1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Remoting/ClientServerStream
47  "/builds/gitlab-kitware-sciviz-ci/Remoting/ClientServerStream/vtkClientServerID.h"
48  "/builds/gitlab-kitware-sciviz-ci/Remoting/ClientServerStream/vtkClientServerInterpreter.h"
49  "/builds/gitlab-kitware-sciviz-ci/Remoting/ClientServerStream/vtkClientServerInterpreterInitializer.h"
50  "/builds/gitlab-kitware-sciviz-ci/Remoting/ClientServerStream/vtkClientServerStream.h"
51  "/builds/gitlab-kitware-sciviz-ci/Remoting/ClientServerStream/vtkClientServerStreamInstantiator.h"
52  "/builds/gitlab-kitware-sciviz-ci/build/Remoting/ClientServerStream/vtkRemotingClientServerStreamModule.h"
53  )
54 endif()
55
56 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
57  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkRemotingClientServerStream-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkRemotingClientServerStream-hierarchy.txt")
58 endif()
59
60 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
61  foreach(file
62  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingClientServerStream-pv5.13.so.5.13"
63  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingClientServerStream-pv5.13.so.1"
64  )
65  if(EXISTS "${file}" AND
66  NOT IS_SYMLINK "${file}")
67  file(RPATH_CHECK
68  FILE "${file}"
69  RPATH "\$ORIGIN")
70  endif()
71  endforeach()
72  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
73  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRemotingClientServerStream-pv5.13.so.5.13"
74  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRemotingClientServerStream-pv5.13.so.1"
75  )
76  foreach(file
77  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingClientServerStream-pv5.13.so.5.13"
78  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingClientServerStream-pv5.13.so.1"
79  )
80  if(EXISTS "${file}" AND
81  NOT IS_SYMLINK "${file}")
82  file(RPATH_CHANGE
83  FILE "${file}"
84  OLD_RPATH "\$ORIGIN:"
85  NEW_RPATH "\$ORIGIN")
86  if(CMAKE_INSTALL_DO_STRIP)
87  execute_process(COMMAND "/usr/bin/strip" "${file}")
88  endif()
89  endif()
90  endforeach()
91 endif()
92
93 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
94  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingClientServerStream-pv5.13.so" AND
95  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingClientServerStream-pv5.13.so")
96  file(RPATH_CHECK
97  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingClientServerStream-pv5.13.so"
98  RPATH "\$ORIGIN")
99  endif()
100  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRemotingClientServerStream-pv5.13.so")
101  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingClientServerStream-pv5.13.so" AND
102  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingClientServerStream-pv5.13.so")
103  file(RPATH_CHANGE
104  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingClientServerStream-pv5.13.so"
105  OLD_RPATH "\$ORIGIN:"
106  NEW_RPATH "\$ORIGIN")
107  if(CMAKE_INSTALL_DO_STRIP)
108  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingClientServerStream-pv5.13.so")
109  endif()
110  endif()
111 endif()
112
113 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xspdxx" OR NOT CMAKE_INSTALL_COMPONENT)
114  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Remoting/ClientServerStream/vtkRemotingClientServerStream.spdx")
115 endif()
116
