Plugins
StreamingParticles
CMakeFiles
StreamingParticles_server_manager_modules
StreamingParticles_server_manager_modules_data.h
1
// Loadable modules
3
// Generated by /builds/gitlab-kitware-sciviz-ci/build/bin/vtkProcessXML-pv5.13
4
5
#ifndef StreamingParticles_server_manager_modules_data_h
6
#define StreamingParticles_server_manager_modules_data_h
7
#include <cstring>
9
#include <cassert>
10
#include <algorithm>
11
12
13
// From file /builds/gitlab-kitware-sciviz-ci/Plugins/StreamingParticles/Particles/StreamingParticles.xml
14
const
char
const
StreamingParticles_server_manager_modulesStreamingParticlesInterface0
15
"<ServerManagerConfiguration>\n"
16
" <ProxyGroup name=\"representations\">\n"
17
" <RepresentationProxy name=\"StreamingParticlesRepresentation\"\n"
18
" class=\"vtkStreamingParticlesRepresentation\"\n"
" processes=\"client|renderserver|dataserver\">\n"
20
" <Documentation>\n"
21
" This is the new representation type we are adding. This is identical to\n"
22
" the SurfaceRepresentation except that we are overriding the mapper with\n"
23
" our mapper.\n"
24
" </Documentation>\n"
25
" <InputProperty command=\"SetInputConnection\"\n"
26
" name=\"Input\">\n"
27
" <DataTypeDomain composite_data_supported=\"1\"\n"
28
" name=\"input_type\">\n"
" <DataType value=\"vtkDataSet\" />\n"
30
" </DataTypeDomain>\n"
31
" <InputArrayDomain name=\"input_array_any\">\n"
32
" </InputArrayDomain>\n"
33
" <Documentation>Set the input to the representation.</Documentation>\n"
" </InputProperty>\n"
35
" <IntVectorProperty command=\"SetUseOutline\"\n"
36
" default_values=\"0\"\n"
37
" name=\"UseOutline\"\n"
38
" number_of_elements=\"1\">\n"
" <BooleanDomain name=\"bool\" />\n"
40
" </IntVectorProperty>\n"
41
" <IntVectorProperty command=\"SetUseBlockDetailInformation\"\n"
42
43
" name=\"UseBlockDetailInformation\"\n"
45
46
47
" <IntVectorProperty command=\"SetProcessesCanLoadAnyBlock\"\n"
48
" default_values=\"1\"\n"
49
" name=\"ProcessesCanLoadAnyBlock\"\n"
50
51
52
53
" <DoubleVectorProperty command=\"SetDetailLevelToLoad\"\n"
54
" default_values=\"2\"\n"
55
" name=\"DetailLevel\"\n"
56
57
" <DoubleRangeDomain min=\"0\"\n"
58
" max=\"5e-4\"\n"
59
" range=\"range\" />\n"
60
" </DoubleVectorProperty>\n"
61
" <IntVectorProperty command=\"SetStreamingRequestSize\"\n"
62
63
" name=\"StreamingRequestSize\"\n"
64
65
" <IntRangeDomain name=\"range\" min=\"1\" max=\"1000\" />\n"
66
67
" Set the number of blocks to request at a given time on a single process\n"
68
" when streaming.\n"
69
70
71
" <DoubleVectorProperty command=\"SetPointSize\"\n"
72
" default_values=\"2.0\"\n"
73
" name=\"PointSize\"\n"
74
75
76
" name=\"range\" />\n"
77
78
" <StringVectorProperty command=\"SetInputArrayToProcess\"\n"
79
" element_types=\"0 0 0 0 2\"\n"
80
" name=\"ColorArrayName\"\n"
81
" number_of_elements=\"5\">\n"
82
83
" Set the array to color with. One must specify the field association and\n"
84
" the array name of the array. If the array is missing, scalar coloring will\n"
85
" automatically be disabled.\n"
86
87
" <RepresentedArrayListDomain name=\"array_list\"\n"
88
" input_domain_name=\"input_array_any\">\n"
89
" <RequiredProperties>\n"
90
" <Property function=\"Input\" name=\"Input\" />\n"
91
" </RequiredProperties>\n"
92
" </RepresentedArrayListDomain>\n"
93
" </StringVectorProperty>\n"
94
" <ProxyProperty command=\"SetLookupTable\"\n"
95
" name=\"LookupTable\" >\n"
96
" <Documentation>Set the lookup-table to use to map data array to colors.\n"
97
" Lookuptable is only used with MapScalars to ON.</Documentation>\n"
98
" <ProxyGroupDomain name=\"groups\">\n"
99
" <Group name=\"lookup_tables\" />\n"
100
" </ProxyGroupDomain>\n"
101
" </ProxyProperty>\n"
102
" <DoubleVectorProperty command=\"SetOpacity\"\n"
103
" default_values=\"1.0\"\n"
104
" name=\"Opacity\"\n"
105
106
" <DoubleRangeDomain max=\"1\" min=\"0\" name=\"range\" />\n"
107
108
" <!-- End of StreamingParticlesRepresentation -->\n"
109
" </RepresentationProxy>\n"
110
"\n"
111
" <Extension name=\"GeometryRepresentation\">\n"
112
113
" Extends standard GeometryRepresentation by adding\n"
114
" StreamingParticlesRepresentation as a new type of representation.\n"
115
116
"\n"
117
" <!-- this adds to what is already defined in PVRepresentationBase -->\n"
118
" <RepresentationType subproxy=\"StreamingParticlesRepresentation\"\n"
119
" text=\"Streaming Particles\" />\n"
120
"\n"
121
" <SubProxy>\n"
122
" <Proxy name=\"StreamingParticlesRepresentation\"\n"
123
" proxygroup=\"representations\" proxyname=\"StreamingParticlesRepresentation\">\n"
124
" </Proxy>\n"
125
" <ShareProperties subproxy=\"SurfaceRepresentation\">\n"
126
" <Exception name=\"Input\" />\n"
127
" <Exception name=\"Visibility\" />\n"
128
" </ShareProperties>\n"
129
" <ExposedProperties>\n"
130
" <PropertyGroup label=\"Streaming Particles\">\n"
131
" <Property name=\"UseOutline\" />\n"
132
" <Property name=\"UseBlockDetailInformation\" />\n"
133
" <Property name=\"ProcessesCanLoadAnyBlock\" />\n"
134
" <Property name=\"DetailLevel\" />\n"
135
" <Property name=\"StreamingRequestSize\" />\n"
136
" <Hints>\n"
137
" <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
138
" mode=\"visibility\"\n"
139
" property=\"Representation\"\n"
140
" value=\"Streaming Particles\" />\n"
141
" </Hints>\n"
142
" </PropertyGroup>\n"
143
" </ExposedProperties>\n"
144
" </SubProxy>\n"
145
" </Extension>\n"
146
"\n"
147
" <Extension name=\"UnstructuredGridRepresentation\">\n"
148
149
" Extends standard UnstructuredGridRepresentation by adding\n"
150
151
152
"\n"
153
154
155
156
"\n"
157
" <SubProxy>\n"
158
159
160
" </Proxy>\n"
161
162
163
164
165
166
" <PropertyGroup label=\"Styreaming Particles\">\n"
167
168
169
170
171
172
" <Hints>\n"
173
174
175
176
177
" </Hints>\n"
178
179
180
" </SubProxy>\n"
181
" </Extension>\n"
182
"\n"
183
" </ProxyGroup>\n"
184
" <!-- ==================================================================== -->\n"
185
" <ProxyGroup name=\"sources\">\n"
186
" <SourceProxy class=\"vtkPVRandomPointsStreamingSource\" label=\"Random Streaming Points\"\n"
187
" name=\"RandomPoints\">\n"
188
" <IntVectorProperty command=\"SetNumLevels\" default_values=\"5\"\n"
189
" number_of_elements=\"1\" name=\"NumberOfLevels\">\n"
190
" <IntRangeDomain max=\"6\"\n"
191
" min=\"1\"\n"
192
193
" <Documentation>Set the number of levels in the octree of blocks\n"
194
195
196
" <IntVectorProperty command=\"SetPointsPerBlock\" default_values=\"100\"\n"
197
" number_of_elements=\"1\" name=\"PointsPerBlock\">\n"
198
" <Documentation>Set the number of points generated in each block\n"
199
200
201
" <IntVectorProperty command=\"SetSeed\" default_values=\"1\"\n"
202
" number_of_elements=\"1\" name=\"Seed\">\n"
203
" <Documentation>Set the seed of the random number generator\n"
204
205
206
" <Documentation>This source creates random points in an octree of blocks to be\n"
207
" used with the Streaming Particles representation</Documentation>\n"
208
" </SourceProxy>\n"
209
" </ProxyGroup>\n"
210
"\n"
211
"</ServerManagerConfiguration>\n"
212
"\n"
213
// Get single string
214
inline
char
StreamingParticles_server_manager_modulesStreamingParticlesGetInterfaces
215
216
217
const
size_t
len0 = strlen(
218
size_t
len = ( 0
219
+ len0 );
220
char
* res =
new
char
[ len + 1];
221
size_t
offset
= 0;
222
std::copy(
+ len0, res + offset); offset += len0;
223
assert(offset == len);
224
res[offset] = 0;
225
return
res;
226
227
228
229
230
#endif
char * StreamingParticles_server_manager_modulesStreamingParticlesGetInterfaces()
Definition:
StreamingParticles_server_manager_modules_data.h:214
offset
offset
static const char *const StreamingParticles_server_manager_modulesStreamingParticlesInterface0
Definition:
StreamingParticles_server_manager_modules_data.h:14
1.8.13 on Tue Jan 21 2025
