#include <vtksys/Configure.h>
Typedefs | |
| typedef struct kwsysProcess_s | kwsysProcess |
| Process control data structure. More... | |
| typedef int | kwsysProcess_Pipe_Handle |
| kwsysEXPORT kwsysProcess * | kwsysProcess_New (void) |
| Create a new Process instance. More... | |
| kwsysEXPORT void | kwsysProcess_Delete (kwsysProcess *cp) |
| Delete an existing Process instance. More... | |
| kwsysEXPORT int | kwsysProcess_SetCommand (kwsysProcess *cp, char const *const *command) |
| Set the command line to be executed. More... | |
| kwsysEXPORT int | kwsysProcess_AddCommand (kwsysProcess *cp, char const *const *command) |
| Add a command line to be executed. More... | |
| kwsysEXPORT void | kwsysProcess_SetTimeout (kwsysProcess *cp, double timeout) |
| Set the timeout in seconds for the child process. More... | |
| kwsysEXPORT int | kwsysProcess_SetWorkingDirectory (kwsysProcess *cp, const char *dir) |
| Set the working directory for the child process. More... | |
| kwsysEXPORT int | kwsysProcess_SetPipeFile (kwsysProcess *cp, int pipe, const char *file) |
| Set the name of a file to be attached to the given pipe. More... | |
| kwsysEXPORT void | kwsysProcess_SetPipeShared (kwsysProcess *cp, int pipe, int shared) |
| Set whether the given pipe in the child is shared with the parent process. More... | |
| kwsysEXPORT void | kwsysProcess_SetPipeNative (kwsysProcess *cp, int pipe, const kwsysProcess_Pipe_Handle p[2]) |
| Specify a platform-specific native pipe for use as one of the child interface pipes. More... | |
| kwsysEXPORT int | kwsysProcess_GetOption (kwsysProcess *cp, int optionId) |
| Get/Set a possibly platform-specific option. More... | |
| kwsysEXPORT void | kwsysProcess_SetOption (kwsysProcess *cp, int optionId, int value) |
| kwsysEXPORT int | kwsysProcess_GetState (kwsysProcess *cp) |
| Get the current state of the Process instance. More... | |
| kwsysEXPORT int | kwsysProcess_GetExitException (kwsysProcess *cp) |
| When GetState returns "Exception", this method returns a platform-independent description of the exceptional behavior that caused the child to terminate abnormally. More... | |
| kwsysEXPORT int | kwsysProcess_GetExitCode (kwsysProcess *cp) |
| When GetState returns "Exited" or "Exception", this method returns the platform-specific raw exit code of the process. More... | |
| kwsysEXPORT int | kwsysProcess_GetExitValue (kwsysProcess *cp) |
| When GetState returns "Exited", this method returns the child's platform-independent exit code (such as the value returned by the child's main). More... | |
| kwsysEXPORT const char * | kwsysProcess_GetErrorString (kwsysProcess *cp) |
| When GetState returns "Error", this method returns a string describing the problem. More... | |
| kwsysEXPORT const char * | kwsysProcess_GetExceptionString (kwsysProcess *cp) |
| When GetState returns "Exception", this method returns a string describing the problem. More... | |
| kwsysEXPORT int | kwsysProcess_GetStateByIndex (kwsysProcess *cp, int idx) |
| kwsysEXPORT int | kwsysProcess_GetExitExceptionByIndex (kwsysProcess *cp, int idx) |
| kwsysEXPORT int | kwsysProcess_GetExitCodeByIndex (kwsysProcess *cp, int idx) |
| kwsysEXPORT int | kwsysProcess_GetExitValueByIndex (kwsysProcess *cp, int idx) |
| kwsysEXPORT const char * | kwsysProcess_GetExceptionStringByIndex (kwsysProcess *cp, int idx) |
| kwsysEXPORT void | kwsysProcess_Execute (kwsysProcess *cp) |
| Start executing the child process. More... | |
| kwsysEXPORT void | kwsysProcess_Disown (kwsysProcess *cp) |
| Stop management of a detached child process. More... | |
| kwsysEXPORT int | kwsysProcess_WaitForData (kwsysProcess *cp, char **data, int *length, double *timeout) |
| Block until data are available on a pipe, a timeout expires, or the child process terminates. More... | |
| kwsysEXPORT int | kwsysProcess_WaitForExit (kwsysProcess *cp, double *timeout) |
| Block until the child process terminates or the given timeout expires. More... | |
| kwsysEXPORT void | kwsysProcess_Interrupt (kwsysProcess *cp) |
| Interrupt the process group for the child process that is currently running by sending it the appropriate operating-system specific signal. More... | |
| kwsysEXPORT void | kwsysProcess_Kill (kwsysProcess *cp) |
| Forcefully terminate the child process that is currently running. More... | |
| kwsysEXPORT void | kwsysProcess_KillPID (unsigned long) |
| Same as kwsysProcess_Kill using process ID to locate process to terminate. More... | |
| kwsysEXPORT void | kwsysProcess_ResetStartTime (kwsysProcess *cp) |
| Reset the start time of the child process to the current time. More... | |
| #define kwsysEXPORT vtksys_EXPORT |
| #define kwsysProcess kwsys_ns(Process) |
| #define kwsysProcess_SetCommand kwsys_ns(Process_SetCommand) |
| #define kwsysProcess_AddCommand kwsys_ns(Process_AddCommand) |
| #define kwsysProcess_SetTimeout kwsys_ns(Process_SetTimeout) |
| #define kwsysProcess_SetWorkingDirectory kwsys_ns(Process_SetWorkingDirectory) |
| #define kwsysProcess_SetPipeFile kwsys_ns(Process_SetPipeFile) |
| #define kwsysProcess_SetPipeNative kwsys_ns(Process_SetPipeNative) |
| #define kwsysProcess_SetPipeShared kwsys_ns(Process_SetPipeShared) |
| #define kwsysProcess_Option_Detach kwsys_ns(Process_Option_Detach) |
| #define kwsysProcess_Option_HideWindow kwsys_ns(Process_Option_HideWindow) |
| #define kwsysProcess_Option_MergeOutput kwsys_ns(Process_Option_MergeOutput) |
| #define kwsysProcess_Option_Verbatim kwsys_ns(Process_Option_Verbatim) |
| #define kwsysProcess_Option_CreateProcessGroup kwsys_ns(Process_Option_CreateProcessGroup) |
| #define kwsysProcess_Option_e kwsys_ns(Process_Option_e) |
| #define kwsysProcess_State_Starting kwsys_ns(Process_State_Starting) |
| #define kwsysProcess_State_Error kwsys_ns(Process_State_Error) |
| #define kwsysProcess_State_Exception kwsys_ns(Process_State_Exception) |
| #define kwsysProcess_State_Executing kwsys_ns(Process_State_Executing) |
| #define kwsysProcess_State_Exited kwsys_ns(Process_State_Exited) |
| #define kwsysProcess_State_Expired kwsys_ns(Process_State_Expired) |
| #define kwsysProcess_State_Killed kwsys_ns(Process_State_Killed) |
| #define kwsysProcess_State_Disowned kwsys_ns(Process_State_Disowned) |
| #define kwsysProcess_State_e kwsys_ns(Process_State_e) |
| #define kwsysProcess_Exception_None kwsys_ns(Process_Exception_None) |
| #define kwsysProcess_Exception_Fault kwsys_ns(Process_Exception_Fault) |
| #define kwsysProcess_Exception_Illegal kwsys_ns(Process_Exception_Illegal) |
| #define kwsysProcess_Exception_Interrupt kwsys_ns(Process_Exception_Interrupt) |
| #define kwsysProcess_Exception_Numerical kwsys_ns(Process_Exception_Numerical) |
| #define kwsysProcess_Exception_Other kwsys_ns(Process_Exception_Other) |
| #define kwsysProcess_Exception_e kwsys_ns(Process_Exception_e) |
| #define kwsysProcess_GetExitException kwsys_ns(Process_GetExitException) |
| #define kwsysProcess_GetExitCode kwsys_ns(Process_GetExitCode) |
| #define kwsysProcess_GetExitValue kwsys_ns(Process_GetExitValue) |
| #define kwsysProcess_GetErrorString kwsys_ns(Process_GetErrorString) |
| #define kwsysProcess_GetExceptionString kwsys_ns(Process_GetExceptionString) |
| #define kwsysProcess_GetStateByIndex kwsys_ns(Process_GetStateByIndex) |
| #define kwsysProcess_GetExitExceptionByIndex kwsys_ns(Process_GetExitExceptionByIndex) |
| #define kwsysProcess_GetExitCodeByIndex kwsys_ns(Process_GetExitCodeByIndex) |
| #define kwsysProcess_GetExitValueByIndex kwsys_ns(Process_GetExitValueByIndex) |
| #define kwsysProcess_GetExceptionStringByIndex kwsys_ns(Process_GetExceptionStringByIndex) |
| #define kwsysProcess_WaitForData kwsys_ns(Process_WaitForData) |
| #define kwsysProcess_Pipes_e kwsys_ns(Process_Pipes_e) |
| #define kwsysProcess_Pipe_STDIN kwsys_ns(Process_Pipe_STDIN) |
| #define kwsysProcess_Pipe_STDOUT kwsys_ns(Process_Pipe_STDOUT) |
| #define kwsysProcess_Pipe_STDERR kwsys_ns(Process_Pipe_STDERR) |
| #define kwsysProcess_Pipe_Timeout kwsys_ns(Process_Pipe_Timeout) |
| #define kwsysProcess_Pipe_Handle kwsys_ns(Process_Pipe_Handle) |
| #define kwsysProcess_WaitForExit kwsys_ns(Process_WaitForExit) |
| #define kwsysProcess_ResetStartTime kwsys_ns(Process_ResetStartTime) |
| typedef struct kwsysProcess_s kwsysProcess |
| typedef int kwsysProcess_Pipe_Handle |
| enum kwsysProcess_State_e |
| enum kwsysProcess_Pipes_e |
| kwsysEXPORT kwsysProcess* kwsysProcess_New | ( | void | ) |
| kwsysEXPORT void kwsysProcess_Delete | ( | kwsysProcess * | cp | ) |
If the instance is currently executing a process, this blocks until the process terminates.
| kwsysEXPORT int kwsysProcess_SetCommand | ( | kwsysProcess * | cp, |
| char const *const * | command | ||
Argument is an array of pointers to the command and each argument. The array must end with a NULL pointer. Any previous command lines are removed. Returns 1 for success and 0 otherwise.
| kwsysEXPORT int kwsysProcess_AddCommand | ( | kwsysProcess * | cp, |
Argument is an array of pointers to the command and each argument. The array must end with a NULL pointer. If this is not the first command added, its standard input will be connected to the standard output of the previous command. Returns 1 for success and 0 otherwise.
| kwsysEXPORT void kwsysProcess_SetTimeout | ( | kwsysProcess * | cp, |
| double | timeout | ||
The timeout period begins when the child is executed. If the child has not terminated when the timeout expires, it will be killed. A non-positive (<= 0) value will disable the timeout.
| kwsysEXPORT int kwsysProcess_SetWorkingDirectory | ( | kwsysProcess * | cp, |
| const char * | dir | ||
The working directory can be absolute or relative to the current directory. Returns 1 for success and 0 for failure.
| kwsysEXPORT int kwsysProcess_SetPipeFile | ( | kwsysProcess * | cp, |
| int | pipe, | ||
| const char * | file | ||
| kwsysEXPORT void kwsysProcess_SetPipeShared | ( | kwsysProcess * | cp, |
| int | pipe, | ||
| int | shared | ||
The default is no for Pipe_STDOUT and Pipe_STDERR and yes for Pipe_STDIN.
| kwsysEXPORT void kwsysProcess_SetPipeNative | ( | kwsysProcess * | cp, |
| int | pipe, | ||
| const kwsysProcess_Pipe_Handle | p[2] | ||
The native pipe is specified by an array of two descriptors or handles. The first entry in the array (index 0) should be the read end of the pipe. The second entry in the array (index 1) should be the write end of the pipe. If a null pointer is given the option will be disabled.
For Pipe_STDIN the native pipe is connected to the first child in the pipeline as its stdin. After the children are created the write end of the pipe will be closed in the child process and the read end will be closed in the parent process.
For Pipe_STDOUT and Pipe_STDERR the pipe is connected to the last child as its stdout or stderr. After the children are created the write end of the pipe will be closed in the parent process and the read end will be closed in the child process.
| kwsysEXPORT int kwsysProcess_GetOption | ( | kwsysProcess * | cp, |
| int | optionId | ||
Possible options are:
kwsysProcess_Option_Detach = Whether to detach the process. 0 = No (default) 1 = Yes
kwsysProcess_Option_HideWindow = Whether to hide window on Windows. 0 = No (default) 1 = Yes
kwsysProcess_Option_MergeOutput = Whether to merge stdout/stderr. No content will be returned as stderr. Any actual stderr will be on stdout. 0 = No (default) 1 = Yes
kwsysProcess_Option_Verbatim = Whether SetCommand and AddCommand should treat the first argument as a verbatim command line and ignore the rest of the arguments. 0 = No (default) 1 = Yes
kwsysProcess_Option_CreateProcessGroup = Whether to place the process in a new process group. This is useful if you want to send Ctrl+C to the process. On UNIX, also places the process in a new session. 0 = No (default) 1 = Yes
| kwsysEXPORT void kwsysProcess_SetOption | ( | kwsysProcess * | cp, |
| int | optionId, | ||
| int | value | ||
| kwsysEXPORT int kwsysProcess_GetState | ( | kwsysProcess * | cp | ) |
Possible states are:
kwsysProcess_State_Starting = Execute has not yet been called. kwsysProcess_State_Error = Error administrating the child process. kwsysProcess_State_Exception = Child process exited abnormally. kwsysProcess_State_Executing = Child process is currently running. kwsysProcess_State_Exited = Child process exited normally. kwsysProcess_State_Expired = Child process's timeout expired. kwsysProcess_State_Killed = Child process terminated by Kill method. kwsysProcess_State_Disowned = Child is no longer managed by this object.
| kwsysEXPORT int kwsysProcess_GetExitException | ( | kwsysProcess * | cp | ) |
Possible exceptions are:
kwsysProcess_Exception_None = No exceptional behavior occurred. kwsysProcess_Exception_Fault = Child crashed with a memory fault. kwsysProcess_Exception_Illegal = Child crashed with an illegal instruction. kwsysProcess_Exception_Interrupt = Child was interrupted by user (Cntl-C/Break). kwsysProcess_Exception_Numerical = Child crashed with a numerical exception. kwsysProcess_Exception_Other = Child terminated for another reason.
| kwsysEXPORT int kwsysProcess_GetExitCode | ( | kwsysProcess * | cp | ) |
UNIX platforms should use WIFEXITED/WEXITSTATUS and WIFSIGNALED/WTERMSIG to access this value. Windows users should compare the value to the various EXCEPTION_* values.
If GetState returns "Exited", use GetExitValue to get the platform-independent child return value.
| kwsysEXPORT int kwsysProcess_GetExitValue | ( | kwsysProcess * | cp | ) |
| kwsysEXPORT const char* kwsysProcess_GetErrorString | ( | kwsysProcess * | cp | ) |
Otherwise, it returns NULL.
| kwsysEXPORT const char* kwsysProcess_GetExceptionString | ( | kwsysProcess * | cp | ) |
| kwsysEXPORT int kwsysProcess_GetStateByIndex | ( | kwsysProcess * | cp, |
| int | idx | ||
kwsysProcess_StateByIndex_Starting = Execute has not yet been called. kwsysProcess_StateByIndex_Exception = Child process exited abnormally. kwsysProcess_StateByIndex_Exited = Child process exited normally. kwsysProcess_StateByIndex_Error = Error getting the child return code.
| kwsysEXPORT int kwsysProcess_GetExitExceptionByIndex | ( | kwsysProcess * | cp, |
| int | idx | ||
| kwsysEXPORT int kwsysProcess_GetExitCodeByIndex | ( | kwsysProcess * | cp, |
| int | idx | ||
| kwsysEXPORT int kwsysProcess_GetExitValueByIndex | ( | kwsysProcess * | cp, |
| int | idx | ||
| kwsysEXPORT const char* kwsysProcess_GetExceptionStringByIndex | ( | kwsysProcess * | cp, |
| int | idx | ||
| kwsysEXPORT void kwsysProcess_Execute | ( | kwsysProcess * | cp | ) |
| kwsysEXPORT void kwsysProcess_Disown | ( | kwsysProcess * | cp | ) |
This closes any pipes being read. If the child was not created with the kwsysProcess_Option_Detach option, this method does nothing. This is because disowning a non-detached process will cause the child exit signal to be left unhandled until this process exits.
| kwsysEXPORT int kwsysProcess_WaitForData | ( | kwsysProcess * | cp, |
| char ** | data, | ||
| int * | length, | ||
| double * | timeout | ||
Arguments are as follows:
data = If data are read, the pointer to which this points is set to point to the data. length = If data are read, the integer to which this points is set to the length of the data read. timeout = Specifies the maximum time this call may block. Upon return after reading data, the time elapsed is subtracted from the timeout value. If this timeout expires, the value is set to 0. A NULL pointer passed for this argument indicates no timeout for the call. A negative or zero value passed for this argument may be used for polling and will always return immediately.
Return value will be one of:
Pipe_None = No more data will be available from the child process, ( == 0) or no process has been executed. WaitForExit should be called to wait for the process to terminate. Pipe_STDOUT = Data have been read from the child's stdout pipe. Pipe_STDERR = Data have been read from the child's stderr pipe. Pipe_Timeout = No data available within timeout specified for the call. Time elapsed has been subtracted from timeout argument.
| kwsysEXPORT int kwsysProcess_WaitForExit | ( | kwsysProcess * | cp, |
If no process is running, returns immediately. The argument is:
timeout = Specifies the maximum time this call may block. Upon returning due to child termination, the elapsed time is subtracted from the given value. A NULL pointer passed for this argument indicates no timeout for the call.
0 = Child did not terminate within timeout specified for the call. Time elapsed has been subtracted from timeout argument. 1 = Child has terminated or was not running.
| kwsysEXPORT void kwsysProcess_Interrupt | ( | kwsysProcess * | cp | ) |
The caller should call WaitForExit after this returns to wait for the child to terminate.
WARNING: If you didn't specify kwsysProcess_Option_CreateProcessGroup, you will interrupt your own process group.
| kwsysEXPORT void kwsysProcess_Kill | ( | kwsysProcess * | cp | ) |
| kwsysEXPORT void kwsysProcess_KillPID | ( | unsigned | long | ) |
| kwsysEXPORT void kwsysProcess_ResetStartTime | ( | kwsysProcess * | cp | ) |
1.8.13 on Sat Dec 13 2025
