304L
#define __FLT32X_MAX_EXP__   1024
#define __FLT32_HAS_DENORM__   1
#define __UINT_FAST8_MAX__   0xff
#define __cpp_rvalue_reference   200610L
#define __cpp_nested_namespace_definitions   201411L
#define __DEC64_MAX_EXP__   385
#define __INT8_C(c)   c
#define __INT_LEAST8_WIDTH__   8
#define __cpp_variadic_using   201611L
#define __UINT_LEAST64_MAX__   0xffffffffffffffffUL
#define QT_OPENGL_LIB   1
#define __INT_LEAST8_MAX__   0x7f
#define __cpp_capture_star_this   201603L
#define __SHRT_MAX__   0x7fff
#define __LDBL_MAX__   1.18973149535723176502126385303097021e+4932L
#define __FLT64X_MAX_10_EXP__   4932
#define __cpp_if_constexpr   201606L
#define __LDBL_IS_IEC_60559__   2
#define __FLT64X_HAS_QUIET_NAN__   1
#define __UINT_LEAST8_MAX__   0xff
#define __GCC_ATOMIC_BOOL_LOCK_FREE   2
#define __FLT128_DENORM_MIN__   6.47517511943802511092443895822764655e-4966F128
#define __UINTMAX_TYPE__   long unsigned int
#define __linux   1
#define __DEC32_EPSILON__   1E-6DF
#define __FLT_EVAL_METHOD_TS_18661_3__   0
#define __unix   1
#define __UINT32_MAX__   0xffffffffU
#define __GXX_EXPERIMENTAL_CXX0X__   1
#define __FLT128_MIN_EXP__   (-16381)
#define __WINT_MIN__   0U
#define __FLT128_MIN_10_EXP__   (-4931)
#define __FLT32X_IS_IEC_60559__   2
#define __INT_LEAST16_WIDTH__   16
#define __SCHAR_MAX__   0x7f
#define __FLT128_MANT_DIG__   113
#define __WCHAR_MIN__   (-__WCHAR_MAX__ - 1)
#define __INT64_C(c)   c ## L
#define __GCC_ATOMIC_POINTER_LOCK_FREE   2
#define __FLT32X_MANT_DIG__   53
#define __GCC_ATOMIC_CHAR16_T_LOCK_FREE   2
#define __cpp_aligned_new   201606L
#define __USER_LABEL_PREFIX__
#define __FLT32_MAX_10_EXP__   38
#define __FLT64X_EPSILON__   1.08420217248550443400745280086994171e-19F64x
#define __STDC_HOSTED__   1
#define __DEC64_MIN_EXP__   (-382)
#define __cpp_decltype_auto   201304L
#define __DBL_DIG__   15
#define __FLT32_DIG__   6
#define __FLT_EPSILON__   1.19209289550781250000000000000000000e-7F
#define __GXX_WEAK__   1
#define __SHRT_WIDTH__   16
#define __FLT32_IS_IEC_60559__   2
#define __LDBL_MIN__   3.36210314311209350626267781732175260e-4932L
#define __DBL_IS_IEC_60559__   2
#define __DEC32_MAX__   9.999999E96DF
#define __cpp_threadsafe_static_init   200806L
#define __cpp_enumerator_attributes   201411L
#define __FLT64X_DENORM_MIN__   3.64519953188247460252840593361941982e-4951F64x
#define __FLT32X_HAS_INFINITY__   1
#define __INT32_MAX__   0x7fffffff
#define __unix__   1
#define __INT_WIDTH__   32
#define __SIZEOF_LONG__   8
#define __STDC_IEC_559__   1
#define __STDC_ISO_10646__   201706L
#define __UINT16_C(c)   c
#define __DECIMAL_DIG__   21
#define __STDC_IEC_559_COMPLEX__   1
#define __FLT64_EPSILON__   2.22044604925031308084726333618164062e-16F64
#define __gnu_linux__   1
#define __INT16_MAX__   0x7fff
#define __FLT64_MIN_EXP__   (-1021)
#define __FLT64X_MIN_10_EXP__   (-4931)
#define __LDBL_HAS_QUIET_NAN__   1
#define __FLT64_MANT_DIG__   53
#define FlipBookPlugin_EXPORTS   1
#define __FLT64X_MANT_DIG__   64
#define __GNUC__   11
#define __GXX_RTTI   1
#define __MMX__   1
#define __FLT_HAS_DENORM__   1
#define __SIZEOF_LONG_DOUBLE__   16
#define __BIGGEST_ALIGNMENT__   16
#define __STDC_UTF_16__   1
#define __FLT64_MAX_10_EXP__   308
#define __cpp_delegating_constructors   200604L
#define __FLT32_HAS_INFINITY__   1
#define __DBL_MAX__   double(1.79769313486231570814527423731704357e+308L)
#define __cpp_raw_strings   200710L
#define __INT_FAST32_MAX__   0x7fffffffffffffffL
#define __DBL_HAS_INFINITY__   1
#define __SIZEOF_FLOAT__   4
#define __HAVE_SPECULATION_SAFE_VALUE   1
#define __cpp_fold_expressions   201603L
#define __DEC32_MIN_EXP__   (-94)
#define __INTPTR_WIDTH__   64
#define __FLT64X_HAS_INFINITY__   1
#define __UINT_LEAST32_MAX__   0xffffffffU
#define __FLT32X_HAS_DENORM__   1
#define __INT_FAST16_TYPE__   long int
#define __MMX_WITH_SSE__   1
#define __LDBL_HAS_DENORM__   1
#define QT_WIDGETS_LIB   1
#define __cplusplus   201703L
#define __cpp_ref_qualifiers   200710L
#define __DEC32_MIN__   1E-95DF
#define __DEPRECATED   1
#define __cpp_rvalue_references   200610L
#define __DBL_MAX_EXP__   1024
#define __WCHAR_WIDTH__   32
#define __FLT32_MAX__   3.40282346638528859811704183484516925e+38F32
#define __DEC128_EPSILON__   1E-33DL
#define __SSE2_MATH__   1
#define __ATOMIC_HLE_RELEASE   131072
#define __PTRDIFF_MAX__   0x7fffffffffffffffL
#define __amd64   1
#define __ATOMIC_HLE_ACQUIRE   65536
#define __GNUG__   11
#define __LONG_LONG_MAX__   0x7fffffffffffffffLL
#define __SIZEOF_SIZE_T__   8
#define __cpp_nsdmi   200809L
#define __FLT64X_MIN_EXP__   (-16381)
#define __SIZEOF_WINT_T__   4
#define __LONG_LONG_WIDTH__   64
#define __cpp_initializer_lists   200806L
#define __FLT32_MAX_EXP__   128
#define ABI_ID   "ELF"
#define __cpp_hex_float   201603L
#define __GXX_ABI_VERSION   1016
#define __FLT128_HAS_INFINITY__   1
#define kiss_fft_scalar   double
#define __FLT_MIN_EXP__   (-125)
#define __GCC_HAVE_DWARF2_CFI_ASM   1
#define __x86_64   1
#define __cpp_lambdas   200907L
#define __INT_FAST64_TYPE__   long int
#define __FLT64_DENORM_MIN__   4.94065645841246544176568792868221372e-324F64
#define PROTOBUF_USE_DLLS   1
#define __cpp_template_auto   201606L
#define __DBL_MIN__   double(2.22507385850720138309023271733240406e-308L)
#define __FLT128_EPSILON__   1.92592994438723585305597794258492732e-34F128
#define __FLT64X_NORM_MAX__   1.18973149535723176502126385303097021e+4932F64x
#define __SIZEOF_POINTER__   8
#define __LP64__   1
#define __DBL_HAS_QUIET_NAN__   1
#define __FLT32X_EPSILON__   2.22044604925031308084726333618164062e-16F32x
#define __DECIMAL_BID_FORMAT__   1
#define __FLT64_MIN_10_EXP__   (-307)
#define __FLT64X_DECIMAL_DIG__   21
#define __DEC128_MIN__   1E-6143DL
#define __REGISTER_PREFIX__
#define __UINT16_MAX__   0xffff
#define __LDBL_HAS_INFINITY__   1
#define __FLT32_MIN__   1.17549435082228750796873653722224568e-38F32
#define __UINT8_TYPE__   unsigned char
#define __FLT_DIG__   6
#define __NO_INLINE__   1
#define __DEC_EVAL_METHOD__   2
#define __DEC128_MAX__   9.999999999999999999999999999999999E6144DL
#define QT_NO_KEYWORDS   1
#define __FLT_MANT_DIG__   24
#define __LDBL_DECIMAL_DIG__   21
#define __VERSION__   "11.3.1 20220421 (Red Hat 11.3.1-3)"
#define __UINT64_C(c)   c ## UL
#define __cpp_unicode_characters   201411L
#define _STDC_PREDEF_H   1
#define GLAD_API_CALL_EXPORT   1
#define __INT_LEAST32_MAX__   0x7fffffff
#define __GCC_ATOMIC_INT_LOCK_FREE   2
#define __FLT128_MAX_EXP__   16384
#define __FLT32_MANT_DIG__   24
#define __FLOAT_WORD_ORDER__   __ORDER_LITTLE_ENDIAN__
#define SIZEOF_DPTR   (sizeof(void*))
#define __cpp_aggregate_bases   201603L
#define __FLT128_HAS_DENORM__   1
#define __FLT32_DECIMAL_DIG__   9
#define __FLT128_DIG__   33
#define __INT32_C(c)   c
#define __DEC64_EPSILON__   1E-15DD
#define __ORDER_PDP_ENDIAN__   3412
#define __DEC128_MIN_EXP__   (-6142)
#define __INT_FAST32_TYPE__   long int
#define __UINT_LEAST16_TYPE__   short unsigned int
#define unix   1
#define __DBL_HAS_DENORM__   1
#define __cpp_rtti   199711L
#define __SIZE_TYPE__   long unsigned int
#define __UINT64_MAX__   0xffffffffffffffffUL
#define __FLT_IS_IEC_60559__   2
#define __GNUC_WIDE_EXECUTION_CHARSET_NAME   "UTF-32LE"
#define __FLT64X_DIG__   18
#define __INT8_TYPE__   signed char
#define __cpp_digit_separators   201309L
#define __ELF__   1
#define __GCC_ASM_FLAG_OUTPUTS__   1
#define __UINT32_TYPE__   unsigned int
#define __FLT_RADIX__   2
#define __INT_LEAST16_TYPE__   short int
#define __LDBL_EPSILON__   1.08420217248550443400745280086994171e-19L
#define __UINTMAX_C(c)   c ## UL
#define __GNUC_RH_RELEASE__   3
#define __GLIBCXX_BITSIZE_INT_N_0   128
#define __k8   1
#define __FLT32X_MIN__   2.22507385850720138309023271733240406e-308F32x
#define __SIG_ATOMIC_MAX__   0x7fffffff
#define __GCC_ATOMIC_WCHAR_T_LOCK_FREE   2
#define __SIZEOF_PTRDIFF_T__   8
#define __LDBL_DIG__   18
#define __FLT64_IS_IEC_60559__   2
#define __x86_64__   1
#define __FLT32X_MIN_EXP__   (-1021)
#define __DEC32_SUBNORMAL_MIN__   0.000001E-95DF
#define __INT_FAST16_MAX__   0x7fffffffffffffffL
#define __FLT64_DIG__   15
#define __UINT_FAST32_MAX__   0xffffffffffffffffUL
#define __UINT_LEAST64_TYPE__   long unsigned int
#define __FLT_HAS_QUIET_NAN__   1
#define __FLT_MAX_10_EXP__   38
#define __LONG_MAX__   0x7fffffffffffffffL
#define __FLT64X_HAS_DENORM__   1
#define __DEC128_SUBNORMAL_MIN__   0.000000000000000000000000000000001E-6143DL
#define __FLT_HAS_INFINITY__   1
#define __GNUC_EXECUTION_CHARSET_NAME   "UTF-8"
#define __cpp_unicode_literals   200710L
#define __UINT_FAST16_TYPE__   long unsigned int
#define __DEC64_MAX__   9.999999999999999E384DD
#define __INT_FAST32_WIDTH__   64
#define __CHAR16_TYPE__   short unsigned int
#define __PRAGMA_REDEFINE_EXTNAME   1
#define __SIZE_WIDTH__   64
#define __SEG_FS   1
#define __INT_LEAST16_MAX__   0x7fff
#define __DEC64_MANT_DIG__   16
#define __INT64_MAX__   0x7fffffffffffffffL
#define __SEG_GS   1
#define __FLT32_DENORM_MIN__   1.40129846432481707092372958328991613e-45F32
#define __SIG_ATOMIC_WIDTH__   32
#define __INT_LEAST64_TYPE__   long int
#define __INT16_TYPE__   short int
#define __INT_LEAST8_TYPE__   signed char
#define __cpp_structured_bindings   201606L
#define __SIZEOF_INT__   4
#define __DEC32_MAX_EXP__   97
#define __INT_FAST8_MAX__   0x7f
#define __FLT128_MAX__   1.18973149535723176508575932662800702e+4932F128
#define __INTPTR_MAX__   0x7fffffffffffffffL
#define __cpp_sized_deallocation   201309L
#define __cpp_guaranteed_copy_elision   201606L
#define linux   1
#define __FLT64_HAS_QUIET_NAN__   1
#define __FLT32_MIN_10_EXP__   (-37)
#define __EXCEPTIONS   1
#define __PTRDIFF_WIDTH__   64
#define __LDBL_MANT_DIG__   64
#define __cpp_range_based_for   201603L
#define FMT_SHARED   1
#define __FLT64_HAS_INFINITY__   1
#define __FLT64X_MAX__   1.18973149535723176502126385303097021e+4932F64x
#define __STDCPP_DEFAULT_NEW_ALIGNMENT__   16
#define __SIG_ATOMIC_MIN__   (-__SIG_ATOMIC_MAX__ - 1)
#define __code_model_small__   1
#define __GCC_ATOMIC_LONG_LOCK_FREE   2
#define __cpp_nontype_template_args   201411L
#define __DEC32_MANT_DIG__   7
#define __cpp_return_type_deduction   201304L
#define __k8__   1
#define __INTPTR_TYPE__   long int
#define __UINT16_TYPE__   short unsigned int
#define __WCHAR_TYPE__   int
#define __UINTPTR_MAX__   0xffffffffffffffffUL
#define __INT_FAST64_WIDTH__   64
#define __cpp_decltype   200707L
#define __INT_FAST64_MAX__   0x7fffffffffffffffL
#define __GCC_ATOMIC_TEST_AND_SET_TRUEVAL   1
#define __FLT_NORM_MAX__   3.40282346638528859811704183484516925e+38F
#define __FLT64X_MAX_EXP__   16384
#define __UINT_FAST64_TYPE__   long unsigned int
#define __cpp_inline_variables   201606L
#define __INT_MAX__   0x7fffffff
#define __linux__   1
#define __INT64_TYPE__   long int
#define __FLT_MAX_EXP__   128
#define __ORDER_BIG_ENDIAN__   4321
#define __DBL_MANT_DIG__   53
#define __cpp_inheriting_constructors   201511L
#define QT_CORE_LIB   1
#define __SIZEOF_FLOAT128__   16
#define __INT_LEAST64_MAX__   0x7fffffffffffffffL
#define __DEC64_MIN__   1E-383DD
#define __WINT_TYPE__   unsigned int
#define __UINT_LEAST32_TYPE__   unsigned int
#define __SIZEOF_SHORT__   2
#define __FLT32_NORM_MAX__   3.40282346638528859811704183484516925e+38F32
#define __SSE__   1
#define __LDBL_MIN_EXP__   (-16381)
#define __FLT64_MAX__   1.79769313486231570814527423731704357e+308F64
#define __amd64__   1
#define __WINT_WIDTH__   32
#define __INT_LEAST64_WIDTH__   64
#define __LDBL_MAX_EXP__   16384
#define __FLT32X_MAX_10_EXP__   308
#define __SIZEOF_INT128__   16
#define __FLT64X_IS_IEC_60559__   2
#define __LDBL_MAX_10_EXP__   4932
#define __ATOMIC_RELAXED   0
#define __DBL_EPSILON__   double(2.22044604925031308084726333618164062e-16L)
#define __FLT128_MIN__   3.36210314311209350626267781732175260e-4932F128
#define _LP64   1
#define __UINT8_C(c)   c
#define __FLT64_MAX_EXP__   1024
#define __INT_LEAST32_TYPE__   int
#define __SIZEOF_WCHAR_T__   4
#define __GNUC_PATCHLEVEL__   1
#define __FLT128_NORM_MAX__   1.18973149535723176508575932662800702e+4932F128
#define __FLT64_NORM_MAX__   1.79769313486231570814527423731704357e+308F64
#define __FLT128_HAS_QUIET_NAN__   1
#define __INTMAX_MAX__   0x7fffffffffffffffL
#define __INT_FAST8_TYPE__   signed char
#define __cpp_namespace_attributes   201411L
#define __FLT64X_MIN__   3.36210314311209350626267781732175260e-4932F64x
#define __STDCPP_THREADS__   1
#define __GNUC_STDC_INLINE__   1
#define __FLT64_HAS_DENORM__   1
#define __FLT32_EPSILON__   1.19209289550781250000000000000000000e-7F32
#define __DBL_DECIMAL_DIG__   17
#define __STDC_UTF_32__   1
#define __INT_FAST8_WIDTH__   8
#define __FXSR__   1
#define __FLT32X_MAX__   1.79769313486231570814527423731704357e+308F32x
#define __DBL_NORM_MAX__   double(1.79769313486231570814527423731704357e+308L)
#define __BYTE_ORDER__   __ORDER_LITTLE_ENDIAN__
#define __INTMAX_WIDTH__   64
#define __cpp_runtime_arrays   198712L
#define __UINT64_TYPE__   long unsigned int
#define __UINT32_C(c)   c ## U
#define __cpp_alias_templates   200704L
#define __FLT_DENORM_MIN__   1.40129846432481707092372958328991613e-45F
#define __FLT128_IS_IEC_60559__   2
#define __INT8_MAX__   0x7f
#define __LONG_WIDTH__   64
#define __UINT_FAST32_TYPE__   long unsigned int
#define __FLT32X_NORM_MAX__   1.79769313486231570814527423731704357e+308F32x
#define __CHAR32_TYPE__   unsigned int
#define __FLT_MAX__   3.40282346638528859811704183484516925e+38F
#define __cpp_constexpr   201603L
#define __SSE2__   1
#define __cpp_deduction_guides   201703L
#define __INT32_TYPE__   int
#define __SIZEOF_DOUBLE__   8
#define __cpp_exceptions   199711L
#define __FLT_MIN_10_EXP__   (-37)
#define __FLT64_MIN__   2.22507385850720138309023271733240406e-308F64
#define __INT_LEAST32_WIDTH__   32
#define __INTMAX_TYPE__   long int
#define __DEC128_MAX_EXP__   6145
#define __FLT32X_HAS_QUIET_NAN__   1
#define __ATOMIC_CONSUME   1
#define __GNUC_MINOR__   3
#define __GLIBCXX_TYPE_INT_N_0   __int128
#define __INT_FAST16_WIDTH__   64
#define __UINTMAX_MAX__   0xffffffffffffffffUL
#define __FLT32X_DENORM_MIN__   4.94065645841246544176568792868221372e-324F32x
#define __cpp_template_template_args   201611L
#define __DBL_MAX_10_EXP__   308
#define __LDBL_DENORM_MIN__   3.64519953188247460252840593361941982e-4951L
#define __INT16_C(c)   c
#define __STDC__   1
#define __FLT32X_DIG__   15
#define __PTRDIFF_TYPE__   long int
#define __ATOMIC_SEQ_CST   5
#define __FLT32X_MIN_10_EXP__   (-307)
#define __UINTPTR_TYPE__   long unsigned int
#define __DEC64_SUBNORMAL_MIN__   0.000000000000001E-383DD
#define __DEC128_MANT_DIG__   34
#define __LDBL_MIN_10_EXP__   (-4931)
#define __cpp_generic_lambdas   201304L
#define __SSE_MATH__   1
#define __SIZEOF_LONG_LONG__   8
#define __cpp_user_defined_literals   200809L
#define __FLT128_DECIMAL_DIG__   36
#define __GCC_ATOMIC_LLONG_LOCK_FREE   2
#define __FLT32_HAS_QUIET_NAN__   1
#define __FLT_DECIMAL_DIG__   9
#define __UINT_FAST16_MAX__   0xffffffffffffffffUL
#define __LDBL_NORM_MAX__   1.18973149535723176502126385303097021e+4932L
#define __GCC_ATOMIC_SHORT_LOCK_FREE   2
#define __UINT_FAST8_TYPE__   unsigned char
#define _GNU_SOURCE   1
#define __cpp_init_captures   201304L
#define __ATOMIC_ACQ_REL   4
#define __ATOMIC_RELEASE   3
Macro Definition Documentation
◆ __DBL_MIN_EXP__
Definition at line 1 of file moc_predefs.h.
◆ __cpp_attributes
Definition at line 2 of file moc_predefs.h.
◆ __cpp_nontype_template_parameter_auto
Definition at line 3 of file moc_predefs.h.
◆ __UINT_LEAST16_MAX__
Definition at line 4 of file moc_predefs.h.
◆ __ATOMIC_ACQUIRE
Definition at line 5 of file moc_predefs.h.
◆ __FLT128_MAX_10_EXP__
Definition at line 6 of file moc_predefs.h.
◆ __FLT_MIN__
Definition at line 7 of file moc_predefs.h.
◆ __GCC_IEC_559_COMPLEX
Definition at line 8 of file moc_predefs.h.
◆ __cpp_aggregate_nsdmi
Definition at line 9 of file moc_predefs.h.
◆ __UINT_LEAST8_TYPE__
Definition at line 10 of file moc_predefs.h.
◆ __SIZEOF_FLOAT80__
Definition at line 11 of file moc_predefs.h.
◆ __INTMAX_C
#define __INTMAX_C (   c)    c ## L
Definition at line 12 of file moc_predefs.h.
◆ __CHAR_BIT__
Definition at line 13 of file moc_predefs.h.
◆ __UINT8_MAX__
Definition at line 14 of file moc_predefs.h.
◆ __SCHAR_WIDTH__
Definition at line 15 of file moc_predefs.h.
◆ __WINT_MAX__
Definition at line 16 of file moc_predefs.h.
◆ __FLT32_MIN_EXP__
Definition at line 17 of file moc_predefs.h.
◆ __cpp_static_assert
Definition at line 18 of file moc_predefs.h.
◆ QT_GUI_LIB
Definition at line 19 of file moc_predefs.h.
◆ __ORDER_LITTLE_ENDIAN__
Definition at line 20 of file moc_predefs.h.
◆ __SIZE_MAX__
Definition at line 21 of file moc_predefs.h.
◆ __WCHAR_MAX__
Definition at line 22 of file moc_predefs.h.
◆ __GCC_HAVE_SYNC_COMPARE_AND_SWAP_1
Definition at line 23 of file moc_predefs.h.
◆ __GCC_HAVE_SYNC_COMPARE_AND_SWAP_2
Definition at line 24 of file moc_predefs.h.
◆ __GCC_HAVE_SYNC_COMPARE_AND_SWAP_4
Definition at line 25 of file moc_predefs.h.
◆ __DBL_DENORM_MIN__
Definition at line 26 of file moc_predefs.h.
◆ __GCC_HAVE_SYNC_COMPARE_AND_SWAP_8
Definition at line 27 of file moc_predefs.h.
◆ __GCC_ATOMIC_CHAR_LOCK_FREE
Definition at line 28 of file moc_predefs.h.
◆ __GCC_IEC_559
Definition at line 29 of file moc_predefs.h.
◆ __FLT32X_DECIMAL_DIG__
Definition at line 30 of file moc_predefs.h.
◆ __FLT_EVAL_METHOD__
Definition at line 31 of file moc_predefs.h.
◆ __cpp_binary_literals
Definition at line 32 of file moc_predefs.h.
◆ __FLT64_DECIMAL_DIG__
Definition at line 33 of file moc_predefs.h.
◆ __cpp_noexcept_function_type
Definition at line 34 of file moc_predefs.h.
◆ __GCC_ATOMIC_CHAR32_T_LOCK_FREE
Definition at line 35 of file moc_predefs.h.
◆ __cpp_variadic_templates
Definition at line 36 of file moc_predefs.h.
◆ __UINT_FAST64_MAX__
Definition at line 37 of file moc_predefs.h.
◆ __SIG_ATOMIC_TYPE__
Definition at line 38 of file moc_predefs.h.
◆ __DBL_MIN_10_EXP__
Definition at line 39 of file moc_predefs.h.
◆ __FINITE_MATH_ONLY__
Definition at line 40 of file moc_predefs.h.
◆ __cpp_variable_templates
Definition at line 41 of file moc_predefs.h.
◆ __FLT32X_MAX_EXP__
Definition at line 42 of file moc_predefs.h.
◆ __FLT32_HAS_DENORM__
Definition at line 43 of file moc_predefs.h.
◆ __UINT_FAST8_MAX__
Definition at line 44 of file moc_predefs.h.
◆ __cpp_rvalue_reference
Definition at line 45 of file moc_predefs.h.
◆ __cpp_nested_namespace_definitions
Definition at line 46 of file moc_predefs.h.
◆ __DEC64_MAX_EXP__
Definition at line 47 of file moc_predefs.h.
◆ __INT8_C
#define __INT8_C (   c)    c
Definition at line 48 of file moc_predefs.h.
◆ __INT_LEAST8_WIDTH__
Definition at line 49 of file moc_predefs.h.
◆ __cpp_variadic_using
Definition at line 50 of file moc_predefs.h.
◆ __UINT_LEAST64_MAX__
Definition at line 51 of file moc_predefs.h.
◆ QT_OPENGL_LIB
Definition at line 52 of file moc_predefs.h.
◆ __INT_LEAST8_MAX__
Definition at line 53 of file moc_predefs.h.
◆ __cpp_capture_star_this
Definition at line 54 of file moc_predefs.h.
◆ __SHRT_MAX__
Definition at line 55 of file moc_predefs.h.
◆ __LDBL_MAX__
Definition at line 56 of file moc_predefs.h.
◆ __FLT64X_MAX_10_EXP__
Definition at line 57 of file moc_predefs.h.
◆ __cpp_if_constexpr
Definition at line 58 of file moc_predefs.h.
◆ __LDBL_IS_IEC_60559__
Definition at line 59 of file moc_predefs.h.
◆ __FLT64X_HAS_QUIET_NAN__
Definition at line 60 of file moc_predefs.h.
◆ __UINT_LEAST8_MAX__
Definition at line 61 of file moc_predefs.h.
◆ __GCC_ATOMIC_BOOL_LOCK_FREE
Definition at line 62 of file moc_predefs.h.
◆ __FLT128_DENORM_MIN__
Definition at line 63 of file moc_predefs.h.
◆ __UINTMAX_TYPE__
Definition at line 64 of file moc_predefs.h.
◆ __linux
#define __linux   1
Definition at line 65 of file moc_predefs.h.
◆ __DEC32_EPSILON__
Definition at line 66 of file moc_predefs.h.
◆ __FLT_EVAL_METHOD_TS_18661_3__
Definition at line 67 of file moc_predefs.h.
◆ __unix
#define __unix   1
Definition at line 68 of file moc_predefs.h.
◆ __UINT32_MAX__
Definition at line 69 of file moc_predefs.h.
◆ __GXX_EXPERIMENTAL_CXX0X__
Definition at line 70 of file moc_predefs.h.
◆ __FLT128_MIN_EXP__
Definition at line 71 of file moc_predefs.h.
◆ __WINT_MIN__
Definition at line 72 of file moc_predefs.h.
◆ __FLT128_MIN_10_EXP__
Definition at line 73 of file moc_predefs.h.
◆ __FLT32X_IS_IEC_60559__
Definition at line 74 of file moc_predefs.h.
◆ __INT_LEAST16_WIDTH__
Definition at line 75 of file moc_predefs.h.
◆ __SCHAR_MAX__
Definition at line 76 of file moc_predefs.h.
◆ __FLT128_MANT_DIG__
Definition at line 77 of file moc_predefs.h.
◆ __WCHAR_MIN__
Definition at line 78 of file moc_predefs.h.
◆ __INT64_C
#define __INT64_C (   c)    c ## L
Definition at line 79 of file moc_predefs.h.
◆ __GCC_ATOMIC_POINTER_LOCK_FREE
Definition at line 80 of file moc_predefs.h.
◆ __FLT32X_MANT_DIG__
Definition at line 81 of file moc_predefs.h.
◆ __GCC_ATOMIC_CHAR16_T_LOCK_FREE
Definition at line 82 of file moc_predefs.h.
◆ __cpp_aligned_new
Definition at line 83 of file moc_predefs.h.
◆ __USER_LABEL_PREFIX__
Definition at line 84 of file moc_predefs.h.
◆ __FLT32_MAX_10_EXP__
Definition at line 85 of file moc_predefs.h.
◆ __FLT64X_EPSILON__
Definition at line 86 of file moc_predefs.h.
◆ __STDC_HOSTED__
Definition at line 87 of file moc_predefs.h.
◆ __DEC64_MIN_EXP__
Definition at line 88 of file moc_predefs.h.
◆ __cpp_decltype_auto
Definition at line 89 of file moc_predefs.h.
◆ __DBL_DIG__
Definition at line 90 of file moc_predefs.h.
◆ __FLT32_DIG__
Definition at line 91 of file moc_predefs.h.
◆ __FLT_EPSILON__
Definition at line 92 of file moc_predefs.h.
◆ __GXX_WEAK__
Definition at line 93 of file moc_predefs.h.
◆ __SHRT_WIDTH__
Definition at line 94 of file moc_predefs.h.
◆ __FLT32_IS_IEC_60559__
Definition at line 95 of file moc_predefs.h.
◆ __LDBL_MIN__
Definition at line 96 of file moc_predefs.h.
◆ __DBL_IS_IEC_60559__
Definition at line 97 of file moc_predefs.h.
◆ __DEC32_MAX__
Definition at line 98 of file moc_predefs.h.
◆ __cpp_threadsafe_static_init
Definition at line 99 of file moc_predefs.h.
◆ __cpp_enumerator_attributes
Definition at line 100 of file moc_predefs.h.
◆ __FLT64X_DENORM_MIN__
Definition at line 101 of file moc_predefs.h.
◆ __FLT32X_HAS_INFINITY__
Definition at line 102 of file moc_predefs.h.
◆ __INT32_MAX__
Definition at line 103 of file moc_predefs.h.
◆ __unix__
#define __unix__   1
Definition at line 104 of file moc_predefs.h.
◆ __INT_WIDTH__
Definition at line 105 of file moc_predefs.h.
◆ __SIZEOF_LONG__
Definition at line 106 of file moc_predefs.h.
◆ __STDC_IEC_559__
Definition at line 107 of file moc_predefs.h.
◆ __STDC_ISO_10646__
Definition at line 108 of file moc_predefs.h.
◆ __UINT16_C
#define __UINT16_C (   c)    c
Definition at line 109 of file moc_predefs.h.
◆ __DECIMAL_DIG__
Definition at line 110 of file moc_predefs.h.
◆ __STDC_IEC_559_COMPLEX__
Definition at line 111 of file moc_predefs.h.
◆ __FLT64_EPSILON__
Definition at line 112 of file moc_predefs.h.
◆ __gnu_linux__
Definition at line 113 of file moc_predefs.h.
◆ __INT16_MAX__
Definition at line 114 of file moc_predefs.h.
◆ __FLT64_MIN_EXP__
Definition at line 115 of file moc_predefs.h.
◆ __FLT64X_MIN_10_EXP__
Definition at line 116 of file moc_predefs.h.
◆ __LDBL_HAS_QUIET_NAN__
Definition at line 117 of file moc_predefs.h.
◆ __FLT64_MANT_DIG__
Definition at line 118 of file moc_predefs.h.
◆ FlipBookPlugin_EXPORTS
Definition at line 119 of file moc_predefs.h.
◆ __FLT64X_MANT_DIG__
Definition at line 120 of file moc_predefs.h.
◆ __GNUC__
#define __GNUC__   11
Definition at line 121 of file moc_predefs.h.
◆ __GXX_RTTI
Definition at line 122 of file moc_predefs.h.
◆ __MMX__
#define __MMX__   1
Definition at line 123 of file moc_predefs.h.
◆ __FLT_HAS_DENORM__
Definition at line 124 of file moc_predefs.h.
◆ __SIZEOF_LONG_DOUBLE__
Definition at line 125 of file moc_predefs.h.
◆ __BIGGEST_ALIGNMENT__
Definition at line 126 of file moc_predefs.h.
◆ __STDC_UTF_16__
Definition at line 127 of file moc_predefs.h.
◆ __FLT64_MAX_10_EXP__
Definition at line 128 of file moc_predefs.h.
◆ __cpp_delegating_constructors
Definition at line 129 of file moc_predefs.h.
◆ __FLT32_HAS_INFINITY__
Definition at line 130 of file moc_predefs.h.
◆ __DBL_MAX__
Definition at line 131 of file moc_predefs.h.
◆ __cpp_raw_strings
Definition at line 132 of file moc_predefs.h.
◆ __INT_FAST32_MAX__
Definition at line 133 of file moc_predefs.h.
◆ __DBL_HAS_INFINITY__
Definition at line 134 of file moc_predefs.h.
◆ __SIZEOF_FLOAT__
Definition at line 135 of file moc_predefs.h.
◆ __HAVE_SPECULATION_SAFE_VALUE
Definition at line 136 of file moc_predefs.h.
◆ __cpp_fold_expressions
Definition at line 137 of file moc_predefs.h.
◆ __DEC32_MIN_EXP__
Definition at line 138 of file moc_predefs.h.
◆ __INTPTR_WIDTH__
Definition at line 139 of file moc_predefs.h.
◆ __FLT64X_HAS_INFINITY__
Definition at line 140 of file moc_predefs.h.
◆ __UINT_LEAST32_MAX__
Definition at line 141 of file moc_predefs.h.
◆ __FLT32X_HAS_DENORM__
Definition at line 142 of file moc_predefs.h.
◆ __INT_FAST16_TYPE__
Definition at line 143 of file moc_predefs.h.
◆ __MMX_WITH_SSE__
Definition at line 144 of file moc_predefs.h.
◆ __LDBL_HAS_DENORM__
Definition at line 145 of file moc_predefs.h.
◆ QT_WIDGETS_LIB
Definition at line 146 of file moc_predefs.h.
◆ __cplusplus
Definition at line 147 of file moc_predefs.h.
◆ __cpp_ref_qualifiers
Definition at line 148 of file moc_predefs.h.
◆ __DEC32_MIN__
Definition at line 149 of file moc_predefs.h.
◆ __DEPRECATED
Definition at line 150 of file moc_predefs.h.
◆ __cpp_rvalue_references
Definition at line 151 of file moc_predefs.h.
◆ __DBL_MAX_EXP__
Definition at line 152 of file moc_predefs.h.
◆ __WCHAR_WIDTH__
Definition at line 153 of file moc_predefs.h.
◆ __FLT32_MAX__
Definition at line 154 of file moc_predefs.h.
◆ __DEC128_EPSILON__
Definition at line 155 of file moc_predefs.h.
◆ __SSE2_MATH__
Definition at line 156 of file moc_predefs.h.
◆ __ATOMIC_HLE_RELEASE
Definition at line 157 of file moc_predefs.h.
◆ __PTRDIFF_MAX__
Definition at line 158 of file moc_predefs.h.
◆ __amd64
#define __amd64   1
Definition at line 159 of file moc_predefs.h.
◆ __ATOMIC_HLE_ACQUIRE
Definition at line 160 of file moc_predefs.h.
◆ __GNUG__
#define __GNUG__   11
Definition at line 161 of file moc_predefs.h.
◆ __LONG_LONG_MAX__
Definition at line 162 of file moc_predefs.h.
◆ __SIZEOF_SIZE_T__
Definition at line 163 of file moc_predefs.h.
◆ __cpp_nsdmi
Definition at line 164 of file moc_predefs.h.
◆ __FLT64X_MIN_EXP__
Definition at line 165 of file moc_predefs.h.
◆ __SIZEOF_WINT_T__
Definition at line 166 of file moc_predefs.h.
◆ __LONG_LONG_WIDTH__
Definition at line 167 of file moc_predefs.h.
◆ __cpp_initializer_lists
Definition at line 168 of file moc_predefs.h.
◆ __FLT32_MAX_EXP__
Definition at line 169 of file moc_predefs.h.
◆ ABI_ID
Definition at line 170 of file moc_predefs.h.
◆ __cpp_hex_float
Definition at line 171 of file moc_predefs.h.
◆ __GXX_ABI_VERSION
Definition at line 172 of file moc_predefs.h.
◆ __FLT128_HAS_INFINITY__
Definition at line 173 of file moc_predefs.h.
◆ kiss_fft_scalar
Definition at line 174 of file moc_predefs.h.
◆ __FLT_MIN_EXP__
Definition at line 175 of file moc_predefs.h.
◆ __GCC_HAVE_DWARF2_CFI_ASM
Definition at line 176 of file moc_predefs.h.
◆ __x86_64
#define __x86_64   1
Definition at line 177 of file moc_predefs.h.
◆ __cpp_lambdas
Definition at line 178 of file moc_predefs.h.
◆ __INT_FAST64_TYPE__
Definition at line 179 of file moc_predefs.h.
◆ __FLT64_DENORM_MIN__
Definition at line 180 of file moc_predefs.h.
◆ PROTOBUF_USE_DLLS
Definition at line 181 of file moc_predefs.h.
◆ __cpp_template_auto
Definition at line 182 of file moc_predefs.h.
◆ __DBL_MIN__
Definition at line 183 of file moc_predefs.h.
◆ __FLT128_EPSILON__
Definition at line 184 of file moc_predefs.h.
◆ __FLT64X_NORM_MAX__
Definition at line 185 of file moc_predefs.h.
◆ __SIZEOF_POINTER__
Definition at line 186 of file moc_predefs.h.
◆ __LP64__
#define __LP64__   1
Definition at line 187 of file moc_predefs.h.
◆ __DBL_HAS_QUIET_NAN__
Definition at line 188 of file moc_predefs.h.
◆ __FLT32X_EPSILON__
Definition at line 189 of file moc_predefs.h.
◆ __DECIMAL_BID_FORMAT__
Definition at line 190 of file moc_predefs.h.
◆ __FLT64_MIN_10_EXP__
Definition at line 191 of file moc_predefs.h.
◆ __FLT64X_DECIMAL_DIG__
Definition at line 192 of file moc_predefs.h.
◆ __DEC128_MIN__
Definition at line 193 of file moc_predefs.h.
◆ __REGISTER_PREFIX__
Definition at line 194 of file moc_predefs.h.
◆ __UINT16_MAX__
Definition at line 195 of file moc_predefs.h.
◆ __LDBL_HAS_INFINITY__
Definition at line 196 of file moc_predefs.h.
◆ __FLT32_MIN__
Definition at line 197 of file moc_predefs.h.
◆ __UINT8_TYPE__
Definition at line 198 of file moc_predefs.h.
◆ __FLT_DIG__
Definition at line 199 of file moc_predefs.h.
◆ __NO_INLINE__
Definition at line 200 of file moc_predefs.h.
◆ __DEC_EVAL_METHOD__
Definition at line 201 of file moc_predefs.h.
◆ __DEC128_MAX__
Definition at line 202 of file moc_predefs.h.
◆ QT_NO_KEYWORDS
Definition at line 203 of file moc_predefs.h.
◆ __FLT_MANT_DIG__
Definition at line 204 of file moc_predefs.h.
◆ __LDBL_DECIMAL_DIG__
Definition at line 205 of file moc_predefs.h.
◆ __VERSION__
Definition at line 206 of file moc_predefs.h.
◆ __UINT64_C
#define __UINT64_C (   c)    c ## UL
Definition at line 207 of file moc_predefs.h.
◆ __cpp_unicode_characters
Definition at line 208 of file moc_predefs.h.
◆ _STDC_PREDEF_H
Definition at line 209 of file moc_predefs.h.
◆ GLAD_API_CALL_EXPORT
Definition at line 210 of file moc_predefs.h.
◆ __INT_LEAST32_MAX__
Definition at line 211 of file moc_predefs.h.
◆ __GCC_ATOMIC_INT_LOCK_FREE
Definition at line 212 of file moc_predefs.h.
◆ __FLT128_MAX_EXP__
Definition at line 213 of file moc_predefs.h.
◆ __FLT32_MANT_DIG__
Definition at line 214 of file moc_predefs.h.
◆ __FLOAT_WORD_ORDER__
Definition at line 215 of file moc_predefs.h.
◆ SIZEOF_DPTR
Definition at line 216 of file moc_predefs.h.
◆ __cpp_aggregate_bases
Definition at line 217 of file moc_predefs.h.
◆ __FLT128_HAS_DENORM__
Definition at line 218 of file moc_predefs.h.
◆ __FLT32_DECIMAL_DIG__
Definition at line 219 of file moc_predefs.h.
◆ __FLT128_DIG__
Definition at line 220 of file moc_predefs.h.
◆ __INT32_C
#define __INT32_C (   c)    c
Definition at line 221 of file moc_predefs.h.
◆ __DEC64_EPSILON__
Definition at line 222 of file moc_predefs.h.
◆ __ORDER_PDP_ENDIAN__
Definition at line 223 of file moc_predefs.h.
◆ __DEC128_MIN_EXP__
Definition at line 224 of file moc_predefs.h.
◆ __INT_FAST32_TYPE__
Definition at line 225 of file moc_predefs.h.
◆ __UINT_LEAST16_TYPE__
Definition at line 226 of file moc_predefs.h.
◆ unix
#define unix   1
Definition at line 227 of file moc_predefs.h.
◆ __DBL_HAS_DENORM__
Definition at line 228 of file moc_predefs.h.
◆ __cpp_rtti
Definition at line 229 of file moc_predefs.h.
◆ __SIZE_TYPE__
Definition at line 230 of file moc_predefs.h.
◆ __UINT64_MAX__
Definition at line 231 of file moc_predefs.h.
◆ __FLT_IS_IEC_60559__
Definition at line 232 of file moc_predefs.h.
◆ __GNUC_WIDE_EXECUTION_CHARSET_NAME
Definition at line 233 of file moc_predefs.h.
◆ __FLT64X_DIG__
Definition at line 234 of file moc_predefs.h.
◆ __INT8_TYPE__
Definition at line 235 of file moc_predefs.h.
◆ __cpp_digit_separators
Definition at line 236 of file moc_predefs.h.
◆ __ELF__
#define __ELF__   1
Definition at line 237 of file moc_predefs.h.
◆ __GCC_ASM_FLAG_OUTPUTS__
Definition at line 238 of file moc_predefs.h.
◆ __UINT32_TYPE__
Definition at line 239 of file moc_predefs.h.
◆ __FLT_RADIX__
Definition at line 240 of file moc_predefs.h.
◆ __INT_LEAST16_TYPE__
Definition at line 241 of file moc_predefs.h.
◆ __LDBL_EPSILON__
Definition at line 242 of file moc_predefs.h.
◆ __UINTMAX_C
#define __UINTMAX_C (   c)    c ## UL
Definition at line 243 of file moc_predefs.h.
◆ __GNUC_RH_RELEASE__
Definition at line 244 of file moc_predefs.h.
◆ __GLIBCXX_BITSIZE_INT_N_0
Definition at line 245 of file moc_predefs.h.
◆ __k8
#define __k8   1
Definition at line 246 of file moc_predefs.h.
◆ __FLT32X_MIN__
Definition at line 247 of file moc_predefs.h.
◆ __SIG_ATOMIC_MAX__
Definition at line 248 of file moc_predefs.h.
◆ __GCC_ATOMIC_WCHAR_T_LOCK_FREE
Definition at line 249 of file moc_predefs.h.
◆ __SIZEOF_PTRDIFF_T__
Definition at line 250 of file moc_predefs.h.
◆ __LDBL_DIG__
Definition at line 251 of file moc_predefs.h.
◆ __FLT64_IS_IEC_60559__
Definition at line 252 of file moc_predefs.h.
◆ __x86_64__
Definition at line 253 of file moc_predefs.h.
◆ __FLT32X_MIN_EXP__
Definition at line 254 of file moc_predefs.h.
◆ __DEC32_SUBNORMAL_MIN__
Definition at line 255 of file moc_predefs.h.
◆ __INT_FAST16_MAX__
Definition at line 256 of file moc_predefs.h.
◆ __FLT64_DIG__
Definition at line 257 of file moc_predefs.h.
◆ __UINT_FAST32_MAX__
Definition at line 258 of file moc_predefs.h.
◆ __UINT_LEAST64_TYPE__
Definition at line 259 of file moc_predefs.h.
◆ __FLT_HAS_QUIET_NAN__
Definition at line 260 of file moc_predefs.h.
◆ __FLT_MAX_10_EXP__
Definition at line 261 of file moc_predefs.h.
◆ __LONG_MAX__
Definition at line 262 of file moc_predefs.h.
◆ __FLT64X_HAS_DENORM__
Definition at line 263 of file moc_predefs.h.
◆ __DEC128_SUBNORMAL_MIN__
Definition at line 264 of file moc_predefs.h.
◆ __FLT_HAS_INFINITY__
Definition at line 265 of file moc_predefs.h.
◆ __GNUC_EXECUTION_CHARSET_NAME
Definition at line 266 of file moc_predefs.h.
◆ __cpp_unicode_literals
Definition at line 267 of file moc_predefs.h.
◆ __UINT_FAST16_TYPE__
Definition at line 268 of file moc_predefs.h.
◆ __DEC64_MAX__
Definition at line 269 of file moc_predefs.h.
◆ __INT_FAST32_WIDTH__
Definition at line 270 of file moc_predefs.h.
◆ __CHAR16_TYPE__
Definition at line 271 of file moc_predefs.h.
◆ __PRAGMA_REDEFINE_EXTNAME
Definition at line 272 of file moc_predefs.h.
◆ __SIZE_WIDTH__
Definition at line 273 of file moc_predefs.h.
◆ __SEG_FS
#define __SEG_FS   1
Definition at line 274 of file moc_predefs.h.
◆ __INT_LEAST16_MAX__
Definition at line 275 of file moc_predefs.h.
◆ __DEC64_MANT_DIG__
Definition at line 276 of file moc_predefs.h.
◆ __INT64_MAX__
Definition at line 277 of file moc_predefs.h.
◆ __SEG_GS
#define __SEG_GS   1
Definition at line 278 of file moc_predefs.h.
◆ __FLT32_DENORM_MIN__
Definition at line 279 of file moc_predefs.h.
◆ __SIG_ATOMIC_WIDTH__
Definition at line 280 of file moc_predefs.h.
◆ __INT_LEAST64_TYPE__
Definition at line 281 of file moc_predefs.h.
◆ __INT16_TYPE__
Definition at line 282 of file moc_predefs.h.
◆ __INT_LEAST8_TYPE__
Definition at line 283 of file moc_predefs.h.
◆ __cpp_structured_bindings
Definition at line 284 of file moc_predefs.h.
◆ __SIZEOF_INT__
Definition at line 285 of file moc_predefs.h.
◆ __DEC32_MAX_EXP__
Definition at line 286 of file moc_predefs.h.
◆ __INT_FAST8_MAX__
Definition at line 287 of file moc_predefs.h.
◆ __FLT128_MAX__
Definition at line 288 of file moc_predefs.h.
◆ __INTPTR_MAX__
Definition at line 289 of file moc_predefs.h.
◆ __cpp_sized_deallocation
Definition at line 290 of file moc_predefs.h.
◆ __cpp_guaranteed_copy_elision
Definition at line 291 of file moc_predefs.h.
◆ linux
#define linux   1
Definition at line 292 of file moc_predefs.h.
◆ __FLT64_HAS_QUIET_NAN__
Definition at line 293 of file moc_predefs.h.
◆ __FLT32_MIN_10_EXP__
Definition at line 294 of file moc_predefs.h.
◆ __EXCEPTIONS
Definition at line 295 of file moc_predefs.h.
◆ __PTRDIFF_WIDTH__
Definition at line 296 of file moc_predefs.h.
◆ __LDBL_MANT_DIG__
Definition at line 297 of file moc_predefs.h.
◆ __cpp_range_based_for
Definition at line 298 of file moc_predefs.h.
◆ FMT_SHARED
Definition at line 299 of file moc_predefs.h.
◆ __FLT64_HAS_INFINITY__
Definition at line 300 of file moc_predefs.h.
◆ __FLT64X_MAX__
Definition at line 301 of file moc_predefs.h.
◆ __STDCPP_DEFAULT_NEW_ALIGNMENT__
Definition at line 302 of file moc_predefs.h.
◆ __SIG_ATOMIC_MIN__
Definition at line 303 of file moc_predefs.h.
◆ __code_model_small__
Definition at line 304 of file moc_predefs.h.
◆ __GCC_ATOMIC_LONG_LOCK_FREE
Definition at line 305 of file moc_predefs.h.
◆ __cpp_nontype_template_args
Definition at line 306 of file moc_predefs.h.
◆ __DEC32_MANT_DIG__
Definition at line 307 of file moc_predefs.h.
◆ __cpp_return_type_deduction
Definition at line 308 of file moc_predefs.h.
◆ __k8__
#define __k8__   1
Definition at line 309 of file moc_predefs.h.
◆ __INTPTR_TYPE__
Definition at line 310 of file moc_predefs.h.
◆ __UINT16_TYPE__
Definition at line 311 of file moc_predefs.h.
◆ __WCHAR_TYPE__
Definition at line 312 of file moc_predefs.h.
◆ __UINTPTR_MAX__
Definition at line 313 of file moc_predefs.h.
◆ __INT_FAST64_WIDTH__
Definition at line 314 of file moc_predefs.h.
◆ __cpp_decltype
Definition at line 315 of file moc_predefs.h.
◆ __INT_FAST64_MAX__
Definition at line 316 of file moc_predefs.h.
◆ __GCC_ATOMIC_TEST_AND_SET_TRUEVAL
Definition at line 317 of file moc_predefs.h.
◆ __FLT_NORM_MAX__
Definition at line 318 of file moc_predefs.h.
◆ __FLT64X_MAX_EXP__
Definition at line 319 of file moc_predefs.h.
◆ __UINT_FAST64_TYPE__
Definition at line 320 of file moc_predefs.h.
◆ __cpp_inline_variables
Definition at line 321 of file moc_predefs.h.
◆ __INT_MAX__
Definition at line 322 of file moc_predefs.h.
◆ __linux__
#define __linux__   1
Definition at line 323 of file moc_predefs.h.
◆ __INT64_TYPE__
Definition at line 324 of file moc_predefs.h.
◆ __FLT_MAX_EXP__
Definition at line 325 of file moc_predefs.h.
◆ __ORDER_BIG_ENDIAN__
Definition at line 326 of file moc_predefs.h.
◆ __DBL_MANT_DIG__
Definition at line 327 of file moc_predefs.h.
◆ __cpp_inheriting_constructors
Definition at line 328 of file moc_predefs.h.
◆ QT_CORE_LIB
Definition at line 329 of file moc_predefs.h.
◆ __SIZEOF_FLOAT128__
Definition at line 330 of file moc_predefs.h.
◆ __INT_LEAST64_MAX__
Definition at line 331 of file moc_predefs.h.
◆ __DEC64_MIN__
Definition at line 332 of file moc_predefs.h.
◆ __WINT_TYPE__
Definition at line 333 of file moc_predefs.h.
◆ __UINT_LEAST32_TYPE__
Definition at line 334 of file moc_predefs.h.
◆ __SIZEOF_SHORT__
Definition at line 335 of file moc_predefs.h.
◆ __FLT32_NORM_MAX__
Definition at line 336 of file moc_predefs.h.
◆ __SSE__
#define __SSE__   1
Definition at line 337 of file moc_predefs.h.
◆ __LDBL_MIN_EXP__
Definition at line 338 of file moc_predefs.h.
◆ __FLT64_MAX__
Definition at line 339 of file moc_predefs.h.
◆ __amd64__
#define __amd64__   1
Definition at line 340 of file moc_predefs.h.
◆ __WINT_WIDTH__
Definition at line 341 of file moc_predefs.h.
◆ __INT_LEAST64_WIDTH__
Definition at line 342 of file moc_predefs.h.
◆ __LDBL_MAX_EXP__
Definition at line 343 of file moc_predefs.h.
◆ __FLT32X_MAX_10_EXP__
Definition at line 344 of file moc_predefs.h.
◆ __SIZEOF_INT128__
Definition at line 345 of file moc_predefs.h.
◆ __FLT64X_IS_IEC_60559__
Definition at line 346 of file moc_predefs.h.
◆ __LDBL_MAX_10_EXP__
Definition at line 347 of file moc_predefs.h.
◆ __ATOMIC_RELAXED
Definition at line 348 of file moc_predefs.h.
◆ __DBL_EPSILON__
Definition at line 349 of file moc_predefs.h.
◆ __FLT128_MIN__
Definition at line 350 of file moc_predefs.h.
◆ _LP64
#define _LP64   1
Definition at line 351 of file moc_predefs.h.
◆ __UINT8_C
#define __UINT8_C (   c)    c
Definition at line 352 of file moc_predefs.h.
◆ __FLT64_MAX_EXP__
Definition at line 353 of file moc_predefs.h.
◆ __INT_LEAST32_TYPE__
Definition at line 354 of file moc_predefs.h.
◆ __SIZEOF_WCHAR_T__
Definition at line 355 of file moc_predefs.h.
◆ __GNUC_PATCHLEVEL__
Definition at line 356 of file moc_predefs.h.
◆ __FLT128_NORM_MAX__
Definition at line 357 of file moc_predefs.h.
◆ __FLT64_NORM_MAX__
Definition at line 358 of file moc_predefs.h.
◆ __FLT128_HAS_QUIET_NAN__
Definition at line 359 of file moc_predefs.h.
◆ __INTMAX_MAX__
Definition at line 360 of file moc_predefs.h.
◆ __INT_FAST8_TYPE__
Definition at line 361 of file moc_predefs.h.
◆ __cpp_namespace_attributes
Definition at line 362 of file moc_predefs.h.
◆ __FLT64X_MIN__
Definition at line 363 of file moc_predefs.h.
◆ __STDCPP_THREADS__
Definition at line 364 of file moc_predefs.h.
◆ __GNUC_STDC_INLINE__
Definition at line 365 of file moc_predefs.h.
◆ __FLT64_HAS_DENORM__
Definition at line 366 of file moc_predefs.h.
◆ __FLT32_EPSILON__
Definition at line 367 of file moc_predefs.h.
◆ __DBL_DECIMAL_DIG__
Definition at line 368 of file moc_predefs.h.
◆ __STDC_UTF_32__
Definition at line 369 of file moc_predefs.h.
◆ __INT_FAST8_WIDTH__
Definition at line 370 of file moc_predefs.h.
◆ __FXSR__
#define __FXSR__   1
Definition at line 371 of file moc_predefs.h.
◆ __FLT32X_MAX__
Definition at line 372 of file moc_predefs.h.
◆ __DBL_NORM_MAX__
Definition at line 373 of file moc_predefs.h.
◆ __BYTE_ORDER__
Definition at line 374 of file moc_predefs.h.
◆ __INTMAX_WIDTH__
Definition at line 375 of file moc_predefs.h.
◆ __cpp_runtime_arrays
Definition at line 376 of file moc_predefs.h.
◆ __UINT64_TYPE__
Definition at line 377 of file moc_predefs.h.
◆ __UINT32_C
#define __UINT32_C (   c)    c ## U
Definition at line 378 of file moc_predefs.h.
◆ __cpp_alias_templates
Definition at line 379 of file moc_predefs.h.
◆ __FLT_DENORM_MIN__
Definition at line 380 of file moc_predefs.h.
◆ __FLT128_IS_IEC_60559__
Definition at line 381 of file moc_predefs.h.
◆ __INT8_MAX__
Definition at line 382 of file moc_predefs.h.
◆ __LONG_WIDTH__
Definition at line 383 of file moc_predefs.h.
◆ __UINT_FAST32_TYPE__
Definition at line 384 of file moc_predefs.h.
◆ __FLT32X_NORM_MAX__
Definition at line 385 of file moc_predefs.h.
◆ __CHAR32_TYPE__
Definition at line 386 of file moc_predefs.h.
◆ __FLT_MAX__
Definition at line 387 of file moc_predefs.h.
◆ __cpp_constexpr
Definition at line 388 of file moc_predefs.h.
◆ __SSE2__
#define __SSE2__   1
Definition at line 389 of file moc_predefs.h.
◆ __cpp_deduction_guides
Definition at line 390 of file moc_predefs.h.
◆ __INT32_TYPE__
Definition at line 391 of file moc_predefs.h.
◆ __SIZEOF_DOUBLE__
Definition at line 392 of file moc_predefs.h.
◆ __cpp_exceptions
Definition at line 393 of file moc_predefs.h.
◆ __FLT_MIN_10_EXP__
Definition at line 394 of file moc_predefs.h.
◆ __FLT64_MIN__
Definition at line 395 of file moc_predefs.h.
◆ __INT_LEAST32_WIDTH__
Definition at line 396 of file moc_predefs.h.
◆ __INTMAX_TYPE__
Definition at line 397 of file moc_predefs.h.
◆ __DEC128_MAX_EXP__
Definition at line 398 of file moc_predefs.h.
◆ __FLT32X_HAS_QUIET_NAN__
Definition at line 399 of file moc_predefs.h.
◆ __ATOMIC_CONSUME
Definition at line 400 of file moc_predefs.h.
◆ __GNUC_MINOR__
Definition at line 401 of file moc_predefs.h.
◆ __GLIBCXX_TYPE_INT_N_0
Definition at line 402 of file moc_predefs.h.
◆ __INT_FAST16_WIDTH__
Definition at line 403 of file moc_predefs.h.
◆ __UINTMAX_MAX__
Definition at line 404 of file moc_predefs.h.
◆ __FLT32X_DENORM_MIN__
Definition at line 405 of file moc_predefs.h.
◆ __cpp_template_template_args
Definition at line 406 of file moc_predefs.h.
◆ __DBL_MAX_10_EXP__
Definition at line 407 of file moc_predefs.h.
◆ __LDBL_DENORM_MIN__
Definition at line 408 of file moc_predefs.h.
◆ __INT16_C
#define __INT16_C (   c)    c
Definition at line 409 of file moc_predefs.h.
◆ __STDC__
#define __STDC__   1
Definition at line 410 of file moc_predefs.h.
◆ __FLT32X_DIG__
Definition at line 411 of file moc_predefs.h.
◆ __PTRDIFF_TYPE__
Definition at line 412 of file moc_predefs.h.
◆ __ATOMIC_SEQ_CST
Definition at line 413 of file moc_predefs.h.
◆ __FLT32X_MIN_10_EXP__
Definition at line 414 of file moc_predefs.h.
◆ __UINTPTR_TYPE__
Definition at line 415 of file moc_predefs.h.
◆ __DEC64_SUBNORMAL_MIN__
Definition at line 416 of file moc_predefs.h.
◆ __DEC128_MANT_DIG__
Definition at line 417 of file moc_predefs.h.
◆ __LDBL_MIN_10_EXP__
Definition at line 418 of file moc_predefs.h.
◆ __cpp_generic_lambdas
Definition at line 419 of file moc_predefs.h.
◆ __SSE_MATH__
Definition at line 420 of file moc_predefs.h.
◆ __SIZEOF_LONG_LONG__
Definition at line 421 of file moc_predefs.h.
◆ __cpp_user_defined_literals
Definition at line 422 of file moc_predefs.h.
◆ __FLT128_DECIMAL_DIG__
Definition at line 423 of file moc_predefs.h.
◆ __GCC_ATOMIC_LLONG_LOCK_FREE
Definition at line 424 of file moc_predefs.h.
◆ __FLT32_HAS_QUIET_NAN__
Definition at line 425 of file moc_predefs.h.
◆ __FLT_DECIMAL_DIG__
Definition at line 426 of file moc_predefs.h.
◆ __UINT_FAST16_MAX__
Definition at line 427 of file moc_predefs.h.
◆ __LDBL_NORM_MAX__
Definition at line 428 of file moc_predefs.h.
◆ __GCC_ATOMIC_SHORT_LOCK_FREE
Definition at line 429 of file moc_predefs.h.
◆ __UINT_FAST8_TYPE__
Definition at line 430 of file moc_predefs.h.
◆ _GNU_SOURCE
Definition at line 431 of file moc_predefs.h.
◆ __cpp_init_captures
Definition at line 432 of file moc_predefs.h.
◆ __ATOMIC_ACQ_REL
Definition at line 433 of file moc_predefs.h.
◆ __ATOMIC_RELEASE
Definition at line 434 of file moc_predefs.h.
