Store messages for the interpreter. More...
#include <vtkClientServerStream.h>
struct | Argument |
Proxy-object returned by the two-argument form of GetArgument. More... | |
struct | Array |
Proxy-object returned by InsertArray and used to insert array data into the stream. More... | |
enum | Commands { New, Invoke, Delete, Assign, Reply, Error, EndOfCommands } |
Enumeration of message types that may be stored in a stream. More... | |
enum | Types { int8_value, int8_array, int16_value, int16_array, int32_value, int32_array, int64_value, int64_array, uint8_value, uint8_array, uint16_value, uint16_array, uint32_value, uint32_array, uint64_value, uint64_array, float32_value, float32_array, float64_value, float64_array, bool_value, string_value, id_value, vtk_object_pointer, stream_value, LastResult, End } |
Enumeration of data types that may be stored in a stream. More... | |
void | Reserve (size_t size) |
Ask the stream to allocate at least the given size in memory to avoid too many reallocations during stream construction. More... | |
void | Reset () |
Reset the stream to an empty state. More... | |
void | Copy (const vtkClientServerStream *source) |
Copy the stream contents from another stream. More... | |
int | GetNumberOfMessages () const |
Get the number of complete messages currently stored in the stream. More... | |
vtkClientServerStream::Commands | GetCommand (int message) const |
Get the command in the message with the given index. More... | |
int | GetNumberOfArguments (int message) const |
Get the number of arguments in the message with the given index. More... | |
vtkClientServerStream::Types | GetArgumentType (int message, int argument) const |
Get the type of the given argument in the given message. More... | |
int | GetArgument (int message, int &argument, vtkVariant *value) const |
Get the value of the given argument in the given message. More... | |
int | GetArgumentLength (int message, int argument, vtkTypeUInt32 *length) const |
Get the length of an argument of an array type. More... | |
int | GetArgumentObject (int message, int argument, vtkObjectBase **value, const char *type) const |
Get the given argument in the given message as an object of a particular vtkObjectBase type. More... | |
vtkClientServerStream::Argument | GetArgument (int message, int argument) const |
Get the given argument of the given message in a form that can be sent to another stream. More... | |
int | GetData (const unsigned char **data, size_t *length) const |
Get a pointer to the stream data and its length. More... | |
int | SetData (const unsigned char *data, size_t length) |
Construct the entire stream from the given data. More... | |
int | StreamFromString (const char *str) |
Set the stream by parsing the given string. More... | |
vtkClientServerStream (vtkObjectBase *owner=nullptr) | |
Constructor/Destructor manage references of vtk objects stored in the stream along with the rest of the stream data. More... | |
~vtkClientServerStream () | |
vtkClientServerStream (const vtkClientServerStream &, vtkObjectBase *owner=nullptr) | |
Copy constructor and assignment operator copy all stream data. More... | |
vtkClientServerStream & | operator= (const vtkClientServerStream &) |
int | GetArgument (int message, int argument, bool *value) const |
int | GetArgument (int message, int argument, signed char *value) const |
int | GetArgument (int message, int argument, char *value) const |
int | GetArgument (int message, int argument, short *value) const |
int | GetArgument (int message, int argument, int *value) const |
int | GetArgument (int message, int argument, long *value) const |
int | GetArgument (int message, int argument, unsigned char *value) const |
int | GetArgument (int message, int argument, unsigned short *value) const |
int | GetArgument (int message, int argument, unsigned int *value) const |
int | GetArgument (int message, int argument, unsigned long *value) const |
int | GetArgument (int message, int argument, float *value) const |
int | GetArgument (int message, int argument, double *value) const |
int | GetArgument (int message, int argument, long long *value) const |
int | GetArgument (int message, int argument, unsigned long long *value) const |
int | GetArgument (int message, int argument, signed char *value, vtkTypeUInt32 length) const |
int | GetArgument (int message, int argument, char *value, vtkTypeUInt32 length) const |
int | GetArgument (int message, int argument, short *value, vtkTypeUInt32 length) const |
int | GetArgument (int message, int argument, int *value, vtkTypeUInt32 length) const |
int | GetArgument (int message, int argument, long *value, vtkTypeUInt32 length) const |
int | GetArgument (int message, int argument, unsigned char *value, vtkTypeUInt32 length) const |
int | GetArgument (int message, int argument, unsigned short *value, vtkTypeUInt32 length) const |
int | GetArgument (int message, int argument, unsigned int *value, vtkTypeUInt32 length) const |
int | GetArgument (int message, int argument, unsigned long *value, vtkTypeUInt32 length) const |
int | GetArgument (int message, int argument, float *value, vtkTypeUInt32 length) const |
int | GetArgument (int message, int argument, double *value, vtkTypeUInt32 length) const |
int | GetArgument (int message, int argument, long long *value, vtkTypeUInt32 length) const |
int | GetArgument (int message, int argument, unsigned long long *value, vtkTypeUInt32 length) const |
int | GetArgument (int message, int argument, const char **value) const |
int | GetArgument (int message, int argument, char **value) const |
int | GetArgument (int message, int argument, vtkStdString *value) const |
int | GetArgument (int message, int argument, std::string *value) const |
int | GetArgument (int message, int argument, vtkClientServerStream *value) const |
int | GetArgument (int message, int argument, vtkClientServerID *value) const |
int | GetArgument (int message, int argument, vtkObjectBase **value) const |
vtkClientServerStream & | operator<< (vtkClientServerStream::Commands) |
Stream operators for special types. More... | |
vtkClientServerStream & | operator<< (vtkClientServerStream::Types) |
vtkClientServerStream & | operator<< (vtkClientServerStream::Argument) |
vtkClientServerStream & | operator<< (vtkClientServerStream::Array) |
vtkClientServerStream & | operator<< (const vtkClientServerStream &) |
vtkClientServerStream & | operator<< (vtkClientServerID) |
vtkClientServerStream & | operator<< (vtkObjectBase *) |
vtkClientServerStream & | operator<< (const vtkStdString &) |
vtkClientServerStream & | operator<< (const vtkVariant &) |
vtkClientServerStream & | operator<< (bool value) |
Stream operators for native types. More... | |
vtkClientServerStream & | operator<< (char value) |
vtkClientServerStream & | operator<< (short value) |
vtkClientServerStream & | operator<< (int value) |
vtkClientServerStream & | operator<< (long value) |
vtkClientServerStream & | operator<< (signed char value) |
vtkClientServerStream & | operator<< (unsigned char value) |
vtkClientServerStream & | operator<< (unsigned short value) |
vtkClientServerStream & | operator<< (unsigned int value) |
vtkClientServerStream & | operator<< (unsigned long value) |
vtkClientServerStream & | operator<< (long long value) |
vtkClientServerStream & | operator<< (unsigned long long value) |
vtkClientServerStream & | operator<< (float value) |
vtkClientServerStream & | operator<< (double value) |
vtkClientServerStream & | operator<< (const char *value) |
void | Print (ostream &) const |
Print the contents of the stream in a human-readable form. More... | |
void | Print (ostream &, vtkIndent) const |
void | PrintMessage (ostream &, int message) const |
void | PrintMessage (ostream &, int message, vtkIndent) const |
void | PrintArgument (ostream &, int message, int argument) const |
void | PrintArgument (ostream &, int message, int argument, vtkIndent) const |
void | PrintArgumentValue (ostream &, int message, int argument) const |
const char * | StreamToString () const |
Convert the stream to a string-based encoding. More... | |
void | StreamToString (ostream &os) const |
static vtkClientServerStream::Types | GetTypeFromString (const char *name) |
Get the type named by the given string. More... | |
static const char * | GetStringFromCommand (vtkClientServerStream::Commands cmd) |
Get a string describing the given command. More... | |
static vtkClientServerStream::Commands | GetCommandFromString (const char *name) |
Get the command named by the given string. More... | |
static vtkClientServerStream::Array | InsertArray (const char *, int) |
Allow arrays to be passed into the stream. More... | |
static vtkClientServerStream::Array | InsertArray (const short *, int) |
static vtkClientServerStream::Array | InsertArray (const int *, int) |
static vtkClientServerStream::Array | InsertArray (const long *, int) |
static vtkClientServerStream::Array | InsertArray (const signed char *, int) |
static vtkClientServerStream::Array | InsertArray (const unsigned char *, int) |
static vtkClientServerStream::Array | InsertArray (const unsigned short *, int) |
static vtkClientServerStream::Array | InsertArray (const unsigned int *, int) |
static vtkClientServerStream::Array | InsertArray (const unsigned long *, int) |
static vtkClientServerStream::Array | InsertArray (const long long *, int) |
static vtkClientServerStream::Array | InsertArray (const unsigned long long *, int) |
static vtkClientServerStream::Array | InsertArray (const float *, int) |
static vtkClientServerStream::Array | InsertArray (const double *, int) |
static const char * | GetStringFromType (vtkClientServerStream::Types type) |
Get a string describing the given type. More... | |
static const char * | GetStringFromType (vtkClientServerStream::Types type, int index) |
Protected Types | |
enum | { BigEndian, LittleEndian } |
vtkClientServerStream & | Write (const void *data, size_t length) |
int | ParseData () |
unsigned char * | ParseCommand (int order, unsigned char *data, unsigned char *begin, unsigned char *end) |
void | ParseEnd () |
unsigned char * | ParseType (int order, unsigned char *data, unsigned char *begin, unsigned char *end, vtkClientServerStream::Types *type) |
unsigned char * | ParseValue (int order, unsigned char *data, unsigned char *end, unsigned int wordSize) |
unsigned char * | ParseArray (int order, unsigned char *data, unsigned char *end, unsigned int wordSize) |
unsigned char * | ParseString (int order, unsigned char *data, unsigned char *end) |
unsigned char * | ParseStream (int order, unsigned char *data, unsigned char *end) |
void | PerformByteSwap (int dataByteOrder, unsigned char *data, unsigned int numWords, unsigned int wordSize) |
const unsigned char * | GetValue (int message, int value) const |
int | GetNumberOfValues (int message) const |
void | PrintArgumentInternal (ostream &, int message, int argument, int annotate, vtkIndent) const |
void | StreamToString (ostream &os, vtkIndent indent) const |
void | MessageToString (ostream &os, int m) const |
void | MessageToString (ostream &os, int m, vtkIndent indent) const |
void | ArgumentToString (ostream &os, int m, int a) const |
void | ArgumentToString (ostream &os, int m, int a, vtkIndent indent) const |
void | ArgumentValueToString (ostream &os, int m, int a, vtkIndent indent) const |
int | StreamFromStringInternal (const char *begin, const char *end) |
int | AddMessageFromString (const char *begin, const char *end, const char **next) |
int | AddArgumentFromString (const char *begin, const char *end, const char **next) |
Static Protected Member Functions | |
static vtkClientServerStream::Array | InsertString (const char *begin, const char *end) |
static vtkClientServerStream::Types | GetTypeFromString (const char *begin, const char *end) |
static vtkClientServerStream::Commands | GetCommandFromString (const char *begin, const char *end) |
Friends | |
class | vtkClientServerStreamInternals |
vtkClientServerStream will store zero or more almost arbitrary messages in a platform-independent manner. The stream's data may be copied from one platform to another via GetData/SetData methods, and the message represented will remain unchanged. Messages are used to represent both commands and results for vtkClientServerInterpreter, but they may be used for any purpose.
Definition at line 23 of file vtkClientServerStream.h.
This must be kept in sync with the string table in this class's .cxx file.
Enumerator | |
New | |
Invoke | |
Delete | |
Assign | |
Reply | |
Error | |
EndOfCommands |
Definition at line 48 of file vtkClientServerStream.h.
Definition at line 64 of file vtkClientServerStream.h.
Enumerator | |
BigEndian | |
LittleEndian |
Definition at line 391 of file vtkClientServerStream.h.
vtkClientServerStream::vtkClientServerStream | ( | vtkObjectBase * | owner = nullptr | ) |
vtkClientServerStream::~vtkClientServerStream | ( | ) |
vtkClientServerStream::vtkClientServerStream | ( | const vtkClientServerStream & | , |
vtkClientServerStream& vtkClientServerStream::operator= | ( | const vtkClientServerStream & | ) |
void vtkClientServerStream::Reserve | ( | size_t | size | ) |
void vtkClientServerStream::Reset | ( | ) |
void vtkClientServerStream::Copy | ( | const vtkClientServerStream * | source | ) |
int vtkClientServerStream::GetNumberOfMessages | ( | ) | const |
vtkClientServerStream::Commands vtkClientServerStream::GetCommand | ( | int | message | ) | const |
Returns EndOfCommands if the given index is out of range.
Returns a value less than 0 if the given index is out of range.
vtkClientServerStream::Types vtkClientServerStream::GetArgumentType | ( | int | message, |
int | argument | ||
) | const |
Returns End if either index is out of range.
Returns whether the argument could be converted to the requested type.
int vtkClientServerStream::GetArgument | ( | int | message, |
int | argument, | ||
unsigned long long * | value | ||
) | const |
signed char * | value, | ||
vtkTypeUInt32 | length | ||
) | const |
) | const |
short * | value, | ||
) | const |
int * | value, | ||
) | const |
long * | value, | ||
) | const |
unsigned char * | value, | ||
) | const |
unsigned short * | value, | ||
) | const |
unsigned int * | value, | ||
) | const |
unsigned long * | value, | ||
) | const |
float * | value, | ||
) | const |
double * | value, | ||
) | const |
long long * | value, | ||
) | const |
unsigned long long * | value, | ||
) | const |
vtkStdString * | value | ||
) | const |
std::string * | value | ||
) | const |
vtkClientServerStream * | value | ||
) | const |
vtkClientServerID * | value | ||
) | const |
vtkObjectBase ** | value | ||
) | const |
int & | argument, | ||
vtkVariant * | value | ||
) | const |
Note that this version modifies the argument number as a vtkVariant is passed in the stream as a composite type with a variable number of primitive stream entries required to describe it.
int vtkClientServerStream::GetArgumentLength | ( | int | message, |
vtkTypeUInt32 * | length | ||
) | const |
Returns whether the argument is really an array type.
int vtkClientServerStream::GetArgumentObject | ( | int | message, |
vtkObjectBase ** | value, | ||
const char * | type | ||
) | const |
Returns whether the argument is really of the requested type.
vtkClientServerStream::Argument vtkClientServerStream::GetArgument | ( | int | message, |
int | argument | ||
) | const |
Returns an empty argument if it either index is out of range.
The values are suitable for passing to another stream's SetData method, but are invalidated when any further writing to the stream is done. Returns whether the stream is currently valid.
vtkClientServerStream& vtkClientServerStream::operator<< | ( | vtkClientServerStream::Commands | ) |
vtkClientServerStream& vtkClientServerStream::operator<< | ( | vtkClientServerStream::Types | ) |
vtkClientServerStream& vtkClientServerStream::operator<< | ( | vtkClientServerStream::Argument | ) |
vtkClientServerStream& vtkClientServerStream::operator<< | ( | vtkClientServerStream::Array | ) |
vtkClientServerStream& vtkClientServerStream::operator<< | ( | const vtkClientServerStream & | ) |
vtkClientServerStream& vtkClientServerStream::operator<< | ( | vtkClientServerID | ) |
vtkClientServerStream& vtkClientServerStream::operator<< | ( | vtkObjectBase * | ) |
vtkClientServerStream& vtkClientServerStream::operator<< | ( | const vtkStdString & | ) |
vtkClientServerStream& vtkClientServerStream::operator<< | ( | const vtkVariant & | ) |
vtkClientServerStream& vtkClientServerStream::operator<< | ( | bool | value | ) |
vtkClientServerStream& vtkClientServerStream::operator<< | ( | char | value | ) |
vtkClientServerStream& vtkClientServerStream::operator<< | ( | short | value | ) |
vtkClientServerStream& vtkClientServerStream::operator<< | ( | int | value | ) |
vtkClientServerStream& vtkClientServerStream::operator<< | ( | long | value | ) |
vtkClientServerStream& vtkClientServerStream::operator<< | ( | signed char | value | ) |
vtkClientServerStream& vtkClientServerStream::operator<< | ( | unsigned char | value | ) |
vtkClientServerStream& vtkClientServerStream::operator<< | ( | unsigned short | value | ) |
vtkClientServerStream& vtkClientServerStream::operator<< | ( | unsigned int | value | ) |
vtkClientServerStream& vtkClientServerStream::operator<< | ( | unsigned long | value | ) |
vtkClientServerStream& vtkClientServerStream::operator<< | ( | long long | value | ) |
vtkClientServerStream& vtkClientServerStream::operator<< | ( | unsigned long long | value | ) |
vtkClientServerStream& vtkClientServerStream::operator<< | ( | float | value | ) |
vtkClientServerStream& vtkClientServerStream::operator<< | ( | double | value | ) |
vtkClientServerStream& vtkClientServerStream::operator<< | ( | const char * | value | ) |
This destroys any data already in the stream. Returns whether the stream is deemed valid. In the case of 0, the stream will have been reset.
Returns "unknown" if the type value is invalid. If the type has multiple possible names, the second argument can be used to specify the index of the name to use. The higher the index, the more shorthand the name. If the index is too high, the last name is used.
Returns vtkClientServerStream::End if the type string is not recognized.
Returns "unknown" if the command value is invalid.
Returns vtkClientServerStream::EndOfCommands if the string is not recognized.
void vtkClientServerStream::Print | ( | ostream & | ) | const |
void vtkClientServerStream::Print | ( | ostream & | , |
vtkIndent | |||
) | const |
void vtkClientServerStream::PrintMessage | ( | ostream & | , |
int | message | ||
) | const |
void vtkClientServerStream::PrintArgument | ( | ostream & | , |
int | message, | ||
vtkIndent | |||
) | const |
const char* vtkClientServerStream::StreamToString | ( | ) | const |
void vtkClientServerStream::StreamToString | ( | ostream & | os | ) | const |
The syntax of the string must be that produced by the StreamToString method. Returns 1 if the string is successfully parsed and 0 otherwise.
staticprotected |
staticprotected |
staticprotected |
friend |
Definition at line 436 of file vtkClientServerStream.h.
